Results 1 to 20 of 25
Thread: Generic Gamepad - Right Stick Analog Doesn't Work!
    • Frank3nst3in's Gadgets
      • MSI 760GM-P33
      • AMD Athlon II X4 640
      • Samsung 500GB F3 + Hitachi 160GB + Hitachi 80GB
      • ECS EliteGroup GTX 550Ti
      • Samsung SyncMaster 551s
      • integrated VIA Vinyl HD
      • A4Tech HS-100, Panasonic HTF600, SoundMagic E10
      • Delux
      • A4 Tech MOP-70D
      • Generic USB Gamepad
      • ASUS DVD Rom
      • Banglalion 4G/Wimax, GP 3G/EDGE Modem
      • PROLINK 650Va
      • Windows Seven x64
      • Qubee/Banglalion
      • 64 KBps
    Frank3nst3in's Avatar
    Exclamation Generic Gamepad - Right Stick Analog Doesn't Work!
    I got a generic chainese gamepad and I am facing some problem.
    The right stick doesn't work.It works as A,B,X,Y.Everything else is okay.
    Now I googled about this and found many things about previous FIFA versions and got a few solutions about FIFA11.
    Now in HERE I got this-
    1. open reg-edit.
    * at this moment, i assume that you've already modified all your non-compatible gamepads' names to "Logitech DualAction USB"
    2. click find and type "Logitech DualAction USB" or whatever controller you are using.
    3. you'll find a folder where in there are numerous binary switches. if you didn't find it, click F3 to find the next string.
    4. under that folder are 2 subfolders. axis and buttons.
    5. WE'RE GONNA FOCUS ON THE AXIS folder.
    -> it contains 4 subfolders. one each for the X and Y axis (left analogue). and one each for the right analogue stick(Z axis and Rz axis).
    6. take note of the binary values of the Z axis and the Rz axis. modify them both by using the modify command and "interchanging" their respective values.
    7. go back to your controller options in the control panel and you'll be surprised to see that the right analogue stick has switch its movements...vertical now becomes horizontal....
    8. run FIFA... and it works... wow.... great.
    I understand everything here but number 6.
    How do I modify those data and is it the attributes or the FFatributes??
    If anyone have other pads,please share your Binary Data of the Z axis and Rz Axis.
    And if anyone has other solutions,please share them.
    Your help would be highly appreciated
    • Hamilton's Gadgets
      • Gigabyte B75 D3H
      • Intel Core i5 3460 @3.1Ghz
      • 8GB DDR3 1600hz
      • Samsung 320GB+1TB WD
      • Sapphire HD 7870 2GB GDDR5
      • Asus VS228N 21.5" Full HD.
      • Roccat Arvo
      • Cooler Master GX 650W.
      • 500GB
      • Windows 7/ Linux
      • 3DMARK Score, X2151.
      • ¤¤¤¤¤ please.
      • Smile, BD.COM
      • 75KBPS(Variable)
      • 100+KBPS(Variable)
    Hamilton's Avatar
    Default Re: Generic Gamepad - Right Stick Analog Doesn't Work!
    dunnow.....
      • MSI 760GM-P33
      • Delux
      • A4 Tech MOP-70D
      • ASUS DVD Rom
      • PROLINK 650Va
      • Windows Seven x64
      • Qubee/Banglalion
      • 64 KBps
    I got that URL's trick but it doesn't work
    • LynAs's Gadgets
      • XFX 750i nForce
      • Core 2 QUAD Q8200 2.33GHz
      • 2*2 GB Transcend (800 BUS)
      • Samsung 500 GB
      • Gygabyte GTX 460
      • Samsung 19" LCD
      • MicroLab Speaker and (Cosonic & A4Tech) HP
      • A4tec multimedia
      • Delux M615
      • XBox 360 , Ps2 converted and Sonic IT
      • Thermaltec A2169 550W
      • General 1200W
      • WIN 7 64bit
      • I am happy XD
      • BRACNET
      • 60 (avg)
      • 60 (avg)
    LynAs's Avatar
    Sep 2008
    Coventry, UK
      • MSI 760GM-P33
      • Delux
      • A4 Tech MOP-70D
      • ASUS DVD Rom
      • PROLINK 650Va
      • Windows Seven x64
      • Qubee/Banglalion
      • 64 KBps
    Quote Originally Posted by LynAs View Post
    Does that work??
    What's the soft??Can you gimme a link??
    The main question - Right Stick Analog ki evabe thik hoe??
    • LynAs's Gadgets
      • XFX 750i nForce
      • Samsung 500 GB
      • Gygabyte GTX 460
      • Samsung 19" LCD
      • A4tec multimedia
      • Delux M615
      • General 1200W
      • WIN 7 64bit
      • I am happy XD
      • BRACNET
      • 60 (avg)
      • 60 (avg)
    LynAs's Avatar
    Sep 2008
    Coventry, UK
    i am using this soft. i got 3 gp. 2 of them Chinese and i applied this for those 2 gp and it worked for me.
    http://tinyurl.com/3us22st
      • MSI 760GM-P33
      • Delux
      • A4 Tech MOP-70D
      • ASUS DVD Rom
      • PROLINK 650Va
      • Windows Seven x64
      • Qubee/Banglalion
      • 64 KBps
    no direct DL link??
    What's the name of the emulator??
    • LynAs's Gadgets
      • XFX 750i nForce
      • Samsung 500 GB
      • Gygabyte GTX 460
      • Samsung 19" LCD
      • A4tec multimedia
      • Delux M615
      • General 1200W
      • WIN 7 64bit
      • I am happy XD
      • BRACNET
      • 60 (avg)
      • 60 (avg)
    LynAs's Avatar
    Sep 2008
    Coventry, UK
    no you need to figure that out
    • Dhumketu's Gadgets
      • Gigbyte X58 USB 3.0
      • Intel Core i7 920 Nehalem 2.66GHz L3 8MB cache Quad Core
      • 8 GB DDR 3 1600 MHz
      • WD 500 GB
      • Gigabyte ATI HD 5870 1GB GDDR5 256-bit PCI-eHD 5870
      • SONY Bravia 20" LCD
      • Razer Onza TE
      • Gigabyte 600 Watt
      • HP SATA DVD-Writer
      • Rahimafrooz 1000 VA
      • Windows 7, Ubuntu 10.12
      • 30
    Dhumketu's Avatar
    @Frank3nst3in
    Frankie I think this will help you... you will find further instruction in the read me file.....this is a X 360 controller emulator...
    Attached Files Attached Files
    Most people think time is like a river, that flows swift and sure in one direction. But I have seen the face of time, and I can tell you, they are wrong. Time is an ocean in a storm. You may wonder who I really am, and why I say this. Come, and I will tell you a tale like none you have ever heard.
      • MSI 760GM-P33
      • Delux
      • A4 Tech MOP-70D
      • ASUS DVD Rom
      • PROLINK 650Va
      • Windows Seven x64
      • Qubee/Banglalion
      • 64 KBps
    The damn thing doesn't work...tried for one damn hour :/
    Everything works but the right stick :/
    • Ra's al Ghul's Gadgets
      • MSI P6NGM
      • C2D 2.2GHz
      • 3GB DDR2 @533Mhz
      • 160GB Samsung + 500GB Samsung
      • Gigabyte HD5570
      • Samsung 920NW
      • Creative Audigy 4
      • F&D 5.1
      • A4Tech regular
      • DiLong Gamepad
      • Chinese(non brand) 400W
      • Asus 16X DVD Rom + Sony DVD Burner
      • XP SP2
      • 24/48
      • 24
    Ra's al Ghul's Avatar
    Jan 2010
    Does your controller have a MODE button on it?? Press it and a light goes on. It would be helpful if you uploaded a picture of it here.
      • MSI 760GM-P33
      • Delux
      • A4 Tech MOP-70D
      • ASUS DVD Rom
      • PROLINK 650Va
      • Windows Seven x64
      • Qubee/Banglalion
      • 64 KBps
    Press the 'Analog' or 'Turbo' button located in the middle of the two sticks.it will probably light up and the right stick will work.
      • MSI 760GM-P33
      • Delux
      • A4 Tech MOP-70D
      • ASUS DVD Rom
      • PROLINK 650Va
      • Windows Seven x64
      • Qubee/Banglalion
      • 64 KBps
    Quote Originally Posted by aman@ View Post
    OMG!!!!
    THANKS MAN!!!
    THIS DAMN THING WORKS NOW!!!
    Thanks again
      • WD 500 GB
      • Razer Onza TE
      • Gigabyte 600 Watt
      • 30
    Dhumketu's Avatar
    Quote Originally Posted by frank3nst3in View Post
    omg!!!!
    Thanks man!!!
    This damn thing works now!!!
    Thanks again :d :d
    ধুরো ধইনচা
    • Ratul107's Gadgets
      • gigabyte h61M s2p
      • core i5 2400 3.1 ghz
      • 2x2gb ddr3 1333mhz
      • 1TB
      • msi gtx 560ti 2gb twin frozr edition
      • samsung SA300 20" 1600X900
      • generic
      • generic
      • generic
      • thermaltake smart power 550w
      • 1000va
      • win 7 64 bit ultimate edition
      • Cpu 7.4 gpu 7.8 ram 7.6 hdd 5.9
      • it's a mixed bag ... but gaming performance is satisfactory
      • smile (gold)
      • 1mbps
      • 4.76mbps
    Ratul107's Avatar
    u cud use 360 controller emulator to get 360 degree movement........normally u can go only 45
      • MSI 760GM-P33
      • Delux
      • A4 Tech MOP-70D
      • ASUS DVD Rom
      • PROLINK 650Va
      • Windows Seven x64
      • Qubee/Banglalion
      • 64 KBps
    Quote Originally Posted by Dhumketu View Post
    ধুরো ধইনচা
    Thanks for that I deserve that :L
    Quote Originally Posted by Laaden View Post
    Doesn't work.
    • master_tanjid's Gadgets
      • HP-Intel HM65
      • Intel Core i5 - 2410m @ 2.30GHz
      • 4.00 GB Single-Channel DDR3
      • 640GB Western Digital WDC
      • AMD Radeon HD 6750m 1gb ddr5
      • Generic PnP Monitor (1366x768@60Hz)
      • Altec Lansing
      • HP dvd rom
      • windows 7 premium 64bit
      • Maxis Broadband
      • 500
      • 200
    Sep 2008
    Jalan Gombak, Kuala Lumpur, Malaysia
    Quote Originally Posted by Frank3nst3in View Post
    oi miya ami e to tomare amar oi thread e koisi... press the analog button!!!!!!!! tokhonto shunla na -_-
      • MSI 760GM-P33
      • Delux
      • A4 Tech MOP-70D
      • ASUS DVD Rom
      • PROLINK 650Va
      • Windows Seven x64
      • Qubee/Banglalion
      • 64 KBps
    Quote Originally Posted by master_tanjid View Post
    Ki bolsen bujhi nai
      • HP-Intel HM65
      • Altec Lansing
      • HP dvd rom
      • Maxis Broadband
      • 500
      • 200
    Sep 2008
    amar oi thread e just bolsilam analog button ta tip diba.. tailei thik hoye jabe right stick
  1. Replies: 11
    Last Post: December 13th, 2010, 13:18
  2. USB Stick Pen Drive
    By йЦммєяłą in forum XBOX
    Last Post: October 6th, 2010, 04:02
  3. What the? USB generic virbration Gamepad driver
    By sa_rocky in forum Technical Support
    Last Post: November 9th, 2009, 22:18
  4. Top poster of the month link doesn't work
    By Uchiha Obito in forum Feedback
    Last Post: November 16th, 2008, 22:05
  5. Generic Host Problem
    Last Post: October 30th, 2008, 02:14
Page generated in 1.00516 seconds with 15 queries.
