Results 1 to 20 of 21
Thread: Weird sounds coming from front panel audio jack
    • areek's Gadgets
      • ASRock Z87 Extreme4
      • Intel Core i5-4670k CPU 3.4GHz
      • G.SKILL Ripjaw DDR3 1600MHz 2x4gb
      • Corsair Force LX 256gb + 500gb WD caviar green + 2TB WD caviar green + Kingston 500gb USB
      • Gigabyte ATI Radeon R9 280X Windforce 3X
      • Dell S2240L
      • Altec Lansing 2.1 speakers|| HIFIMAN HE400
      • Razer Blackwidow Ultimate Dragon Age II edition
      • Logitech G402 on QCK+ NaVi Splash
      • logitech drivefx axial feedback wheel
      • Thermaltake Toughpower gold 750W
      • Asus 24B1ST
      • Samsung ML-1666 laser printer, CanoScan Lide 25
      • yes
      • Windows 7 Ultimate SP1 64-bit
    বাংলাগেমার.কম
    Default Weird sounds coming from front panel audio jack
    After I bought the thermaltake V4 BE casing, everything is fine except one. Whenever I connect my headphone in the front panel audio jack, I hear noises made by the mobo from the headphones. Sometimes its just static, sometimes it is the external HDD running & sometimes I hear myself typing even(clicking noise). I googled for sometimes, found out that this might be an earthing issue. But I opened the case & did not find any earthing between the audio jack & the USP. So, if any of you guys could help, I would be glad
    • akk's Gadgets
      • MSI G 41 P33 Combo
      • Intel Core 2 duo E 8400 3.00GHZ
      • Transcend 4 GB DDR 3 1600BUS
      • WD Caviar Green 2 TB
      • XFX ATI RADEON HD 4650 1GB
      • Samsung 18.5 IN LCD TFT (WIDE)
      • Realtek Built IN
      • 1.Perfect 5.1 +2 Sony Speakers Customized 7.1 & 2.A4 Tech HS -100
      • A4tech AntiRSI Multimedia+Logitech K200
      • A4 Tech+Logitech
      • 2 Dilong PU -305, Dilong 401T & A.tech dual vibe
      • DELL 300Wx2
      • Asus 52x DVD RW multispeed & multilayer compaitable
      • Prolink USB Modem(T&T)
      • apollo 650 VA
      • Windows 7 x64 Ultimate
      • 6.6 out of 7.9
      • Works Fine
      • Royal Green Online
      • ~34 KB
      • ~ 20 KB
    akk's Avatar
    Default Re: Weird sounds coming from front panel audio jack
    In the motherboard make sure that the pins for the front panel audio jacks are placed accroding to the order . U can find the correct order for the 9- pins in the motherboards instruction manual. This will fix the headphone noise problem.To fix the Earthing problem , contact an electrician .It will cost you about tk 250 for making a earthing connection from the main line . After that there will be no shock problem.
    • areek's Gadgets
      • Dell S2240L
      • Asus 24B1ST
      • yes
    বাংলাগেমার.কম
    Quote Originally Posted by akk View Post
    Bro, actually I use an PCIe x1 audio card(X-fi titanium), the front panel jacks are connected to that. check my gadgets & u will know. & I have plugged the cables accordingly(HD audio). Also, my pc does not shock, there is just a issue that I heard that a wire connecting the audio & usb for earthing can cause the problem, that is why I mentioned it.
    try putting a tester & check the earthing..
    • areek's Gadgets
      • Dell S2240L
      • Asus 24B1ST
      • yes
    বাংলাগেমার.কম
    Quote Originally Posted by EyE SpeeD | DeViL View Post
    Noob question but need some directions here.
    • Arif69's Gadgets
      • Gigabyte H61 S2P B3
      • Intel Core i3 2100
      • Dell E1910H 18.5 Wide Lcd
      • VIA HD Audio Codec
      • Lexma LK7550P Slim
      • Logitech B100
      • Generic Usb Joystick
      • ITS 500 Watt
      • Samsung SH-224BB 24X
      • Transcend Jetflash350 16 GB
      • KS
    Quote Originally Posted by areek View Post
    You need a tester - that has earthing resistance, that has the option of showing light when there is earthing.
    Take that tester & hold it on the places where you think there is earthing.If the tester shows light then there is earthing if not then there is no earthing.
    • areek's Gadgets
      • Dell S2240L
      • Asus 24B1ST
      • yes
    বাংলাগেমার.কম
    Quote Originally Posted by Arif69 View Post
    & the interpretation would be??? I actually dont have any idea about earthing & stuff. I saw this(http://forums.bit-tech.net/showthread.php?t=208880) that is why I mentioned it.
    • Arif69's Gadgets
      • Logitech B100
      • ITS 500 Watt
      • KS
    Mentioning @Mazhar @avas911 & @romulus_ut3 to have a look in this problem as am not fully sure about the reason of your problem.
    • avas911's Gadgets
      • Gigabyte GA-EG41MF-US2H
      • Built In Realtek ALC883
      • A4Tech X7 XL-747H 3600 DPI
      • Delta GPS-500AB A 500W
      • Asus 16x IDE DVD R
      • Rahimafrooz 600VA Premium
      • Win7 Ultimate 64Bit
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    please make sure that you connected the front connector properly. also there are 2 types of front panel audio connector
    1. Azailla/HD
    2. AC'97
    Please select the right type of connection. as the other will not work. you may have to set it in the creative manager. i am not sure...as i use builtin card. so i can set this in the bios
    Once more into the fray
    Into the last good fight I’ll ever know
    Live and die on this day
    Live and Die on this day
    • areek's Gadgets
      • Dell S2240L
      • Asus 24B1ST
      • yes
    বাংলাগেমার.কম
    1. Azailla/HD
    2. AC'97
    I use the HD one, it works. AC97 is there also, just not using it,
    • Mazhar's Gadgets
      • ASUS B250 Strix
      • AMD Ryzen 1700X
      • G.Skill 2x8GB DDR4 3200
      • Samsung 850 Pro 1TB
      • Gigabyte 1070Ti
      • Dell U2711
      • ASUS Essence STX II
      • Beyerdynamic Tesla T1
      • G910
      • G502
      • Xbox One Controller
      • Windows 10 Home
      • Aamra
    Mazhar's Avatar
    Problems like this are hard to detect without trial and error. It might be interference, earthing, bad cable, bad connector, driver problem or a hardware problem with the sound card and some other possibilities. If possible, do a quick check on another casing and see if the problem occurs to eliminate one of those causes. If thats not possible, If thats not possible, connect the cable with the motherboard onboard audio and using that rather than the X-Fi, see if that solves it. You can also try going in the motherboard BIOS and enabling spread spectrum for both the CPU and PCI-E.
    Might try reinstalling all drivers as well and downloading the latest from the website. Worth a shot
    well if @areek bro u need to test u can test using my case/sound card as i live near you.I feel its ur chassis or earthing problem...
    • areek's Gadgets
      • Dell S2240L
      • Asus 24B1ST
      • yes
    বাংলাগেমার.কম
    Quote Originally Posted by Mazhar View Post
    I dont have another casing so the 1st method is not possible. Also, onboard audio is also dead, that is why I bought the x-fi. Don't have any idea about enabling spread spectrum. & all my driver's are updated.
    Somewhere I saw that the cable that goes from the front panel to the card can cause the problem if it passes near certain structures. Any ideas?
    ---------- Post added at 19:16 ---------- Previous post was at 19:03 ----------
    One thing I should also mention--I do not hear these sounds whenever something is playing, like a music or a game. Most probably the signals get masked by those loud sounds (or signals)
    try this - Creative console > Mixer > Mute Microphone FP
    • areek's Gadgets
      • Dell S2240L
      • Asus 24B1ST
      • yes
    বাংলাগেমার.কম
    No help
    ---------- Post added at 19:50 ---------- Previous post was at 19:49 ----------
    BTW, thanks for offering such a help. Will think about it.
    Sometimes, problems like these are solved just by reassembling the whole pc from scratch, you could try that, make sure the integrated sound on the motherboard is disabled despite it being dead, and last but not least, try the sound card on a different system, see if it shows the same symptoms if used on a different system, if it does, then you've gotta problem with the sound card, but I highly doubt that's it. And do read through the sound card's manual, if you still have it, specially the part where it says "how to connect the front panel audio" as you might've missed something.. Best of luck.
    • areek's Gadgets
      • Dell S2240L
      • Asus 24B1ST
      • yes
    বাংলাগেমার.কম
    Quote Originally Posted by romulus_ut3 View Post
    It has been resembled twice but no help. Will try to close the integrated sound. Also, currently I dont have an option to try it on a different system. & front panel lagano o thik ase.
    I think its either a casing or a wire related issue, not a software issue.
    Well u can try on mine or avas bhai's system as they are close to u.
    Also try putting the sound card on a diffrent PCI-E Slot.
    • Arif69's Gadgets
      • Logitech B100
      • ITS 500 Watt
      • KS
    Question Re: Weird sounds coming from front panel audio jack
    Problem solved or any solution yet?
    • areek's Gadgets
      • Dell S2240L
      • Asus 24B1ST
      • yes
    বাংলাগেমার.কম
    NHope. No solve yet. Could not give enough time to it. Busy time jasse ashole. If I get time, I will try to do some trial & errors, will think of goin to Rakin's house mayb
  1. Realtek HD Audio 2.62 audio driver
    By Frank3nst3in in forum Software
    Last Post: June 23rd, 2011, 23:30
  2. Realtek HD Audio 2.60 audio driver
    Last Post: May 8th, 2011, 18:45
  3. Front Panel USB 2.0 Port
    By zaman_177 in forum Others PC Hardware
    Last Post: December 26th, 2010, 09:25
  4. 3.5mm audio jack info needed....
    By Aunee in forum Technical Support
    Last Post: September 12th, 2010, 10:11
  5. Replies: 0
    Last Post: November 12th, 2009, 18:05
Page generated in 0.32636 seconds with 14 queries.
