Results 1 to 20 of 28
Thread: Case Temperature Help!
    Default Case Temperature Help!
    I cant believe I'm opening such a thread, but I do need help with my case & the temperatures! ;D
    The thing is I couldn't play a single game during my vacation, but now that I've got the chance...the temperatures seem to be worrying!
    My CPU peaks at 60-65C & as for the GPU it goes to 65-70C, now the numbers are perfectly fine, but I feel my case is burning & I can literally feel those heat waves! What I suspect is that, the GTX460 is dumping all that heat into the casing which heats it up! This does not happen when I play CSS, since it's an CPU intensive game! But when playing AC:II/Witcher2/AC:B/DiRT3- this becomes an issue!
    Oh I've clocked my X4 955 to a 3.6GHz & the HT & NB are at 2400 respectively, I've CoolnQuiet enabled, so the machine cools down quick after exiting the game! The GPU is at stock, though it's an OC edition card!
    As for the case description, it's ThermalTake Dokker, nothing impressive here really...it only came with a single 120mm exhaust & spins at a max 1000/1200RPM, I've installed a front intake, it's a 120mm blue LED fan which I ripped of a Space casing!
    I need to know, if changing the front intake to a powerful one could at least shove that heat out of the casing in a timely manner ? Or should I install two side fans ? The Dokker can accomodate *1front intake, *1 back exhaust, *2side fans beside the GPU, *1 fan in the bottom in front of the PSU & *2 fans in the top (1 120 & 1 200mm)!
    I'll post some pictures later, & I can only spend 1K to get those new fans, Help me out guys!
    • Dee's Gadgets
      • Asus Maximus VIII Ranger
      • Intel Core i5 6600k
      • Dell S2216H
      • Cooler Master V650 Gold
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    Default Re: Case Temperature Help!
    Install a fan on the side panel, and see the differences.
    Quote Originally Posted by Dee View Post
    ehkon cls theke giye, IDB or multiplan jete pari, dekhi koeta fan kina jay xD
    • Camouflage's Gadgets
      • Gigabyte Sniper B5 B85
      • Core i5-4460 3.2Ghz with Deepcool Mini Cooler in Thermaltake 'Versa-2'' Case
      • Corsair Vengeance DDR3 1600Mhz 2*4gb
      • WD Blue 1TB 7200rpm
      • MSI Gtx770
      • Samsung 22'' Wide Screen LED-1920*1080
      • Creative Sound blaster Audigy 2ZS
      • Microlab 5:1
      • HP keyboard
      • A4Tech X7 XL-747H Spider
      • Corsair-HX650W-52A in single 12V Rail with 4 (6+2) pin connectors
      • HP DVD writer
      • Transcend Jetflash-16gb & Sandisk Cruzer 4gb
      • Apollo 1200VA
      • Windows-7-64 bit Ultimate Edition
      • Pro-7.6,GPU-7.9-Windows7 benchmark
      • Satisfied what i have
      • Dhakanet,1mbps
      • 128 kbps
    Camouflage's Avatar
    Ofcourse go for thunderblade.u cant regret.But there is no 200mm thunderblade there in bd.U have to buy a chinese 1.
    • eXsTatik's Gadgets
      • Msi 990FXA GD80
      • Phenom x6 1090T @ 4ghz 24/7
      • 8gb drr3 1600mhz
      • 500GB x2 raid 0 + 1TB caviar black + 500GB wd passport.
      • GTX 580
      • Syncmaster 2243
      • X-fi titanium
      • 2x microlab solo 7c front and back, 2 x microlab FC subs + pro 1 as center
      • Razer blackwidow
      • Razer imperator/deathadder/a4tech x7/razer boomslang 2007CE/ Razer Abyssus
      • xbox 360
      • 850 Toughpower Thermaltake
      • Glasses.
      • Generator that runs on oil downstairs with 24/7 backup
      • Windows7 64 I still dont really care.
      • Yes if you are wondering I am AMD fanboyish :/. LOL
      • link 3
      • 142
    eXsTatik's Avatar
    Beyond reality
    The air being sucked out needs to be more than the intake. I dont however recommend side panel fans though, dont really know how they fare but to me they mess up the overall air flow in the case. Try keep the air path simple as possible, making things complicated may ruin air flow thus increasing overall temps
    FTW!!!!!!!!!!
    Lightbulb Re: Case Temperature Help!
    +1 and thanks to Dee, thik 1ee kotha boltey chaitesilam ami, u can see the difference by installing a 120mm thunderblade in side cover as intake just beside ur gpu...one thing i wanna add that u need at least 3 efficient fans for proper thermal temp. even in this hot summer...
    i have A60 chassis with 4 fans and yes i did see the difference when i remove the side intake thunderblade for using it in rear of the chassis to help my frio to exhaust the processor heat,
    the difference i've seen is-
    GPu temp with side 120mm intake- idle 32c and full load(several hours of witcher 2) 64c
    GPu temp without side 120mm intake- idle 36-38c and full load(several hours of witcher 2) 68c
    so i also need another 120mm intake for cooldown the gpu..
    btw amio jachhi ucc within an hour to buy a thunderblade....and of course the red one
    • @bhi's Gadgets
      • Gigabyte Z87X-UD3H
      • Samsung 30nm 2x4GB
      • Gigabyte HD7950 3GB WF3
      • Samsung 20" LED BX-2035
      • Creative SoundBlaster Z
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Seasonic X-650 km3 80+ Gold
      • Luminous Solo 1200 VA
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    Quote Originally Posted by musvi View Post
    thunderblade er price koto?? kono link ase??
    • Dee's Gadgets
      • Dell S2216H
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    Actually I don't have any fan installed on the side panel, so can't tell the differences. My GPU idles at 40C, and at load it reaches 75C.
    • SinisterFahim's Gadgets
      • Gigabyte GA-945GCMX-S2
      • Core 2 Duo E4500
      • Twinmos 1GB + 2GB = 3GB DDR2 (800 Mhz)
      • Hitachi 1TB
      • ATi Radeon X1050
      • Asus MS228H
      • On-Board......
      • Creative Inspire M4500. (Going To Get A Microlab SOLO 7C ASAP)
      • A4 Tech Basic Keyboard
      • Genius 120 NetScroll
      • Don't Have One For PC Gaming..........
      • Generic 440W.....
      • Lite-On 16X Combo & ASUS 24X Dual Layer DVD-RW
      • Transcend 25M2 500GB External HardDrive ll Apacer 8GB AH324 ll Apacer 8GB AH332 ll Transcend V30 8GB
      • Mercury 1200VA
      • Windows 7 (62-Bit)
      • Sucks, I Know........!!!!
      • Banglalion WiMax
      • 512kbps OR 64KB/s
      • 128kbps Or 16KB/s
    SinisterFahim's Avatar
    Home........
    Bro...install the most no.(4) of 120mm u can.....bcoz without them the dokker has like very little cooling.....
    • Dee's Gadgets
      • Dell S2216H
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    Quote Originally Posted by SinisterFahim View Post
    You can install more than 4 fans, 6 iirc, in the Dokker.
      • Core 2 Duo E4500
      • Hitachi 1TB
      • ATi Radeon X1050
      • Asus MS228H
      • On-Board......
      • Generic 440W.....
      • Mercury 1200VA
      • Banglalion WiMax
      • 512kbps OR 64KB/s
      • 128kbps Or 16KB/s
    Home........
    Quote Originally Posted by abhi4168 View Post
    120mm thunderblades are 600tk at UCC.........kono link nai....
    ---------- Post added at 17:38 ---------- Previous post was at 17:26 ----------
    the other 2 are 200mm and 80mm....which are not available in bd(not sure tho).......
    • Dee's Gadgets
      • Dell S2216H
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    - Front (intake): Optional
    120 x 120 x 25 mm Fan X 1
    - Rear (exhaust):
    120 x 120 x 25 mm Blue LED fan (1300 rpm, 17 dBA)
    - Top (exhaust): Optional
    200 x 200 x 20 mm / 120 x 120 x 25 mm
    -Side (intake): Optional
    120 x 120 x 25 mm fan
    - Bottom (intake): Optional
    120 x 20 x 25 mm / 80 x 80 x 25
    You can install 120mm fan in the 200mm slot too.
    yes!!! I've just installed two 120mm(s), now there are currently 4 fans installed, 1 exhaust, 1 intake, 1 top-exhaust, & a GPU side exhaust! I'll report of the temps at night! Thanks everyone
    • pcgamer's Gadgets
      • Gigabyte GA-Z87-HD3
      • i5 4670k
      • CORSAIR Vengeance 4 GB*2=8 GB DDR3 1600
      • Samsung 850 EVO 250GB, 1 TB WD Blue
      • ASUS ROG STRIX Radeon Rx 480 8GB OC
      • Samsung BX2035 LED LCD 20 inch
      • Onbord
      • Creative Labs Inspire 4400 4.1
      • A4TECH Multimedia
      • A4TECH
      • Asus U-75 HA 750 Watt
      • Asus DVD Writer
      • 1200 va (Battery-2x12volt 7.2 amp)
      • Windows 7 64-bit
      • Need to Update GPU
      • 100 KBps
      • 100 KBps
    pcgamer's Avatar
    Dhaka, Bangladesh, Bangladesh
    How much you pay for your 120mm per piece? And mention other fans price which are you bought today.
    Quote Originally Posted by pcgamer View Post
    well ami just normal duita 120mm kintam, but kichu tk paise pore, tai 2ta blue thunderblade kinsi But I saw some other fans, MAN they are so POWERFUL compared to these thunderblades, I mean oita'r jonno pura ekta adapter lage & it is noisy as ¤¤¤¤! oigula pore ekta kinbo
    yeeeey, just did IBT for 5mins, CPU temps dont cross 62C at 3.6GHz, GPU stress kore dekhbo pore ki obostha...ekhon porte boste hobe
    • @bhi's Gadgets
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    Where did u saw those other fans?? need details pls??
    IDB'r 3rd floor e kon ekta shop e jani dekhlam, shope name ta mone portese na
    I guess oita PC'r jonno na, cuz it's definitely bigger & thicker than the regular 120mm we see!
    • faisal.amir.bd's Gadgets
      • ABIT IP35 Dark Raider
      • Intel Core 2 Duo [email protected]
      • 2GB Transcend AxeRam DDR-2 800+ @816MHz
      • 820GB (320GB Hitachi, 500GB Samsung)
      • Gigabyte Radeon HD5770 1GB DDR5 (Batmobile Cooler)
      • ASUS MS228H 1080p LED backlit
      • Creative Sound Blaster Live! 5.1
      • Creative Inspire 5200 (5.1)
      • XBOX 360 wired gamepad
      • Thermaltake TR2 600W
      • Rahim Afrooz 1000VA
      • Windows 7x86
      • 180kBps [1.5Mbps]
      • 180kBps [1.5Mbps]
    faisal.amir.bd's Avatar
    Atlanta
    I think what you saw were server fans. They are way too noisy and would totally ruin your gaming. Sometimes it actually sounds like a siren.
    ami gpu'r side e(side cover of casing) intake hishebe use kortesi(in accordence to the spec of the thermaltake)
    @dipanzan u may also try to use the side cover fan as intake and i think u may get better result with it...
    please see this-
    Attachment 10417
    as u can see top and rear is exhaust and side front and bottom is for intake in accordance to Thermaltake website, practically processor hoilo onno shob hw theke beshi gorom hoi, as its located in top, oitakey sarround kore shob guloi exhaust deya, and interestingly nich er 3ta intake oneek air tene bhitorey dhukai and oi air gulokey(with other hw's hot air) uporer 3ta exhaust bairey ber kore dei, in result fantastic airflow!!! i guess eibhabe plan korei mone hoi TT oder chassis gulo design korcey...
    i think this is the optimum setup for better thermal temperature..
    @abhi4168
    hope u get ur answer..
  1. HDD Temperature Reduction
    By Dee in forum Hardware Modding
    Last Post: August 16th, 2011, 04:59
  2. cpu temperature problem
    By Swapan Roy in forum CPU
    Last Post: March 5th, 2011, 17:45
  3. CPU Temperature Measurement
    By gamefreak in forum Technical Support
    Last Post: January 27th, 2011, 01:06
  4. CPU Over temperature!
    By Dee in forum CPU
    Last Post: October 22nd, 2010, 00:06
  5. E5200 temperature problem
    By shahriar in forum CPU
    Last Post: June 8th, 2009, 12:00
Page generated in 0.32405 seconds with 14 queries.
