Results 1 to 2 of 2
Thread: LED MONITOR with vga cable issues
    • ochin's Gadgets
      • MSI H61
      • intel core i3 2100 3.1ghz
      • 2gb ddr3 1333mhz
      • 500gb
      • sapphire 7850 OC
      • philips 224el2sb 21.5"
      • Thermaltake smart 550w
      • qubee
      • 124kpbs
    Default LED MONITOR with vga cable issues
    I have bought a new Full HD led monitor philips 224el and i have three ports VGA,DVI and HDMI.
    I have been using HDMI cable all these days but recently switched to VGA cable because now the hdmi cable is connected to my xbox 360.I use the same resolution as used in hdmi cable 1360x768 but now in the VGA display objects and things seem bigger??
    and if i change the resolution the text gets blurry.
    i have a not so good ati radeon 2400hd pro graphics card..
    i dont seem to understand the problem................should i get a DVI cable???
    Member Raa's Avatar
    Jul 2011
    Sylhet
    Default Re: LED MONITOR with vga cable issues
    yes maybe dvi will solve it.
  1. Confused.....LED or LCD monitor !
    By Codename-Scorpion in forum Help - PC Buying
    Last Post: April 21st, 2011, 04:27
  2. LCD/LED Monitor Cleaner
    By zaman_177 in forum Miscellaneous Topics
    Last Post: April 21st, 2011, 01:13
  3. 20" LED monitor
    Last Post: November 23rd, 2010, 01:39
  4. PS 3 VGA Cable
    By thekoRngear in forum PlayStation
    Last Post: November 11th, 2009, 21:57
  5. VGA Cable Audio Converter
    By H.O.S in forum XBOX
    Last Post: March 18th, 2009, 12:42
Page generated in 0.14477 seconds with 14 queries.
