Thread: Help buying Raspberry Pi 2 Model B
    • Mahdi's Gadgets
      • Biostar Hi-Fi Z77X in Thermaltake Dokker (with 120mm intake and 140mm exhaust fan)
      • Intel Core i5 2400 3.1 GHz with Cooler Master Hyper 212 Evo
      • 2X8GB Team Dark DDR3 OC 1600 MHz
      • Samsung 850 Evo 250GB SSD + 2TB HDD
      • Asus DCII Top 560 GTX
      • Dell S2240L 1080p 22 inch display
      • Realtek Built-in Hi-Fi chip
      • Microlab 5.1
      • Logitech K270 Wireless
      • A4Tech X7
      • XBox 360 Controller for Windows
      • XFX Pro Edition 650 Watt
      • Samsung 24x DVD-RW
      • ADATA 1TB Portable Drive
      • 1200 VA
      • Windows 10 Professional x64
      • Gets the job done.
    Dec 2011
    Default Help buying Raspberry Pi 2 Model B
    I am planning to buy a Raspberry Pi 2 Model B. I am thinking about buying from techshopbd.com. It is priced 5000 (approx.) taka there. Are they good or any suggestion for buying from elsewhere?
    Moreover, those who are using it, can you please give me some information about:
    1. Compatibility of locally available brands (such as TP-Link) Wi-Fi dongles with Raspberry Pi?
    2. What SD cards you are using with it?
    Last but not least, I am planning to use it as a media center PC, is it a good idea?
    u would be better off with a nano atx system like this 1.
    http://globalbrand.com.bd/Computer_H...rice&order=ASC
    Asus J1800I-C Motherboard
    5,800 BDT probably includes 2gb DDR3L
    Quote Originally Posted by Mahdi View Post
    Raspberry Pi is great for the GPIO pins but not for media center, if you need something like that go with either AMD's low cost offerings or from intel.
    • MusharratC's Gadgets
      • MSI 990FXA G65
      • Asus VX229
      • Prachin JVC UX T1
      • Gigabyte Pulse 650W
      • Dead Powertree 1250VA
      • An ALMOST decent rig!
    MusharratC's Avatar
    Feb 2013
    Sorry for the OT, but which one is the better option for a torrent-box? A RPi/ similar boards or low end AMD/Intel solutions?
    Quote Originally Posted by MusharratC View Post
    For torrentbox go with intel/AMD solutions, I tried Raspberry pi and kola pi, none of them is that fast really. They are awesome at what they do but not for this.
    If you need just a seedbox go with intel/amd solutions, if you need more than that, say you want to control some other devices at the same time go for the pi.
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    Don't know whether this will be compatible with your project but there is new IoT platform creating buzz called Omega that you can try.
    It runs full linux and you code using high level programming languages like Javascript, PHP and Python along with tools like Git or npm.
    It also has built-in WiFi and more compact than Raspberry Pi.
    I am going to get one in future for sure.
    Quote Originally Posted by йЦммєя³¹ View Post
    performance should be very very low. 400MHz processor with 64MB RAM, really not enough this days. Even pi with .7-1GHz with 512MB of RAM is sluggish.
  1. Sale (New) Raspberry Pi Model B (Made in UK)
    By MAXPAYNE in forum Shop - Gadgets
    Last Post: March 9th, 2014, 13:18
  2. Sale (New) Raspberry Pi Model B Revision 2.0 (512MB)
    By thunderroid in forum Shop - General
    Last Post: June 27th, 2013, 13:41
  3. Sale (Used) Raspberry Pi
    By ruleworld in forum Shop - Gadgets
    Last Post: March 28th, 2013, 00:42
  4. Replies: 1
    Last Post: February 4th, 2012, 12:39
  5. Replies: 1
    Last Post: May 7th, 2011, 00:41
Page generated in 0.19014 seconds with 14 queries.
