Results 1 to 10 of 10
Thread: I need your advise on buying a Power Supply Unit for my PC. Please help
    Default I need your advise on buying a Power Supply Unit for my PC. Please help
    I need to buy a PSU and I need it to run Phenom X4 965 , XFX HD6570, CD/DVD rom, HDD, RAM and etc and I dont know which power supply is good for money please give me your suggestion on cost effective PSU units. I've read very good reviews on Delux PSU.Please tell me where to buy it in a cheap price if you know any one or store name and number then please give me. Thanks
    Member Riese's Avatar
    Bogra, Bangladesh
    Default Re: I need your advise on buying a Power Supply Unit for my PC. Please help
    Any generic psu is enough for the your pc.If you want a branded one you can get gigabyte 460w for 3,300.
    hey GameBalok 1st of all wc to BanglaGamer, as this is ur 1st post i would request to introduce urself in introduction thread, about the advice u want, for ur current setup u just need a decent 400-500w psu and u r safe(not those chinese cheap psu i mean) and to be future proof u may go for 650+ psu's(those r very expensive).....so all depends upon ur budget... about delux psu's they have good reputation in international market but the unit jeigula dhaka te availabe oigular baper e amar kono idea nai...to be on safe side get better and reliable branded psu like xfx, Delta, Gigabyte, Thermaltake...xfx and delta psu's are expensive for example a 500-550w unit will cost u 5.8-6.5k(5800-6500tk) but if u are looking for more cost effective solution u may go for either gigabyte superb series psu (4-5k) and also u may buy thermaltake litepower or tr2 series which may cost u around (4-5k), achha u can get thermaltake psu from Star Solution level 9 Multiplan center and u can get gigabyte superb series from foresight in IDB bhaban.....................and i u are looking for even more cost effective solution please see-http://www.cellbazaar.com/web/item-d...%2fpage-1.aspx as the seller is me.......
    best of luck getting ur psu, and dont forget to introduce urself in introduction thread..
    Bogra, Bangladesh
    Quote Originally Posted by musvi View Post
    hey GameBalok 1st of all wc to BanglaGamer, as this is ur 1st post i would request to introduce urself in introduction thread, about the advice u want, for ur current setup u just need a decent 400-500w psu and u r safe(not those chinese cheap psu i mean) and to be future proof u may go for 650+ psu's(those r very expensive).....so all depends upon ur budget... about delux psu's they have good reputation in international market but the unit jeigula dhaka te availabe oigular baper e amar kono idea nai...to be on safe side get better and reliable branded psu like xfx, Delta, Gigabyte, Thermaltake...xfx and delta psu's are expensive for example a 500-550w unit will cost u 5.8-6.5k(5800-6500tk) but if u are looking for more cost effective solution u may go for either gigabyte superb series psu (4-5k) and also u may buy thermaltake litepower or tr2 series which may cost u around (4-5k), achha u can get thermaltake psu from Star Solution level 9 Multiplan center and u can get gigabyte superb series from foresight in IDB bhaban.....................and i u are looking for even more cost effective solution please see-http://www.cellbazaar.com/web/item-d...%2fpage-1.aspx as the seller is me.......best of luck getting ur psu, and dont forget to introduce urself in introduction thread..
    Good;kintu hd6570 chalaite delta,xfx 500/550w besi holona?
    ---------- Post added at 23:36 ---------- Previous post was at 23:08 ----------
    @gameBalok Didn't saw your post is the first one.WC & here is the Member Introduction.
    Quote Originally Posted by s1ahmed View Post
    but bro 1 ta gigabyte 460w er price e jodi apni 1 ta thermaltake 500w tr2 pan with 11months warranty tahole konta better...
    Bogra, Bangladesh
    Ami ki mana korsi tr2 500 nite ami khali suggestion er kotha bolsi ai pc'r maximum 200w power lagbe.So,xfx 550/delta 500 kinleo eficiency vhalo hobe na.
    Taka thakle ami nitam apnar psu ta
    yeah brother i just gave him a cost effective idea yeah behind that idea amar shartho jorito ase but with that price psu like a TT 500w tr2 with 11 months warrany kintu oneek cost effective o hobe uar jonno plus amar o help hobe...
    • RYDER23's Gadgets
      • AsRock H55LE
      • Core i5 750 (4x @ 2.66Ghz | 8MB)
      • Corsair Vengeance 4096MB DDR3 (1600MHz)
      • Samsung 500GB 7200RPM
      • ASUS ENGTX550-Ti DirectCU
      • 1440x900 Widescreen LCD
      • A4Tech X7-747H
      • ADATA HM650 - 650Watt (80Plus Bronze)
      • ASUS DVD-R
      • Windows 7 32bit
      • Coming Soon...
      • Something I can't live without....
      • 60-90kbps
      • Maximum 20kbps
    RYDER23's Avatar
    Jul 2011
    Dhaka, Bangladesh, Bangladesh
    3000 takae kotoh watt pabo? kon brand? (except Thermaltek Lightpower)
    • war1oc's Gadgets
      • Gigabyte H55M-USB3
      • Intel Core i5 760
      • 2 x 2GB 1333 Mhz
      • Samsung Spinpoint F3 [HD103SJ/B] 1TB
      • Leadtek GTX 560Ti cooled with Arctic Cooling accelero Twin Turbo II
      • Viewsonic VX1937
      • A4Tech HS-800
      • A4Tech XL-747H
      • XFX pro 650w
      • Apollo 800 VA
      • Windows 7 32-bit
    war1oc's Avatar
    Oct 2009
    Quote Originally Posted by demented23 View Post
    delta 400w
    • RYDER23's Gadgets
      • AsRock H55LE
      • A4Tech X7-747H
      • ASUS DVD-R
      • Windows 7 32bit
      • Coming Soon...
      • 60-90kbps
      • Maximum 20kbps
    RYDER23's Avatar
    Jul 2011
    Asus P-50GA 500watt second hand seller paisi... 1.5 years used.. asking 4000 for it... should I take it?
    ---------- Post added at 13:51 ---------- Previous post was at 13:43 ----------
    Delta nlieh... GPS-500AB-A model ta valo?
  1. Power Supply Buying Help .
    By GalibZ in forum Help - PC Buying
    Last Post: August 30th, 2011, 15:41
  2. Best Power Supply Unit within 8k - 8.5k ?
    By s.s.shuvo in forum Others PC Hardware
    Last Post: August 8th, 2011, 21:15
  3. Replies: 43
    Last Post: February 12th, 2011, 20:19
  4. Replies: 21
Page generated in 0.22717 seconds with 14 queries.
