Results 1 to 20 of 24
Thread: Ocing Noob needs Help Overclocking i7 930 to 4ghz
    • Kruger's Gadgets
      • Gigabyte X58A UD7 REV 2, 3 way SLI Silent heat pipe II
      • Intel Core i7 930 at 4.1 ghz OCed with THERMALTAKE FRIO OCK
      • Adata XPG 6 GB DDR3 @ 1600 mhz cl 7
      • Western Digital CAVIAR BLUE 6.0 gb/s 7200 rpm SATAIII 500gb
      • ASUS GTX 570
      • Dell P2211H 21.5" HD LED Monitor
      • Realtek Dolby Prologic II HD Sound Card (Azalia)
      • Creative 4.1
      • Thermaltake Challenger Pro
      • Cyborg R.A.T. 3 on Razer Vespula (Hard) Pad
      • Adata HM-750 watt , SLI and 80+ Bronze 60A On 12 V rail
      • Sony 24x DVD-R/RW
      • Bluetooth 2.0 A2dp Room
      • 1200 VA iNeat Just for the CPU
      • Windows 7 64bit Ultimate Housed in Thermaltake SPEDO ADVANCED
      • 7.8 CPU, 7.9 Memory,7.9 Aero,7.9 Gaming
      • Worked hard to earn it , i paid for these stuff , so the satisfaction lvl is up there :D
      • Bangla Lion 512kbps Unlimited
      • 63+
      • 20kbps
    Kruger's Avatar
    Dhaka,Town : Uttara
    Default Ocing Noob needs Help Overclocking i7 930 to 4ghz
    Mother Board - X58 A UD7 Rev 2
    CPU - i7 930
    Hell hath no fury like Kruger Hawke Pissed off
    Default Re: Ocing Noob needs Help Overclocking i7 930 to 4ghz
    Bump the cpu pll, qpi voltages...set BLCK to 200 & lower the multi to 21x
    Quote Originally Posted by EyE SpeeD | DeViL View Post
    come on rakin this is not the way to oc any cpu...its a delicate matter and it needs a lot patience and time coz as u know each hw has different oc potential, so just bumping pll and vcore isn't a good idea at all....
    @Kruger bro wassup....apnar shathe iftar party te temon 1 ta kotha hoi nai...newayz there are lots of oc guides over internet, take help from google then proceed as i already said overclocking is the art of matching of ur hw's maximum potential with in minimal power usage(bumping vcore/volt mod) and also considering the heat emitted from the oc'ed hw.....so for this u need to spend a little time to learn this...
    ---------- Post added at 21:46 ---------- Previous post was at 21:44 ----------
    this might help u..
    http://www.clunk.org.uk/forums/overc...beginners.html
    Quote Originally Posted by musvi View Post
    this might help u..
    He cant go 4GHZ so i suggested to raise those voltages as he is facing stablitiy prob even with 1.45 vcore....
    • Kruger's Gadgets
      • ASUS GTX 570
      • Creative 4.1
      • Sony 24x DVD-R/RW
      • 63+
      • 20kbps
    Kruger's Avatar
    Dhaka,Town : Uttara
    Not working man i need Help
    lol i guided him to every possible methods but his pc won't boot after 3.9GHz..So his bad luck i guess.....
    • Kruger's Gadgets
      • ASUS GTX 570
      • Creative 4.1
      • Sony 24x DVD-R/RW
      • 63+
      • 20kbps
    Kruger's Avatar
    Dhaka,Town : Uttara
    Thanks Rakin , it worked
    • Kruger's Gadgets
      • ASUS GTX 570
      • Creative 4.1
      • Sony 24x DVD-R/RW
      • 63+
      • 20kbps
    Kruger's Avatar
    Dhaka,Town : Uttara
    thanks @musvi
    Did some tweeking and REACHED the MILESTONE
    • Kruger's Gadgets
      • ASUS GTX 570
      • Creative 4.1
      • Sony 24x DVD-R/RW
      • 63+
      • 20kbps
    Kruger's Avatar
    Dhaka,Town : Uttara
    ur guide really helped bro
    Quote Originally Posted by Kruger View Post
    thanks @musvi
    I'm glad that helped u...
    I'm really impressed that u managed to reach 4GHZ with only 1.34vcore, but have u tested the stability of ur system either with Prime 95 or Intel BurnIn Test? and what about the highest temp in full load?
    • Kruger's Gadgets
      • ASUS GTX 570
      • Creative 4.1
      • Sony 24x DVD-R/RW
      • 63+
      • 20kbps
    Kruger's Avatar
    Dhaka,Town : Uttara
    nope it was not stable , but i bumped the Volt to 1.37 vcore and ran prime95 for 30 mins stable and temps 80 DEAD - highest
    80c with frio ock...:O which thermal compound u r using? and if ur system is stable @1.37 thats fine(but 1.37 is way too much if u dont have better cooling solution but u have maybe a better thermal compound and its proper application would help) but bro 80c for prolonged use is very unhealthy for ur cpu, try to keep the temp below 71c, coz akhon ambient temp kintu kom(weather besh thankda) but gorom porley kintu aro heatup hobe(except u have ac in ur room).....
    but bro the fact is we are living in a summer based country, seeing the online review(which actually held in any europian country) where ambient temp is around 15c, buying any hw is totally disappointment, in case of me, ami nijei saw a lot of review before buy my frio and got very impressed, but now i'm using it(ThermalTake Frio) and the performance is nowhere near those reviews, but ki korar our ambient temp waaaaaaaay toooo high and ami nijei ei summer e amar q9550'r temp 71c er nich e rakhtey literally himshim khaisi.....
    oneek kotha boley fellam bhaia.....try to lower the temp below the highest rated temp stated by intel which is 71c for a 45nm processor(afaik and correct me if i'm wrong) and anything higher then this will shorten the life of ur cpu....
    • Kruger's Gadgets
      • ASUS GTX 570
      • Creative 4.1
      • Sony 24x DVD-R/RW
      • 63+
      • 20kbps
    Kruger's Avatar
    Dhaka,Town : Uttara
    thats with PRIME 95 only but without it gaming and other stuff is around 56 highest , i know i think i might have applied the thermal compound wrong , anyway and all my windows were closed and AC off , i think if i turned the AC on the temp would have dropped still i think if i lower any more voltage then i think ill get BSOD . still ill do some more tweaking and see where i can go
    • DarkMan's Gadgets
      • Asrock P67 Extreme6
      • Intel Core i7 2600k @ 4.7ghz [WaterCooled]
      • 2 x 4GB G.SKILL Sniper @ 2133mhz 11-11-11-30
      • Samsung EVO 840 250GB SSD, Segate 2TB + Hitachi 750GB + Samsung 1TB + 250GB + 160GB HDDs
      • Gigabyte HD 5870 1GB @ 900/1250mhz
      • AOC I2251Fwe
      • Creative X-Fi Titanium HD
      • Microlab FC-360 2.1 / Sennheiser HD 558 Headphone
      • A4tech multimedia keybord
      • Logitech G500, Deathadder 2013
      • Xbox 360 Controller
      • Corsair TX-650watt
      • Transend 4 GB Flash Drive; ATI TV Wonder 600
      • Apollo 1200va
      • Windows 8 Pro 64-bit
      • Acording to WEI : 7.8, 7.9, 7.8, 7.8, 7.9
      • Housed in a tt Spedo Advance Case
      • Btcl 1mbps
      • 115 KBPS
      • 32 KBPS
    DarkMan's Avatar
    Bro, Don't stress the cpu too much unless you badly needed those extra mhz. Just find a nice spot considering mhz, vcore and temp.
    And one thing about OC, if there's a "LLC" (Load Line Calibration) setting in bios try to lower or disable it. It creates massive vcore drop while under load and can make the system unstable.
    "Down here in the atmosphere
    Garbage and city lights
    Gonna save you’re tired soul
    Who's gonna save our lives ?"
    • proton_chain's Gadgets
      • Gigabyte GA-P55-UD3
      • 4x4GB DDR3-1600MHz
      • 6.5TB (3TB+2TB+1TB+.5TB)
      • Nvidia Geforce GTX 760 4GB
      • Samsung Syncmaster 22 inch
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
      • Sony Optiarc DVD burner
      • Blue Yeti USB Microphone
    proton_chain's Avatar
    Try to find the sweet spot of your CPU, don't just be mad about a specific frequency (in your case, 4 GHz). Sweet spots offer maximum possible frequency with minimum possible vCore and other voltages. It may be 3.8 or 4.2, but not 4. So, you may even end up OCing your CPU to 4+GHz while using less vCore than 4 GHz itself. Experimentation and patience is the key. True, it won't fry your CPU at current settings. But why not get it done the "OC-er" way?
    For example, my i7's sweet spot is around 3.6 GHz. I can do 3.4 @ 1.17v, 3.5 @ 1.185, 3.6 @ 1.168, 3.7 @ 1.9 ......... 4.2 @ 1.312 volts. So, as you can see, 3.6 mark looks different than the others as it requires exceptionally low voltage. It is impossible to find out unless you do some experimentaion. Once you hit the spot, you can rest assured that your CPU has been tamed.
    If you are OCing not for bragging rights but for performance gains, you may want to reconsider it. Only raytracers' performances scale linearly with frequency and core count, not games or most other apps.
    • Kruger's Gadgets
      • ASUS GTX 570
      • Creative 4.1
      • Sony 24x DVD-R/RW
      • 63+
      • 20kbps
    Kruger's Avatar
    Dhaka,Town : Uttara
    So what do i need to do to find that SWEETSPOT , i need step by step help . like i said NOOB here
    • Mazhar's Gadgets
      • ASUS B250 Strix
      • AMD Ryzen 1700X
      • G.Skill 2x8GB DDR4 3200
      • Samsung 850 Pro 1TB
      • Gigabyte 1070Ti
      • Dell U2711
      • ASUS Essence STX II
      • Beyerdynamic Tesla T1
      • G910
      • G502
      • Xbox One Controller
      • Windows 10 Home
      • Aamra
    Mazhar's Avatar
    Go back to stock volts and run at 3.3ghz. Should be stable there. For every ~100mhz you add, run stability tests (OCCT 1h test should be enough). If unstable, add desired voltage. When you see that the mhz gained is relatively low for the voltage being added, youre moving away from the sweet spot.
    Generally speaking, theres no strict voltage and/or frequency of a sweet spot. But for example, if you require an extra 0.05 volts for 100mhz gain all throughout and then suddenly at one point for the next 100mhz you require an extra 0.15 volts, you know that youre better off in the previous setting.
    Proton_chain explained it quite nicely as well. In my case, the i7 920 required 1.28v for 4.2ghz, 1.32v/4.4ghz but 1.45v/4.6ghz. Ended up staying at 4.4, I didnt really need the extra 200mhz. One more thing, towards the end of the frequency barrier the chip produces a lot more heat for every mhz you increase in the case of Bloomfield (i7 9xx quads). For example, going from 3.4 to 3.6 might be an extra 15w, but 4.0 to 4.2 will be a lot more, in the range of 30w extra. Leakage increases disproportionately at those frequencies. Keep that in mind.
    Good luck
    • Kruger's Gadgets
      • ASUS GTX 570
      • Creative 4.1
      • Sony 24x DVD-R/RW
      • 63+
      • 20kbps
    Kruger's Avatar
    Dhaka,Town : Uttara
    This is a VERY time consuming process but ill do it hehe
    ---------- Post added at 17:53 ---------- Previous post was at 17:52 ----------
    but what about qpi and Pll voltages
    • Kruger's Gadgets
      • ASUS GTX 570
      • Creative 4.1
      • Sony 24x DVD-R/RW
      • 63+
      • 20kbps
    Kruger's Avatar
    Dhaka,Town : Uttara
    ok this is these are the VOLTS i am using to get to 4.09 ghzClick image for larger version.
    • Kruger's Gadgets
      • ASUS GTX 570
      • Creative 4.1
      • Sony 24x DVD-R/RW
      • 63+
      • 20kbps
    Kruger's Avatar
    Dhaka,Town : Uttara
ID:	11346 the clock i am using
  1. Replies: 5
    Last Post: January 16th, 2011, 03:07
  2. Closed Q6600 2.4GHz L2 8MB Socket 775 processor
    By Power_gamer in forum Shop - Gadgets
    Last Post: March 29th, 2010, 01:29
  3. OCing E7400
    By йЦммєя³¹ in forum CPU
    Last Post: September 15th, 2009, 15:45
  4. Chekout my new PC!!!! :D.....need help OCing
    By bid_boi in forum Technical Support
    Last Post: March 21st, 2009, 21:25
Page generated in 0.32369 seconds with 15 queries.
