Thread: Hard drive problem
    • Aziz37's Gadgets
      • MSI 760GM-P33
      • AMD Athlon II X4 640 3.0GHz
      • Silicon Power 4GB (2x2GB)
      • Western Digital Caviar Blue 500GB
      • ECS GTX 550Ti
      • Samsung SyncMaster 550s(T) @ 1024x768
      • Speaker: Microlab M-200; Headphone: Cosonic CT-719
      • A4 Tech
      • Value Top
      • Thermaltake TR2 450W
      • ASUS DRW-24B1ST
      • Appollo 800VA
      • Windows 7 Ultimate x86
      • I guess my rig is almost complete! waiting for the monitor! :D
      • 58KB/s approximately
      • no idea
    Chittagong
    Default Hard drive problem
    Hey guys! I recently bought a Samsung 500GB hard drive, but a couple of days back, when i tried turning my pc on, i got the following message: NO BOOTABLE DEVICE FOUND. INSERT A BOOT DEVICE AND PRESS ANY KEY. so i went to my bios and saw that they didn't recognize any hard drives. So i thought that maybe my cables were loose. So i reattached the SATA cables and restarted but got a burnt smell. Scared, i immediately turned the pc off and took it to a shop where they said that my hard drive burned and i need a new 1. So my question is: IS THERE ANY WAY I CAN RECOVER MY DATA? coz there were arnd 200 gigs worth of data.... and which hard drive should i get? western digital or samsung? suggestions pls! thanks!
    • codename5302's Gadgets
      • Gigabyte X99-UD5 Wifi
      • Zotac 980Ti Amp Extreme
      • Fiio Andes E07K
      • Corsair RM850
      • 2 * Prollink 1200VA
      • Windows 7 64Bit
      • It works!!
      • 154
    codename5302's Avatar
    Default Re: Hard drive problem
    i heard there is a shop in idb who is data recovery specialist. try that one. but that will be expensive. samsung just sold it's hard drive business. so better stay away. their hard disks are not bad. i am using two for around two years without problem. but for warranty matter stay away from samsung.
    Member Raa's Avatar
    Jul 2011
    Sylhet
    you dont need to get it to any shop.
    follow my steps
    1st find a friend who has a pc (running pc)
    then download seagate file recovary software
    then install the soft on your frnd pc
    now shut the pc down
    connect your hdd on ur frnds pc. (dont remove your frnds hdd just add ur one)
    then run the soft and read the try to to do the next part by ur shelf ))
    Quote Originally Posted by Raa View Post
    you dont need to get it to any shop. follow my steps1st find a friend who has a pc (running pc)then download seagate file recovary softwarethen install the soft on your frnd pcnow shut the pc downconnect your hdd on ur frnds pc. (dont remove your frnds hdd just add ur one)then run the soft and read the try to to do the next part by ur shelf ))
    je hdd mobo detect kortese na, seita theke software diye data recover korbe kemne? Felling sorry 4 the thread opener. But u may give a try. New hdd kenar bapare, well WD are expensive, get a hitachi 1tb.
  1. Is Hard Drive Mounting Bracket Available?
    By xebecs in forum Others PC Hardware
    Last Post: May 31st, 2011, 14:51
  2. How to use two hard drive on a motherboard?
    By superhuman in forum Technical Support
    Last Post: February 9th, 2011, 13:36
  3. Sale (Used) pc without hard drive for sell
    By CHR.XR in forum Shop - Gadgets
    Last Post: October 27th, 2010, 00:31
  4. Problem with New HARD DRIVE.....
    By zaman_177 in forum Technical Support
    Last Post: September 6th, 2010, 21:07
  5. Problem with my new hard drive,,,
    By zaman_177 in forum Others PC Hardware
    Last Post: July 17th, 2010, 11:06
Page generated in 0.16656 seconds with 14 queries.
