Thread: Utorrent problem!
    • EaGL1337's Gadgets
      • Gigabyte H55M-S2H in Thermaltake Dokker
      • Intel Core i5 750, 2.66 GHz, 8MB L3 Cache, Quad Core
      • 2x2GB DDR3 1333MHz (Total 4GB)
      • SAMSUNG Spinpoint F3 HD502HJ 500GB
      • XFX AMD Radeon 6950 2 GB GDDR5 @ Stock clocks
      • Samsung 943NWPLUS 19 inch widescreen LCD display
      • Integrated Realtek High Definition Audio System
      • Altech Lansing VS2621 2.1 Speaker System/TT Esports Shock One Gaming Headset
      • A4 Tech multimedia keyboard
      • Razer Taipan 4G
      • Delta 550W
      • Asus DVD writer 24X
      • Windows 7 Ultimate 32 bit
      • After the upgrade, this thing kicks a$$!
      • 64KB before 8PM. 160 KB after 8PM
      • Same as above
    EaGL1337's Avatar
    Default Utorrent problem!
    Whenever I start Utorrent it works fine for 30 seconds then it stops responding. What could be the problem? :S I never had it before.
    Default Re: Utorrent problem!
    Quote Originally Posted by EaGL1337 View Post
    Remove your settings.dat
    Probably a torrent with a filename in a codepage that exceeds 255 bytes. Had this happen for myself too.
      • Razer Taipan 4G
      • Delta 550W
      • Same as above
    EaGL1337's Avatar
    Okay I've removed it. Let's see what happens.
    ---------- Post added at 13:37 ---------- Previous post was at 01:10 ----------
    Nah, no dice. :/
    Nah, no dice. :/
    Remove the whole uTorrent folder from %appdata%
    (Well, move it elsewhere, don't delete)
    If that doesn't fix it, try running uTorrent as admin. If that fixes it, problem is with group policies.
  1. Replies: 24
    Last Post: July 7th, 2011, 15:00
  2. uTorrent Help!
    By Hamilton in forum Software
    Last Post: May 23rd, 2011, 16:21
  3. Post Your uTorrent Statistics!!
    By Deep -xCross- in forum File Sharing and Torrents
    Last Post: May 24th, 2010, 06:58
  4. Post Your uTorrent Statistics!!
    By Deep -xCross- in forum Internet
  5. utorrent problem
    By Necray in forum File Sharing and Torrents
    Last Post: May 6th, 2009, 19:34
Page generated in 0.16920 seconds with 14 queries.
