Thread: Banglalion Signal Problem
    Member Shoaib's Avatar
    Khulna
    Default Banglalion Signal Problem
    Well... Ami akta banglalion modem kinbo bole bhabci... Barisal a sudhu banglalion e paoa jay... But amader basa 1st floor a.
    Toh Signal strength somporke dharona paoa'r jonno ajke duita friend r wimax modem ane test korci... 1st modem ta sei adi-kaler 'lej-wala' modem jeta kono signal e pay na. (computer cpu desk r upor uthiye o try korci). But kono signal e Pay na.
    2nd ta holo 999tk r modem ta(jeita ami kinbo). Aei ta diye normal obostha te pay na. Bt cpu desk r upor uthaile signal 6dB-13dB r moddhe thake. And usually 11dB Pay... And 2-3 'bar' pay. But oitay balance na thakay DL speed test korte pari nai...
    Toh ami ki full speed pabo?
    • Frank3nst3in's Gadgets
      • MSI 760GM-P33
      • AMD Athlon II X4 640
      • Samsung 500GB F3, WD Blue 1TB, Seagate Barracuda 1TB, Hitachi 160GB
      • ECS EliteGroup GTX 550Ti
      • ASUS VX229H 21.5
      • Creative SB X-Fi Titanium
      • Panasonic HTF600, SoundMagic E10
      • CM Storm Devastator MS2K
      • CM Storm Devastator MB24
      • Windows 8.1
      • 64 KBps
    Frank3nst3in's Avatar
    Default Re: Banglalion Signal Problem
    Buy the gigaset one,BL provides the gigaset one,right?
    • blitzkrieg's Gadgets
      • Intel DG41RQ
      • Intel Core 2 Duo E7500 Wolfdale (45nm)
      • 4GB DDR-2 800 MHz Dual Channel
      • 250 GB Samsung
      • Sapphire Radeon HD5870 PCIE 2GB GDDR5 256BIT
      • LG Flatron W1942SR
      • X-Fi platinum
      • Creative Gigaworks 5.1
      • Standard
      • Standard
      • Thermaltake Tough Power 650 watt
      • Samsung DVD writter
      • Rahimafroz 550 va
      • Windows 7 Ultimate x64
      • I'm satisfied.
      • 20
      • 56
    blitzkrieg's Avatar
    @Frank3nst3in Qubee provides Gigaset. BL has the desktop modem version.
    BL Desktop modem,Specifically the one which has no WiFi access,Yes the Ask Colored statue type one works pretty fine with me...
    • ronycmc's Gadgets
      • ASUS P5KPL-AM (G31)|| Acer mobile GL40
      • Pentium DC E5200 @2.5Ghz|| Intel Dual core T4200(2.0GHz) 800 FSB
      • Twinmos 2GB DDR2 800 Bus|| Samsung 2GB DDR3 1066 Bus
      • Samsung 320GB||Western Digital 160GB
      • Sapphire HD4670 512 MB DDR3
      • Samsung 22" 2243swx @1920*1080 || 14" @1366*768
      • Creative Audigy 2 Zs|| Realtek ALC 888s
      • Creative 5.1 T6060|| Acer 3D sonic
      • MINI
      • A4Tech Optical
      • Asus 24x DVD RW
      • Prolink 650 VA
      • XP,Windows 7
      • GP
    Chittagong
    u need to buy bl indoor modem. Bl now only providing zyxel modem,which is good enough.price 2426tk.i m using one.i have one usb (zte)modem also. In my office usb modem shows only 6db and disconnet frequently. But zyxel works fine,got 2 signal out of of 3.** older indoor modem (awb) which is currently out of stock have wifi.if u lucky enough to find one buy this.
  1. Are you going to break the signal anymore?
    By CODhunter in forum Miscellaneous Topics
    Last Post: June 29th, 2011, 23:03
  2. LCD tv dish signal booster
    By Mohiuddin in forum Help - General Shopping
    Last Post: May 18th, 2011, 22:39
  3. problem with banglalion
    By @nonymous™ in forum WiMAX
    Last Post: April 3rd, 2011, 19:38
  4. Banglalion Weather Problem
    By neo.matrix in forum WiMAX
    Last Post: November 2nd, 2010, 02:12
  5. Wimax signal reciption increasing ?
    By neo.matrix in forum Internet
    Last Post: August 21st, 2010, 00:28
Page generated in 0.17408 seconds with 14 queries.
