Results 1 to 2 of 2
Thread: Help, Serious Monitor problems.
    • EaGL1337's Gadgets
      • Gigabyte H55M-S2H in Thermaltake Dokker
      • Intel Core i5 750, 2.66 GHz, 8MB L3 Cache, Quad Core
      • 2x2GB DDR3 1333MHz (Total 4GB)
      • SAMSUNG Spinpoint F3 HD502HJ 500GB
      • XFX AMD Radeon 6950 2 GB GDDR5 @ Stock clocks
      • Samsung 943NWPLUS 19 inch widescreen LCD display
      • Integrated Realtek High Definition Audio System
      • Altech Lansing VS2621 2.1 Speaker System/TT Esports Shock One Gaming Headset
      • A4 Tech multimedia keyboard
      • Razer Taipan 4G
      • Delta 550W
      • Asus DVD writer 24X
      • Windows 7 Ultimate 32 bit
      • After the upgrade, this thing kicks a$$!
      • 64KB before 8PM. 160 KB after 8PM
      • Same as above
    EaGL1337's Avatar
    Default Help, Serious Monitor problems.
    Well my monitor's been turning on and off lately following the "USB Disconnect/Connect" sound. I've double checked my mouse USB and its okay so what IS causing this problem?
    Default Re: Help, Serious Monitor problems.
    Check the connection of your monitor, see if it's plugged in right, doesn't sound like a faulty monitor to me, but hard to tell what exactly the problem is without actually inspecting everything.
  1. Facing problems !!! need help
    By Ic3_STrik3R in forum XBOX
    Last Post: March 7th, 2011, 12:43
  2. FIFA 11 FIFA 11 Problems
    By Overlord in forum FIFA 11
    Last Post: October 19th, 2010, 16:03
  3. game problems
    Last Post: December 3rd, 2009, 12:25
  4. Problems!!
    By Deep -xCross- in forum Technical Support
    Last Post: May 27th, 2008, 11:22
  5. Farming problems
    By kabir_sharif2000 in forum DotA Talk
    Last Post: May 21st, 2008, 13:42
Page generated in 0.14846 seconds with 14 queries.
