Results 1 to 13 of 13
Thread: Problem with LAN and Multiplayer
    Default Problem with LAN and Multiplayer
    HI guys, some of you should already know that my pc configuration is way too low to run most games I want to play. However, luckily Need For Speed Most Wanted runs pretty well on both my desktop and laptop (although from its later sequel, Pro Street, I'm outta luck ). Now I wanted to play with my brother via LAN. But I failed. Here's what happened:
    I connected both laptops, configured the IPv4 settings to 10.0.0.1 and 10.0.0.2 then pinged to test whether the connection was successful. Then I opened mw in both computers, created a host then tried to join the game from the other one. Guess what it didn't work at all. A few times it seemed to work but as soon as I tried to 'join' the game the game crashed. I checked online and found a few fixes to get rid of this problem. However, none of them worked for me.
    Another question I have in mind is how do I play online? I mean, it's not possible to get an EA authorization code without buying the title. Still I see many people are playing online. My connection is banglalion 512kpbs. Is that good enough for playing online? If yes, how can I play?
    That's all for today. Hope you guys will help.
    Most of you don't know me. However, a lot of you have discussed about the articles I wrote and visited my blog at least once. Wondering? Well, do you recall these two links?
    http://aisjournal.com/2010/12/17/hon...ew-banglalion/
    My Blog | Flickr
    • sadi_warhead's Gadgets
      • MSI G41
      • Intel(R) Core(TM)2 Quad CPU Q8400 @ 2.66GHz (4 CPUs)
      • ADATA 4096MB RAM DDR3
      • 1 TB Samsung H3
      • Gigabyte GTX 560OC-1GI 1 GB
      • 22" samsung 2233sw
      • Realtek HD Audio output input
      • Creative 2.1/A4tech headphones
      • BenQ mulitmedia
      • A4 teCH
      • Sony controller
      • Fortex 600w
      • Windows 7 Ultimate 64-bit (6.1, Build 7600)
      • Motamuti-:| :)
      • Ispros
    sadi_warhead's Avatar
    MIRPUR
    Default Re: Problem with LAN and Multiplayer
    for playing online with friends .. choose gameranger [http://www.gameranger.com/]
    lan settings: no idea
    Fly High, Do or Die, Dare to Dream, Cheer Extreme!
    Quote Originally Posted by sadi_warhead View Post
    Will it work with my banglalion 512 kbps?
    My Blog | Flickr
    • Franklin's Gadgets
      • Gigabyte z97P D3
      • NIA Wireless Headset
      • A4 tech
      • DS4 Wireless Controller
      • Cooler Master v750W
      • Asus DVD RW 24x
      • Transcend Jetflash v70 8 GB
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    Thumbs up Re: Problem with LAN and Multiplayer
    Quote Originally Posted by aisajib View Post
    Playing online games with Banglalion is horrible. Not only because of high ping but also because of frequent dc problem. You better consider BTCL or Link3. By the way, Banglalion doesn't allow port forwarding. So, you have to change your ISP anyway.
    As for how to play online with your brother, my signature says it all . I played NFS MW in Tunngle lag free with Qubee 512 kbps with a BD player.
    Quote Originally Posted by Kevepeter View Post
    I'm considering to switch as well. May not happen anytime soon, but will switch. I hate FUP.
    By the way, does tunngle use Internet data? It looks like so. In that case, I won't be using it. Again, FUP. Plus it's not given that an active internet connection will be available all the time. By Lan, I meant lan cable's both end connected to two computers. So there's no more ports for internet connection.
    My Blog | Flickr
    • akk's Gadgets
      • MSI G 41 P33 Combo
      • Intel Core 2 duo E 8400 3.00GHZ
      • Transcend 4 GB DDR 3 1600BUS
      • WD Caviar Green 2 TB
      • XFX ATI RADEON HD 4650 1GB
      • Samsung 18.5 IN LCD TFT (WIDE)
      • Realtek Built IN
      • 1.Perfect 5.1 +2 Sony Speakers Customized 7.1 & 2.A4 Tech HS -100
      • A4tech AntiRSI Multimedia+Logitech K200
      • A4 Tech+Logitech
      • 2 Dilong PU -305, Dilong 401T & A.tech dual vibe
      • DELL 300Wx2
      • Asus 52x DVD RW multispeed & multilayer compaitable
      • Prolink USB Modem(T&T)
      • apollo 650 VA
      • Windows 7 x64 Ultimate
      • 6.6 out of 7.9
      • Works Fine
      • Royal Green Online
      • ~34 KB
      • ~ 20 KB
    akk's Avatar
    I had the same problem like yours.
    Solution:
    1.After connecting the two pc's , go to the installation dirctory of the MSW(Both Laptop And desktop).Rt click on speed.exe set the compatibility to windows XP sp3 (No matter what your os is).
    2.Then run the game . Host a game in on pc.Then on the other search server>join>session Match>any >join.
    I think ur good to go.
    Gameranger e proti raat 1.00 am er dike BD er onek player MSW khele. Ami onek er sathe khele dekhsi tadero wimax kintu problem hoi na . If u like u can join.
    Quote Originally Posted by akk View Post
    Solution:
    Thanks your tips. I'll try that next time.
    My Blog | Flickr
      • Gigabyte z97P D3
      • A4 tech
      • Asus DVD RW 24x
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    What do you mean by Tunngle uses Internet data? Tunngle needs internet to run. FUP will not be a problem. Wimax is fine for gaming, but either the host or the player has got to have his port forwarded. Otherwise, no connection can be established. And Banglalion does not allow port forwarding.
    • Rorschach's Gadgets
      • MSI B85 GAming
      • Core i3 4130 3.2Ghz
      • Corsair vengeance 2*4gb = 8gb Ddr3 1600Mhz
      • 128Gb Crucial M4 SSD + 2TB Hitachi HDD + 2* 2TB Seagate HDD+2TB Seagate HDD+(4TB+3TB) Seagate HDD
      • EVGA GTX 980 SC ACX cooler
      • Sony Bravia W670A 32inch
      • Sound Blaster X fi Titanium
      • Panasonic HTF600 + Creative 4:1 Speaker
      • Ducky
      • V3
      • Xbox 360 Controller In PC via Receiver
      • TT Toughpower XT 675W 80+Bronze
      • Asus Dvd-RW ; NZXT Sentry 2
      • Thermaltek Armor
      • Luminious 1000VA
      • Windows 10 64Bit
      • BUCT 2Mbps real ip
      • 12.5MBPS
      • 12.5MBPS
    Rorschach's Avatar
    Oct 2011
    IS Gamer-ranger IS the Only Option ...??
    Does Citycell Zoom Ultra allow port forwarding? How much data is sent and received during playing a game? I'm only subscribed to 1.5 GB limited package. Do you think it's not enough to use this connection for gaming?
    My Blog | Flickr
    • BrknSword's Gadgets
      • MSI H81M-E33 (MS-7817)
      • Core i3 4150 @3.5 GHz
      • 6 GB DDR3
      • 1.25 TB
      • NVIDIA GeForce GTX 750
      • Samsung S19C300 (18.5 inch)
      • Altec Lansing VS2621
      • Basic
      • Basic
      • Thermaltake Litepower 550W
      • ProLink
      • Windows 10 Pro
      • Average
      • 120 kbps
    BrknSword's Avatar
    Gazipur,Bangladesh.
    GameRanger a MW khelte gele ki ki kora lage?
    plus kono problem ki hoy GR a MW khelte?
      • Gigabyte z97P D3
      • A4 tech
      • Asus DVD RW 24x
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    @aisajib, they don't. As for the data sent and received during gameplay, it's equivalent to your upload and download speed.
  1. The 11 best multiplayer games ever
    By anik_lc in forum Online Multiplayer
    Last Post: August 15th, 2011, 23:27
  2. Replies: 4
    Last Post: November 26th, 2010, 20:47
  3. FIFA 10 HowTo | Fifa 10 Online : 2 v 2 (Multiplayer Lan)
    By Valkyrie™ in forum Older FIFA Games
    Last Post: July 6th, 2010, 04:12
  4. multiplayer games
    Last Post: October 8th, 2008, 12:40
Page generated in 0.25559 seconds with 14 queries.
