Thread: power supply amperage
    • Raziel's Gadgets
      • Asus P8Z77 - V
      • Intel Core i5 2500K @4.2GHz
      • Sapphire Vapor-X HD 7970
      • Asus MS228H 21.5''
      • Realtec HD Audio
      • Microlab Solo 7c
      • Logitech K220
      • X7 XL-747
      • Logitech F510
      • TT Toughpower 750watt
      • 2 GB + 8 GB
      • Micro 1000v
      • Link 3 1MB NDP
      • 100/200
      • 1.2 Mbps
    Raziel's Avatar
    Dhanmondi, Dhaka
    Default power supply amperage
    I've a TT litepower 500 Psu of 400w. So how could i measure how much amp my psu can draw? is it only 12 volt rails or including 5v and 3.3v. here's whats written; MAX 5v-28amp, 3.3v-25amp 12v1-14amp, 12v2-15amp.
      • GIGABYTE B75M-D3H rev1.1
      • A4Tech KRS-86
      • Thermaltake azureus
      • Antec VP450P
      • Samsung DVD RW+Asus CD RW
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    Default Re: power supply amperage
    Quote Originally Posted by bambambad View Post
    The most important voltage rail in a power supply is the +12V rail. This voltage rail supplies power to the most demanding components including the processor, drives, cooling fans and graphics cards. All of these items draw a lot of current...+3.3/5v rails are not that important in real life...even generic psu's have decent +5v/3.3v rails...so u have to measure the total amp from 12v rail only.....
    and about your lite power.....is it w0316 then its combined amperage from +12v rail is just around 23A (which is too low to handle a decent gpu) although it is marked as 29A!!!...
    • Raziel's Gadgets
      • Asus P8Z77 - V
      • Realtec HD Audio
      • Microlab Solo 7c
      • Logitech K220
      • X7 XL-747
      • Logitech F510
      • 2 GB + 8 GB
      • Micro 1000v
      • Link 3 1MB NDP
      • 100/200
      • 1.2 Mbps
    Raziel's Avatar
    Dhanmondi, Dhaka
    dude.... aita kena uchit hoy nai. kenar somoy psu ar morjada bujhi nai, i need a good psu, kintu budget low. i've seen one on Fortex 600W 2nd hand. any review bout it???
  1. Replies: 21
  2. Best Power Supply
    By EBL.Mantis in forum Others PC Hardware
    Last Post: January 9th, 2011, 01:14
  3. Suggestion for a Power supply.
    By acE.Shanny in forum Technical Support
    Last Post: July 26th, 2010, 20:17
  4. Power supply
    By sameev29 in forum Others PC Hardware
    Last Post: May 28th, 2010, 00:23
Page generated in 0.15888 seconds with 15 queries.
