Thread: How to play Guitar Hero 3 Aerosmith (PC Versions) with xbox 360 Guitar Controller
    Member xhossain22l's Avatar
    Apr 2009
    Mirpur-12, Dhaka, bangladesh
    Lightbulb How to play Guitar Hero 3 Aerosmith (PC Versions) with xbox 360 Guitar Controller
    Hello shobaike
    I love guitar hero and I want to play it in my PC. So I started my home work and now that’s what I get.
    How to play Guitar Hero 3 Aerosmith ( PC Versions ) with Xbox 360 Rock Band Guitar Controller
    Hardware and Software I used:
    • Guitar Hero 3 Aerosmith (PC version): From IDB Bhaban. Price 90tk or less. You can also download it from internet. Guitar Hero 3 Legends of Rock (PC version) also works fine.
    • Xbox 360 Rockband Guitar:I bought from Boshundhora City for 5700tk. They ask for 7000tk. The actual price is something like 20$.
    • Xpadder 5.3 (Free version ):Download it from internet. Xpadder5.3 worked nicely with my Windows XP SP3. I didn’t test it in Vista or Windows 7.
    After installing the game please confirm that you can play GH:A with your Keyboard. Exit the game and follow the instructions.
    Step 1: Installing the Guitar Controller
    Connect your guitar to PC USB port. If you are using windows XP SP3 then you’ll have no trouble. WinXP will automatically detect your Guitar Controller as Harmonix Guitar for Xbox 360. For testing go to
    Start> Setting >Control panel>Game Controllers>Test. While you are testing you may notice that the Guitar controller
    Buttons are like
    Green – Button1
    Red – Button2
    Yellow – Button4*
    Blue – Button3*
    Orange – Button5
    *We’ll fix this later with Xpadder
    Step 2: Guitar Hero Aerosmith Keyboard Setting
    Run the game. Wait For loading, Press Keyboard Enter. Remember Don’t Press any buttons on Guitar Controller*. Go to Option>Controllers>Config Keyboard. Change the setting as shown. This configuration will allow you to play more effectively. Now Exit the game using Esc. In next step we’ll use these Keyboard keys in Xpadder.
    *If you press any button from the guitar, the game will recognize the Guitar as your Player 1 Controller and guitar will become the default controller instead of Keyboard. We cannot let it happen. So keep your fingers off the guitar.
    Step 3: Xpadder Settings: Run Expadder. Click the joy-pad icon on the left top of the Xpadder window and then select settings. Controller Setting Window will appear.
    D Pad:
    Select D pad tab at the bottom of the Controller Setting Window. Enable D pad check-box. Now use your
    guitar. Strum up ->UP
    Strum Down ->Down
    D pad Left->Left
    D pad Right->Right
    Buttons:
    Now its time for frets buttons. Select Buttons tab just next to D pad tab on the Xpadder Controller Settings. Now use your guitar. Press Frets according to the following sequence.
    Green Fret (Button 1)
    Red Fret (Button 2)
    Blue Fret (Button 4)*
    Yellow Fret (Button 3)*
    Orange Fret (Button 5)
    *The sequence is important to swap the 3rd button with the 4th . Now map Start and Back Buttons in the same way.
    Whammy Bar:
    go to sticks tab in the Xpadder. Enable Stick1 But don’t map it. We need Stick2 not Stick1. Click Stick 2 sub tab. Map the buttons as follows
    Pull Whammy bar closer to the guitar ------------------------------> Left (Whammy)
    Release Whammy bar (its always pressed by default)----------> Right
    Tilt the guitar*-----------------------------------------------------------> Up (Star Power Release)
    *Guitar has a motion sensor inside. It works like a POV (Y-Rotation).
    Go to Finish tab>Close.
    Assign Keyboard's Keys:By now you can see all the buttons you mapped in the XPadder main window. All you need to do is click on each button and assign corresponding Guitar Hero Aerosmith keyboard button for them. Its very easy and quick. Now save your Profile and setting. Minimize the XPadder. We’ll need to use xpadder running for the emulation.
    5. Run Guitar Hero: A. Wait for loading and don’t press any button from guitar. Use Keyboard to go to main menu and select quick play. Select your difficulty and press enter. From now on you can use guitar to play the game. Have fun
    (Please let me know if it helps. Any suggestion is appreciated. My next target is GHA Multiplayer. ......Guitar vs Keyboard. )
    [ I'm here to kill not to give hope ]
    Default Re: How to play Guitar Hero 3 Aerosmith (PC Versions) with xbox 360 Guitar Controller
    Gha has a pc version?is it playable via keyboard and mouse?
    • HolySlayer's Gadgets
      • Asus B85 Pro Gamer
      • Intel i5 4570
      • 12GB DDR3
      • 320GB + 250GB SSD
      • NVIDIA GEFORCE 660Ti ASUS DirectCUII 2GB
      • Builtin High Definition Audio with SPDIF Output
      • Microlab 5.1
      • A4 Tech Bloody
      • Almost kono naam nai
      • Xbox360,CreativeCOBRA2
      • Thermaltake LightPower Key 3
      • ASUS 52x CD-ROM Drive (Baki shob noshto)
      • Apollo 800 VA
      • Windows Score 7.3
      • Its okay
      • 160
    HolySlayer's Avatar
    Dacca
    Quote Originally Posted by shreshto View Post
    yes.. lol.. it was in torrentbd not long ago... cud still be there..
    • OoAIDoO's Gadgets
      • Gigabyte GA-Z68A-D3-B3
      • Kingston HyperX 2 x 2 GB 1600 MHz
      • Corsair F60 + Samsung 1TB + 1.5TB
      • Gigabyte HD 5670 GDDR5
      • Fujitsu 24 inch TFT LCD
      • Creative Sound Blaster X-Fi Titanium
      • Shure SRH440 Professional Studio Headphone
      • Logitech G110
      • A4 Tech X7 XL-747H
      • PS3 DS3 Controller :P
      • XFX Core Edition PRO550W
      • ASUS DVD-ROM
      • iPod Touch 4G + StoreJet 25D3 USB3 500GB
      • Micro 1000VA
      • IS Pros
      • 256 kbps or 32 KB
      • 256 kbps or 32 KB
    OoAIDoO's Avatar
    Azimpur Dhaka
    xhossain22l thankyou for sharing this with us
    Apr 2009
    ami ai game e bangla gan dhukate chai. can any1 help?
  1. Replies: 1
    Last Post: June 21st, 2011, 23:41
  2. Guitar hero super bundle
    By Shade101 in forum PlayStation
    Last Post: November 3rd, 2010, 00:34
  3. Guitar Hero PS3
    Last Post: September 29th, 2009, 18:17
  4. WCG Asia Guitar Hero
    By Annihilator in forum World Cyber Games
    Last Post: June 18th, 2009, 04:26
  5. Guitar hero with real guitar?? | "Guitar Rising" - new game.
    By xK::CREATOR in forum General Discussion
    Last Post: September 20th, 2008, 00:31
Page generated in 0.19631 seconds with 14 queries.
