Thread: PSU only has single 4 pin CPU power connector.......
    Default PSU only has single 4 pin CPU power connector.......
    I have to run an Asus Sabertooth Z77 + intel Core i5 2500K setup with my Thermaltake TR2-420 PSU, maybe for 2-3 months before I can get e new PSU for it. But the problem is, the motherboard's 12v CPU power connector is 8-pin, but the PSU only has one 4-pin 12v CPU power connector.
    Motherboard's manual has this picture at the CPU power connection section:
    Will it be safe to use the middle option, connecting the 4pin connector on one side of the 8pin socket, for the i5 2500K running at stock speeds? Or would I need a converter like this?:
    Are these converters even available at BD? If yes where can I find them?
    • Sybaris Caesar's Gadgets
      • Intel DH61WW B3 Rev.
      • Intel Core i5 2400 3.10 Ghz
      • Thermaltake Commander
      • Logitech G402
      • Original Xbox 360 Wireless
      • Cooler Master G550M
    Sybaris Caesar's Avatar
    Nowy Warsaw
    I think only 4-pin's enough. AFAIK the extra pins are for giving the extra oomph overclocking needs. But not highly suggested IMO.
    Quote Originally Posted by Sybaris Caesar View Post
    there are some Badass mobos which won't even let you turn on the system if the 8pin EPS is not connected, i mean only ATX wont be enough for them.
    so nupe 4 pin is not enough.
    • Ra's al Ghul's Gadgets
      • Gigabyte MA78LMT
      • AMD FX4300
      • 4GB DDR3 1600Mhz
      • 160GB Samsung + 500GB Toshiba
      • Sapphire R7 250
      • Samsung 920NW
      • Creative Audigy 4
      • F&D 5.1
      • A4Tech regular
      • DiLong Gamepad
      • Thermaltake Smart 530W
      • Asus 16X DVD Rom + Samsung DVD Burner
      • Windows 7 64bit
      • 42-90
      • 24
    Ra's al Ghul's Avatar
    Jan 2010
    Will run if you leave everything at factory settings.
    • Trave160's Gadgets
      • MSI B350M Mortar AM4
      • AMD Ryzen 5 1600
      • 16GB DDR4 3000Mhz
      • 3TB Western Digital red
      • ASUS Strix GTX 960 4G
      • Dell S2216H 22 Inch monitor
      • Logitech Speaker
      • TtEsports Knucker
      • PS4 Dualshock 4 controller
      • Pendrive 4GB
      • NunuCom Ltd, Penus group
      • Super San 200kbps
      • 105*2
    Trave160's Avatar
    A Secure Area
    Lol I had to plug 2x4-pins for an AMD FX processor on a 970 board
    Haven't got the motherboard yet, so can't test if it boots up. But in any case I guess getting a ATX to EPS converter/adapter would be my best bet until I change the PSU.
    Can anyone tell me if the adapter on the second pic is available anywhere?
    • _batman's Gadgets
      • msi Z87-GD65 inside Corsair Carbide 300R Windowed Edition
      • Intel Core i5 Devil's Canyon with CM Hyper 212X
      • G.Skill TridentX 8GB DDR3
      • Transcend SSD720, WDC20EZRX, WDC 10EZEX, WDC 5000AAKX
      • msi gaming x rx480
      • Viewsonic VX2270S 21.5'' IPS LED + Philips
      • Realtek ALC 1150 with Creative SBC
      • Piston 3 (Dead), Iron Ring Pro, Iron Ring HD
      • Logitech K120, Blackwidow X Chroma
      • Bloody A6, Logitech M557
      • Xbox 360 (Dead)
      • CM V650 Semi-Modular (80+ gold, active PFC)
      • Asus
      • WD My Passport, My Passport Ultra
      • Powerguard 1200 volt-ampere simulated sinewave
      • Win 7 Ultimate 64-bit / Windows 10
      • So... many... X
      • ~500KBps
      • 1/2 of download
    _batman's Avatar
    Jun 2013
    I used to come across this in places like tom's hardware, though that was a long time ago. From what I read intel mainboards ran just fine with 4-pin connectors.
  1. Want to Buy 8 Pin PCI-e connector to 6+2 or 6 Pin PCI-e connector adapter
    By emroz_2272 in forum Shop - Gadgets
    Last Post: February 1st, 2015, 17:23
  2. Replies: 2
    Last Post: November 22nd, 2014, 20:33
  3. FIRE !!!! Molex power connector caught fire !!!
    By Rawkill in forum Technical Support
    Last Post: July 22nd, 2013, 23:11
  4. Single Rail Power Supply-- Why it is BETTER.....
    By VANGUARD in forum Others PC Hardware
    Last Post: September 9th, 2012, 15:01
  5. Sale (Used) Tansnet Casing with 430watt Thermaltek Lite power Power Supply
Page generated in 0.19561 seconds with 15 queries.
