Results 1 to 10 of 10
Thread: Need help : How to Flash GPU Bios (250 GTS OC )
    • Kruger's Gadgets
      • Gigabyte X58A UD7 REV 2, 3 way SLI Silent heat pipe II
      • Intel Core i7 930 at 4.1 ghz OCed with THERMALTAKE FRIO OCK
      • Adata XPG 6 GB DDR3 @ 1600 mhz cl 7
      • Western Digital CAVIAR BLUE 6.0 gb/s 7200 rpm SATAIII 500gb
      • ASUS GTX 570
      • Dell P2211H 21.5" HD LED Monitor
      • Realtek Dolby Prologic II HD Sound Card (Azalia)
      • Creative 4.1
      • Thermaltake Challenger Pro
      • Cyborg R.A.T. 3 on Razer Vespula (Hard) Pad
      • Adata HM-750 watt , SLI and 80+ Bronze 60A On 12 V rail
      • Sony 24x DVD-R/RW
      • Bluetooth 2.0 A2dp Room
      • 1200 VA iNeat Just for the CPU
      • Windows 7 64bit Ultimate Housed in Thermaltake SPEDO ADVANCED
      • 7.8 CPU, 7.9 Memory,7.9 Aero,7.9 Gaming
      • Worked hard to earn it , i paid for these stuff , so the satisfaction lvl is up there :D
      • Bangla Lion 512kbps Unlimited
      • 63+
      • 20kbps
    Kruger's Avatar
    Dhaka,Town : Uttara
    Default Need help : How to Flash GPU Bios (250 GTS OC )
    Guys I have 2x 250 GTS and i know these are obsolete Cards , i am planning to get new Cards soon but , i want these cards to go all out on Crisis 2 before i sell them , NO I do not wanna use Riva tuner i want a More Permanent Solution , so i heard we can Flash GPU Bios with nvflash and nibitor so how do i use it
    i want to
    My Gigabyte N250Gts OC has the Perfect Clock speeds
    But my Ecs 250 Gts has -40 mhzn on Core Speed and some other stuff
    so , can i put my Gigabyte GPU Bios on my ECS one ? i heard its possible , can any one tell me how ? Please and I also want to Learn this ty
    Hell hath no fury like Kruger Hawke Pissed off
    Default Re: Need help : How to Flash GPU Bios (250 GTS OC )
    Yes u can force flash the gigabyte bios on the ECS card but make sure its fully stable.
    ---------- Post added at 16:27 ---------- Previous post was at 16:25 ----------
    I myself flashed my cards to ASUS TOP (100MHz overclocked) bios.....
    Bad advice Rakin! Don't directly flash another manufacturer's bios on to your card unless you're really sure that both of the cards use the same brand of memory and timings! You can use nbitor, read the bios of your ECS GTS250 and flash bios with modded clocks..
    See here on bios flashing:
    http://banglagamer.com/forums/showth...962#post267962
    Instead of changing sub vendor id change your default high performance 3D Clock for your card and save the edited bios and you're good to go. And also, don't forget to specify which card you're flashing as you've two of them, better if you remove the Gigabyte one while flashing if you don't wanna take risks.
    Quote Originally Posted by romulus_ut3 View Post
    http://banglagamer.com/forums/showthread.php?13584-Exclusive-nvidia-overlocking-gear-plus-a-nifty-tutorial!&p=267962#post267962
    well i advised him that bcoz it would be less hassle for him. But editing the original bios is the safest way anyway....
    ECS products are mostly cost effective, and when products are cost effective, they usually tend to go for components that're of good quality but not too pricey so they can lower their own production costs, so I wouldn't be surprised if the memory modules used on the ECS card is different from the Gigabyte one, and the memory timings could also be different, which might render the ECS card useless when flashed with the Gigabyte bios, actually it's a 50/50 shot with the Gigabyte bios, it might work, it might not, the reason why you were able to flash with Asus's TOP profile bioses is because the manufacturer is the same, hence the memory modules, timing/PCB etc. were same, so you can make a jump from one model to another, I'm very resource limited see if you can help the guy out with pics of what he needs to change from nibitor and make a tutorial with mine as reference and make a copy/paste job and we'll vote for it to be stickied
    I'm too lazy to post a tutorial. pls do it for me..
    • Kruger's Gadgets
      • ASUS GTX 570
      • Creative 4.1
      • Sony 24x DVD-R/RW
      • 63+
      • 20kbps
    Kruger's Avatar
    Dhaka,Town : Uttara
    if u let me i could even come to ur place for Tutorial i can Bring my cards , Please I realy want to LEARN this , could u please help me ty,
    Quote Originally Posted by Kruger View Post
    it'll be better if u call me up, or if u want to come down to my place then u have to travel all the way to mohammadpur.
    my cell no 01675464860/01741124890
    • Kruger's Gadgets
      • ASUS GTX 570
      • Creative 4.1
      • Sony 24x DVD-R/RW
      • 63+
      • 20kbps
    Kruger's Avatar
    Dhaka,Town : Uttara
    Ok bhaya i will call u tonight if u are Free its 4 pm now , ty my no is 01673907444
    I'm free
    anyways dont call me bhaiaya i'm younger than u & infact any1 in bg..
  1. Price of ECS GTS 250
    By Rakin the Devil in forum GPU
    Last Post: February 16th, 2011, 20:35
  2. XFX GTS 250 or the ATI 5770?
    By Eshter in forum GPU
    Last Post: January 5th, 2011, 22:37
  3. facing problems with gts 250...!!!!
    By morshedkhan97 in forum Technical Support
    Last Post: February 27th, 2010, 14:20
  4. Gts 250
    By Dante in forum GPU
    Last Post: August 18th, 2009, 02:00
  5. Nvidia GTS 250 Reviewed.....
    By shaikh_imtiaj in forum GPU
    Last Post: March 3rd, 2009, 23:18
Page generated in 0.22203 seconds with 14 queries.
