Thread: Need help in buying Ati radeon 5670 :confused:
    • Mighty Gamer's Gadgets
      • Gigabyte G33M-S2L
      • Intel(R) Pentium(R) Dual CPU E2200 @ 2.20GHz (2 CPUs), ~2.2GHz
      • Twinmos-2048MB RAM
      • WDD-250 GB
      • Gigabyte Radeon Hd 6850 1GB( R685OC-1GD)
      • 17" Philipls Brilliance 170S (Square)
      • Realtek Digital Output (Realtek High Definition Audio)
      • 2:1 Speaker. A4tech Gaming Headset
      • Standard-A4tech
      • Samsung
      • Dilong Dual Shock Gamepad
      • Delta 500W
      • Sony DVD RW+_
      • Power Pac 600MA
      • Windows 7
      • 14880
      • Nothing special but effective on games.
    Mighty Gamer's Avatar
    Khulna
    Smile Need help in buying Ati radeon 5670 :confused:
    One of my friend need to buy Ati radeon 5670 , but i don't know about it's price and performance.
    so, i can't suggest him any other cards. Do anyone know the price and performance of this card?
    Love to play
    • samiulislam16's Gadgets
      • Core i7 860 2.93ghz
      • Sapphire HD7870 ghz dualX
      • Asus 22 inch LED MS228H
      • Realtech Hd 8 channel Audio
      • Creative 2.1
      • Newmen M560
      • Dilong usb controller
      • Samsung DVD writer
      • Sigma 640va
      • Good enough
      • Smile/BDcom
      • 150
      • 200
    samiulislam16's Avatar
    Default Re: Need help in buying Ati radeon 5670 :confused:
    hd 5670 ddr3 is about 6.7k and a good ddr3 type GPU
    if hd 5670 ddr5 is about 8.5k & its the lowest good GDDR5 card
    but whats the budget????? then more precise suggestion can give u
    Guess what??? scan it??:
    Good enough GAMING RIG
    HApPy GAMing
    • SadmanBD's Gadgets
      • Asus VX229H 21.5" LED IPS
      • Newmen E370
      • A4Tech D-70FX
      • Genius F-1000
      • XFX 850W Core Edition
      • Luminous Solo 1000VA
      • Windows 8.1 Pro WMC
      • Primary Rig ;)
      • ReignICT
      • 416 kB/s
      • 416 kB/s
    SadmanBD's Avatar
    Jan 2011
    HD 5670 DDR3 6K and GDDR5 7.5K.
      • Gigabyte G33M-S2L
      • WDD-250 GB
      • Standard-A4tech
      • Samsung
      • Delta 500W
      • Sony DVD RW+_
      • Power Pac 600MA
      • Windows 7
      • 14880
    Khulna
    His Budget range is about 6K to 7K. What's the difference between DDR3 and DDR5 card?
    Love to play
      • Creative 2.1
      • Newmen M560
      • Sigma 640va
      • Good enough
      • Smile/BDcom
      • 150
      • 200
    then he should go for gigabyte or asus hd 5670 ddr3
    if budget is higher then gddr5
    GDDR5 is newer & higher memory type with more bandwidth
    on the other hand GDDR3 is older memory type with lower bandwidth
    in simple words GDDR5 is better than GDDR3, if u want to know more just google it
    HApPy GAMing
    • play hard's Gadgets
      • GIGABYTE GA H55M-S2H
      • core i3-530 overclocked to 3.52 GHz
      • 4 GB DDR3 1333 BUS (TWINMOSS)
      • 320 GB SAMSUNG SATA
      • SAPPHIRE HD 5830 1GB GDDR5
      • 20 INCH SAMSUNG LCD
      • STILL RUNNING BUILT IN
      • NOTHING SPECIAL TO MENTION
      • LEXMA
      • A4TEK X7
      • XBOX 360 CONTROLLER
      • THERMALTAKE TR2 500 WATT
      • ASUS 16x DVD ROM
      • APOLLO 600VA
      • WIN 7 ETERNITY 64 BIT
      • GARBAGE....DYING FOR UPGRADING IT
      • BANGLALION
      • 70 KB/SEC
      • 70 KB/SEC
    play hard's Avatar
    south goran
    ddr3 and ddr5 will differentiate the memory band width of the core clock. Gddr5 will b faster than gddr3. um using the gddr3 version. borrowed it from a friend. plying crysis 2 at 1600*900 in gamer details with fps 25-30. this a very playable fps. so in my sense the card is good...or not bad at all. price is 6.8k. if u r on a tight budget, then this is the card for u.
      • Gigabyte G33M-S2L
      • WDD-250 GB
      • Standard-A4tech
      • Samsung
      • Delta 500W
      • Sony DVD RW+_
      • Power Pac 600MA
      • Windows 7
      • 14880
    Khulna
    Ati radeon 5670 ar jonno ki extra PSU dorkar? extra PSU chara 6-7K ar modhhe ar ki card pawa jabe?
    Love to play
    • Dee's Gadgets
      • Asus Maximus VIII Ranger
      • Intel Core i5 6600k
      • Dell S2216H
      • Cooler Master V650 Gold
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    Quote Originally Posted by Mighty Gamer View Post
    You don't need a very good PSU, a 600tk Value-top or Delux will do.
    Get a deluxe, the value top one is crappy.
  1. Replies: 12
    Last Post: October 29th, 2012, 01:24
  2. Replies: 18
    Last Post: February 2nd, 2011, 22:33
  3. confused on buying Nvidia ar ATI GPU
    By sakinsarwar in forum GPU
    Last Post: December 2nd, 2010, 22:29
  4. ATi 5670 review
    By shaikh_imtiaj in forum GPU
    Last Post: January 20th, 2010, 02:05
  5. Replies: 5
    Last Post: December 3rd, 2009, 16:38
Page generated in 0.24197 seconds with 14 queries.
