Thread: Monitor buying help
    • Aziz37's Gadgets
      • MSI 760GM-P33
      • AMD Athlon II X4 640 3.0GHz
      • Silicon Power 4GB (2x2GB)
      • Western Digital Caviar Blue 500GB
      • ECS GTX 550Ti
      • Samsung SyncMaster 550s(T) @ 1024x768
      • Speaker: Microlab M-200; Headphone: Cosonic CT-719
      • A4 Tech
      • Value Top
      • Thermaltake TR2 450W
      • ASUS DRW-24B1ST
      • Appollo 800VA
      • Windows 7 Ultimate x86
      • I guess my rig is almost complete! waiting for the monitor! :D
      • 58KB/s approximately
      • no idea
    Chittagong
    Default Monitor buying help
    Hey everyone! I've finally decided to get the ECS GTX 550Ti graphics card because I want to play the recent games and my budget wasn't too high. Plus i had power supply restrictions so I couldn't buy the GTX 460/Radeon 6850, anyway, now I'd like to know which monitor would be best for watching movies and playing games with the 550Ti? i mean i kno that the 550 ti isn't suitable for gaming at 1080p, rite? confused and would like your help!
    Default Re: Monitor buying help
    GTX 550 Ti is okay for 1080p, buy one of the Asus LED monitors and you should be able to enjoy watching movies and playing games.
    • Aziz37's Gadgets
      • MSI 760GM-P33
      • ECS GTX 550Ti
      • A4 Tech
      • Value Top
      • ASUS DRW-24B1ST
      • Appollo 800VA
      • no idea
    Chittagong
    but budget to max 12,000... :/
    Including the money gained from selling off your current monitor?
    Search the forums with "upgrate monitor" exactly as I've written where some of the other members have suggested a fellow member on upgrading monitor, you should be able to choose one within the mentioned models.
    ---------- Post added at 12:45 ---------- Previous post was at 12:39 ----------
    http://banglagamer.com/forums/showth...922#post322922
    • Aziz37's Gadgets
      • MSI 760GM-P33
      • ECS GTX 550Ti
      • A4 Tech
      • Value Top
      • ASUS DRW-24B1ST
      • Appollo 800VA
      • no idea
    Chittagong
    thanks a lot romulus bro!!
  1. Need Help Buying a Multi-Monitor Desktop
    By RON in forum Help - PC Buying
    Last Post: May 21st, 2011, 10:32
  2. Suggestion for Buying LCD/LED Monitor
    By SadIkMahdI in forum Others PC Hardware
    Last Post: December 9th, 2010, 02:09
  3. LCD monitor buying suggestion
    By outragedhuman in forum Others PC Hardware
    Last Post: May 27th, 2010, 08:53
  4. Confused about buying lcd monitor
    By LORÐ in forum Others PC Hardware
    Last Post: March 1st, 2009, 22:08
  5. Buying a 22'/24' inch lcd monitor...
    By hasib981 in forum Technical Support
    Last Post: October 28th, 2008, 19:46
Page generated in 0.17651 seconds with 18 queries.
