Thread: pc isn't starting
    • wasi006's Gadgets
      • Biostar H55 HD
      • Intel core i3 2.93 GHz
      • 2 GB DDR3
      • hitachi 500 GB, WD 500 GB portable
      • ATI Radeon 5670 1 GB GDDR5
      • 17 inch samsung CRT
      • Cosonic CD-720
      • Mercury
      • HP
      • Windows 7
      • Ispros
      • 64 KBPS
    Jan 2010
    Gulshan, Dhaka
    Default pc isn't starting
    when i start the pc, it just hangs in the safe mode, safe mode with networking/command prompt, start windows normally page. B4 that, the pc just hanged and had to restart it. What is the problem. I tried removing the ram and reinstalling it. Help me guyz
    • CODhunter's Gadgets
      • EVGA z370 FTW
      • i7 8700k
      • 16GB G-Skill RGB 3000bus
      • 128GB Corsiar SSD+2TB SSHD+1TB WD
      • EVGA GTX 1070 FTW
      • Samsung 23.6' 4K
      • WV-Klong
      • Razor elite
      • EVGA Supernova 650wat
      • Windows 10 (pirated)
    CODhunter's Avatar
    Nov 2009
    Default Re: pc isn't starting
    set up ur windows, i think it will solve ur problem
    • wasi006's Gadgets
      • Biostar H55 HD
      • 2 GB DDR3
      • Cosonic CD-720
      • Mercury
      • HP
      • Windows 7
      • Ispros
      • 64 KBPS
    Jan 2010
    Gulshan, Dhaka
    arekta jinish kheyal krlam. pc onkkhn off rakhar por charle mtamti ksukhn chole. Tarpor abr hang. And monitor hotath off hoye jai. Windows reinstall dle thik hbe? Amr to mne hoy hardware problem.
    windows install marte geleo hang khay. Arekta bapar. Jkhn pc start hoy tkhn initializing usb controllers, ei jaygateo hang khay. Kahini ksui bujhtesi na. Mobo ta gelo naki?
      • Z68MA-D2H-B3
      • Intel Core i5 2400 3.1GHZ
      • DD3 4gb*2 1333mhz
      • 500gb hitachi,2TB Samsung
      • Sapphire 6950 2gb
      • Benq V2220HP 21.5" LED
      • realtek HD7.1 builtin
      • cosonic 723mv///sony xplode home theater 4000watts B)
      • a4tech
      • A4tech-X6
      • TT 650w
      • Asus 24x Dvdrw
      • Apollo 1200va
      • win 7 64bit
      • AWESOME :D
      • Mango Telecom
      • 32KBPS
      • 30KBPS
    N...B's Avatar
    Dhaka,Bangladesh
    prolly USB controller nosto....if possible try disabling it from ur bios...then try rebooting....gud luck wid that
    • wasi006's Gadgets
      • Biostar H55 HD
      • 2 GB DDR3
      • Cosonic CD-720
      • Mercury
      • HP
      • Windows 7
      • Ispros
      • 64 KBPS
    Jan 2010
    Gulshan, Dhaka
    simple things can make a big difference ....just removed my GPU, cleaned it and re installed it. VOILA
  1. pc not starting
    By LIV Gaming in forum Technical Support
    Last Post: June 12th, 2011, 14:01
  2. Why Half-life 3 Isn't Coming Soon
    By anik_lc in forum News
    Last Post: May 21st, 2011, 12:17
  3. Intel Says PC Gaming Isn't Dying
    By Frank3nst3in in forum Tech News
    Last Post: April 11th, 2011, 21:43
  4. PC Starting Problem
    By shamir in forum Technical Support
    Last Post: July 9th, 2010, 15:10
  5. Forum Slow, isn't it?
    By Hamilton in forum Feedback
    Last Post: November 25th, 2009, 10:54
Page generated in 0.17819 seconds with 14 queries.
