Results 1 to 18 of 18
Thread: witcher 2 problem ...help me out
    • reza123's Gadgets
      • GIGABYTE G41-M COMBO
      • c2d 2.93 GHZ
      • 2 GB
      • samsung 160
      • NVIDIA GeForce9400GT
      • SYNCMASTER B1930
      • MICROLAB
      • MICRO 650VA
      • XP SP2
    reza123's Avatar
    HABIGANJ
    Default witcher 2 problem ...help me out
    friends help me.....It next ar witcher 2 kinlam farmgate theke kintu setup dite jaiya problem a porlam … disk theke setup nai na pore 4ta dvd disk pc te copy korte chailam kintu tate o problem …1st disk ar witcher2.part08 (400mb) ai file ta sara baki sob file save hoise …witcher2.part08 file ta save korte gele, cannot copy witcher2.part08 : data error (cyclic redundancy check) dekhai …akon ami ki korte pari ..ami dhakar baire thaki ..ple help me ...karo kase ai file ta thakle ple upload kore den / link den ami download kore nibo ...
    The answer lies..in the Heart of battle...
    Default Re: witcher 2 problem ...help me out
    you have got another stupid crc error.you should put the disk on another pc and try to copy the file from there to your pc.sometimes it solves the problem.
    ---------- Post added at 11:05 ---------- Previous post was at 11:00 ----------
    And in 4 dvd version you have to extract the files in 1 folder and then install it from there.you cant just setup it from dvd.
    • akk's Gadgets
      • MSI G 41 P33 Combo
      • Intel Core 2 duo E 8400 3.00GHZ
      • Transcend 4 GB DDR 3 1600BUS
      • WD Caviar Green 2 TB
      • XFX ATI RADEON HD 4650 1GB
      • Samsung 18.5 IN LCD TFT (WIDE)
      • Realtek Built IN
      • 1.Perfect 5.1 +2 Sony Speakers Customized 7.1 & 2.A4 Tech HS -100
      • A4tech AntiRSI Multimedia+Logitech K200
      • A4 Tech+Logitech
      • 2 Dilong PU -305, Dilong 401T & A.tech dual vibe
      • DELL 300Wx2
      • Asus 52x DVD RW multispeed & multilayer compaitable
      • Prolink USB Modem(T&T)
      • apollo 650 VA
      • Windows 7 x64 Ultimate
      • 6.6 out of 7.9
      • Works Fine
      • Royal Green Online
      • ~34 KB
      • ~ 20 KB
    akk's Avatar
    use Bad CD repair for recovering the file. I had the same problem in a DVD of Devil May Cry 4. I recovered the file using it.Before the process run some other DVDs to heat up the drive then start the process.
    You have to change the 4th disk, no other option. And DO NOT use any cd/dvd recovery tool. It is extremely harmful for your optical drive.
    while pepole giving solution they might as well give me a solution for random freezing in witcher 2.
    • Overlord's Gadgets
      • Asrock Z370 Pro4
      • Geil 8GB DDR4 2400
      • MSI GTX 970 OC Gaming 4G
      • ASUS VX229H IPS 21.5 LED
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Samsung 22X DVD RW
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    Quote Originally Posted by shreshto View Post
    install latest patch...
    Quote Originally Posted by hrishat View Post
    i have patch 1.2.doesnt help.
      • Asrock Z370 Pro4
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    then install 1.3 it is the latest.....
    • reza123's Gadgets
      • c2d 2.93 GHZ
      • 2 GB
      • samsung 160
      • SYNCMASTER B1930
      • MICROLAB
      • MICRO 650VA
      • XP SP2
    reza123's Avatar
    HABIGANJ
    ok guys i will try all of ur direction
    • reza123's Gadgets
      • c2d 2.93 GHZ
      • 2 GB
      • samsung 160
      • SYNCMASTER B1930
      • MICROLAB
      • MICRO 650VA
      • XP SP2
    reza123's Avatar
    HABIGANJ
    no option working .. i hav to change the 4th disk
    Try extracting from the dvd
    • reza123's Gadgets
      • c2d 2.93 GHZ
      • 2 GB
      • samsung 160
      • SYNCMASTER B1930
      • MICROLAB
      • MICRO 650VA
      • XP SP2
    reza123's Avatar
    HABIGANJ
    brother ... kaj hoi na
    • Antar's Gadgets
      • Intel DH67BL
      • Intel i5 2400 Sandy Bridge 3.10 GHz
      • 8GB DDR3 Super * Talent (2 x 4)
      • 1 Tb
      • ECS Geforce GTX 550 Ti 1 GB GDDR5
      • Samsung LED 21.5 Inch
      • 10 Channel HD Audio of Realtek
      • Creative 4.1 Sound Blaster
      • A4Tech Wireless
      • A4Tech Wireless
      • XFX Dual Shock
      • Gigabyte 550W
      • 2 Asus DVD R/W
      • Windows 7 Ultimate x64
      • 13609 with 3D Marks 06 Res 1920
      • Looking to make an unique one soon.
      • Qubee and Banglalion Unlimited
      • 1Mbps
    Antar's Avatar
    Aug 2011
    The World
    One of my colleague faced the same prob. His first disk stopped working while almost near to the end being copied. He tried everything but couldn't solve even despite changed the disk several times. Then I suggested him to be in my home and I copied the first disk of mine to his Hard Disk without any prob and now he is playing the game with a smiley face.
    CPU: Intel Core i5 2400 Sandy Bridge 3.10GHz | MoBo: Intel DH67BL Media Series | RAM : 8 GB DDR3 of Super * Talent 1333 Bus | GPU: ECS GTX 550Ti | HD: 1 Tb Samsung | PSU: Gigabyte 550W| Monitor: Samsung LED 22"|
    • buno047's Gadgets
      • asus
      • quad core
      • 2 gb ddr2
      • 250 gb
      • ati 4850
      • Logitech Rumble pad
      • asus 550w
      • xp seven ubuntu
    buno047's Avatar
    chittagong
    its a very critical game i think.. tough also.. i needed walk through several times for finishing the 1st two chapters.. and in the 3rd chapter i coudnt defeat the dragon and later uninstalled it !!! lol.. ma bad!!
    JACK OF ALL TRADES MASTER OF NONE
    • wackedGUNZ's Gadgets
      • Gigabyte B75M-D3H [Case: InWin Mana 136]
      • Intel Core i5-3450 @3.1Ghz
      • Twinmos Mainstream 4GBx1 1600Mhz
      • Western Digital Cavier Blue 1TB 64MB Cache
      • Sapphire R7 260X 2GB OC
      • AOC i2269VWm IPS 21.5inch
      • Realtek Azalia ALC887
      • Microlab FC-360
      • Razer Deathadder 3.5G Black Edition
      • Corsair VS-450
      • Asus 24X DRW-24B3ST DVD Burner
      • Sentron 1200VA
      • lol...don't care!
      • nearly full :)
      • zxonline
      • 160kBps or 1.2mbps
      • same as above
    wackedGUNZ's Avatar
    Quote Originally Posted by buno047 View Post
    me too did the same thing
    • Trave160's Gadgets
      • MSI B350M Mortar AM4
      • AMD Ryzen 5 1600
      • 16GB DDR4 3000Mhz
      • 3TB Western Digital red
      • ASUS Strix GTX 960 4G
      • Dell S2216H 22 Inch monitor
      • Logitech Speaker
      • TtEsports Knucker
      • PS4 Dualshock 4 controller
      • Pendrive 4GB
      • NunuCom Ltd, Penus group
      • Super San 200kbps
      • 105*2
    Trave160's Avatar
    A Secure Area
    For crying out load you gave up that easily , look The witcher 2 rewards players who explores more so you should have gone to places where you're not told to.Also change the difficulty at least i did that sheesh what is with you noobs !!
    • Deathhunter's Gadgets
      • Asus SABERTOOTH P67 TUF B3
      • Intel Ci5 2500k
      • 4x4=16GB G.Skill RipjawsX(2000Bus)
      • WD 500GB HDD+OCZ Vortex 120GB SSD
      • EVGA GTX 465 Unlocked to 470(320Bit 448CUDA Cores)+9800GX2 as Dedicated PhysX Card.570SLI On the Way
      • 19 inch Samsung,40inch Vierra
      • Asus ROG 24bit True pitch
      • MicroLab 2:1
      • A4Tech Multimedia A Shape
      • A4Tech Q3
      • Xbox360 white & Xbox 360 wireless black
      • Cooler Master 850watt
      • LiteOn DVD writer+Samsung DVD ROM
      • Upsmon
      • Windows 7 64Bit
      • 7.9,7.9.7.8,7.8,7.8(CPU,RAM,GPU,G.GPU,HDD)
      • I rebuild my RIG in every 6months but m a console freak...March 2012 The RIG will be...
      • uMobile 7.6Mbps+DiGi 3.6Mbps
      • 18
    Deathhunter's Avatar
    Jan 2011
    I finished it 3 times n still I Love it....m a big Witcher series fan........
    Asus SABERTOOTH P67 TUF B3/EVGA P67 FTW
    intel Ci5 2500k/intel Ci7 2600k
    Antec H20 kooler/Stock kooler
    EVGA GTX 465 Unlocked to 470 320Bit 448CUDA+OEM 9800GT/HIS 6950[Waiting for EVGA 570SLI]
    4x4=16GB G.Skill RipjawsX 2000Bus RAM with G.Skill kooler/2x4=8GB 1333Bus Team Elite
    CoolerMaster Silent Pro 850watt/CoolerMaste GX Power 750watt.
    Death is the beginning of new Life.....
    • reza123's Gadgets
      • c2d 2.93 GHZ
      • 2 GB
      • samsung 160
      • SYNCMASTER B1930
      • MICROLAB
      • MICRO 650VA
      • XP SP2
    reza123's Avatar
    HABIGANJ
    friends ... iam already succesfull to install this game from that dvd ...i was coppied that dvd to another pc nd after that i install it in my pc..sry for my late ans...thx all
  1. The Witcher 2: Assassins of Kings
    By pollob.codename13 in forum RPG
    Last Post: November 13th, 2014, 23:32
  2. The Witcher
    By CHR.Assassin in forum RPG
    Last Post: October 12th, 2011, 00:12
  3. Need The Witcher - Enhanced Edition or v1.5
    By Leaving BG in forum RPG
    Last Post: August 20th, 2011, 08:22
  4. The Witcher: Enhanced Edition
    Last Post: October 16th, 2008, 11:26
Page generated in 0.28287 seconds with 14 queries.
