i've also googled it, but is it good or bad???
Its not silver, its silicone. Did they say its silver based? Silver isnt necessarily better, but this isnt a high performance silicone based compound, its a basic thermal compound for a vast amount of applications. A 310ml tube (i.e. a freaking Colgate toothpaste) will cost around 700tk here. Talk about ripping customers of.
@bambambad how much is ur CPU temp. with this themal paste ?
Are you in Bangladesh? I thought you're still in Londonmahn life's unfair!
Edit: Do you happen to have a DBBL account? If so, I'd like to buy some thermal stuff from you and I'll pay you by depositing money into your DBBL account, since I don't live in the capital, @avas911 will collect the paste from you, if you do have something that's eligible for sale that is.
The pastes are usually in my house and my brother handles the transactions. Right now I only have the stuff that I mentioned in the last post. Let me know if youre interested, and no I dont have a DBBL account since im not in Dhaka. You can pay avas and he can give it to my brother I guess. Whatever works out for you..
@Sharier if i oc to 3.8Ghz temp still goes crazy. around 90c on 100% load. so i revert back to default, so around 75-80c on 100% load.
@bambambad is 75-80 C typical for a i3. Seems too much.
even my Dual core runs at 64-65C at load.
That's why i need a good cooler and TIM. TIM paisi but cooler paitesi na.
@Dee , frio ucc or pc carnival kothao nai. startec a cooler master 520 ase. tao frio theke price besi chay
@bambambad , foresight er TIM use kore ki idle or load temp drop hoise?
@bambambad BTW oi TIM er quantity diye ki matro ekbar use kora jai. like did to hav any left after applying first time on your CPU?
if you use tiny drop method then there is plenty in it, like 10 or more time. but if you use line method then 2 or 3 times. i used up half of it during line method.![]()
