Results 1 to 20 of 20
Thread: Motherboard Problem
    Default Motherboard Problem
    I bought my new pc at september of 2010(a core i3 530 with gagabyte h55m s2 mobo).It gave no problem except last 1 week.4-5 days ago when I started my pc I saw black screen in monitor.After trying 2-3 times by restarting pc it was fixed.After this everyday this problem was happened.
    But 2 days ago there was no response in monitor(see black screen after starting pc).Then I went to glorious computers(from where I bought my pc) yesterday.After checking my pc they told some pin of the slot(where processor is placed in the mobo) is damaged.Those pins are not straight and they are curled phisically which means under physical damage I wont get warranty.!!!!!!!!!!
    I am not a hardware expert and not change pc components regularly.I don't even know how to open processor's fans(totally noob!!!!!!!!).So I have no idea how physical damage was happened. Besides from the talking of theirs I knew that they already saw same type of problem of their other customers 1-2 days before with same brand(gigabyte/smart).After telling there is no way a physical damage can happened they told me they will send it to their head office and will tell me today I will getting the warranty or not.
    I am totally astonished and confused.One of my friend told me those pins are so small that it cant be repaired.Is it true?If yes then if I wont get the warranty I have to buy a new mobo which is completely impossible for me right now.Any idea how those pins are damaged and what can I do now?
    Default Re: Motherboard Problem
    If you didn't touch it, said Physical damage most likely happened when they themselves jammed the processor in when you bought it. So, totally not your fault
    • Dee's Gadgets
      • Asus Maximus VIII Ranger
      • Intel Core i5 6600k
      • Dell S2216H
      • Cooler Master V650 Gold
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    Did you check the bent pins yourself?
    After completing checking they showed me the mobo and I also noticed 3-4 pins are curled
    • Dee's Gadgets
      • Dell S2216H
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    You never opened it right? Maybe the problem was something else, and they accidentally ¤¤¤¤ed those pins up, and now they are blaming you.
    • codename5302's Gadgets
      • Gigabyte X99-UD5 Wifi
      • Zotac 980Ti Amp Extreme
      • Fiio Andes E07K
      • Corsair RM850
      • 2 * Prollink 1200VA
      • Windows 7 64Bit
      • It works!!
      • 154
    codename5302's Avatar
    AFAIK i3's dont have pins that go into the socket. so how can it be bent if someone didnt apply force in it? may be the seller is trying to fool you.
    • Dee's Gadgets
      • Dell S2216H
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    i3 CPUs don't have pins, they have pads which touch the pins on the motherboard. So if you are sure that you never opened it, go to the shop again.
    After 1 month or more of waiting(it isn't simple,"please come again after 7 days/3 days",I had to listen it for at least 6 times) I got my new motherboard(actually they told it new).When I returned my pc I lost my PSU(Deluxe 450W) also.They said it is damaged and also showed it to me by testing it.Then I bought a ATX 500W and returned to home.
    The first problem I saw after returning my pc back is its responding time was to much
    increased.Previously,monitor was connected with cpu in 3 second after pressing power button.But now it needs at least 8 second to connect.I ignored it cause it's not a big problem.
    Then pc started to become more and more slow.Anti-virus(avast) found nothing.Before pc become a pentium-2 I reinstalled seven and problem is gone.But I feel it isn't permanent solution.
    Before passing 7 more days another problem is created.In the middle of playing starcraft 2,pc was hang.I ignored it.Then next morning,suddenly whole pc was hang when windows try to start.Seven setup was also hang after copying setup file.
    I took my pc to a servicing shop near my house and they repaired it.But when I asked what is the problem they couldn't answer properly.After returning pc to home I saw the OS is windows-7(starter).Then I realized what they did is just reconnecting all hardware and cleaning; and then setup OS.I also realized this solution isn't permanent.
    Next morning PC became slow again and I tried solve this problem differently.I removed external gpu (hd 5670) and set-up windows(this time 32 bit instead of 64) without it.I thought about running my pc without gpu for few days to see the problem is reappear.But after start fifa-11 for the 1st time , I found this new process isn't good.Fifa -11 was lagging in practice-mode!!!!Before buying hd 5670 I played fifa 11 smoothly even in high settings with the internal gpu of my core i3 and 2 gb ram.now with 4 gb why i can't even in low setting!!!! Playing starcraft-2 in medium settings will be a dream and my prediction became true.I started to loose my temper for the 1st time.
    I had to return gpu back and set-up windows (32 bit instead of 64).This process is stayed more days than my thought.It stays even now but it also have some problem(of course it's new type and not so serious).When I tried to open hd videos(720p/1024p) it starts to lagg.
    Sometimes cursor is changed permanently.Cursor has different shape in different case(like when you writing in notepad/office cursor is like capital I).But you wont except this in gaming starcraft-2 or in desktop.By restarting I can solve it.Sometime I saw(I forget what it is called) some parallel waves goes from down to up(it's common in TV when channel network isn't good).
    Sometimes I thought PSU(ATX 500W) is the main culprit and thinking about buying a thermaltake 4XXW PSU.But for thinking a scenareo that after buying the PSU problem isnt solved and I lost 3.5K for nothing I decieded not to.
    Any suggetion what I can do now?I also thoght about returning it to IDB,but my experience with the servicing shop prevent it.
    • Dee's Gadgets
      • Dell S2216H
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    Which motherboard are you using now?
    Probably H55M S2 F4
    • Dee's Gadgets
      • Dell S2216H
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    Can you try installing a fresh OS? I mean, either download a fresh untouched version of Windows 7 or buy a DVD of SP1. And what's the brand of your PSU?
    do what Dee suggested, but before that do a "memtest" if it finds errors, then your RAM's are faulty if not ? Then continue with the OS setup! Oh if you can, update the BIOS & clear the CMOS by removing the battery for 5mins & resetting the CMOS jumpers, check your motherboard's guide, should be listed on the layout!
    @Dee
    kono brand ar na.market-a je non brand ATX PSU gula paowa jay.500-600 tk price.
    Maybe SP1 will be better than normal edition of windows.Currenly I cant download OS cause it's size.I will buy it.
    @dipanzan
    I dont know how to open hardware!!!!!!!!I cant do anything that will led to me for claiming warranty again.I still dont forget how much i had to suffer to get this one.
    Quote Originally Posted by Perfect_Galaxy View Post
    @Dee
    @dipanzan
    that sucks, anyways try the memtest ? Oh & if you update the BIOS, usually Gigabyte has a native Windows software for updating the BIOS, if you do update the BIOS...the CMOS also gets clear in the process! Though some motherboards require that you manually reset the jumpers to "clear" & then to "default"
    Check their website, I'm sure you'll find something!
    • Dee's Gadgets
      • Dell S2216H
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    @Dee
    @dipanzan
    Download memtest and check if there are errors with the RAM, as dipanzan bro said. And if you are not experienced, I suggest you not to do anything with the hardware. And I have some SP1 disks, if you want, you can take one.
    How can I test my ram so I can know those are faulty or not?I cant do it externally.I have no friend by those i can replace my DDR3 ram and test it.I also cant use mines in theirs pc cause those are DDR2.Is their any way to test it internally?
    Use ---> memtest86
    I used memtest86.But it didn't show any error in my ram.
    • rion_uttara's Gadgets
      • MSI b75MA-p45
      • intel i-3 2100 @3.1 ghz
      • 6gb ddr-3
      • 500gb samsung
      • intel HD graphics
      • Viewsonic 18.5inch led
      • altec lancing 2:1
      • Delta 750 watt
      • samsung dvdrw
      • win7 64-bit
      • chole :P
      • banglalion wimax
      • 120-128kbps
      • 32 kbps
    vai amr mone hoy oi dokandarerai ulta-palta kisu korse
    • mmrozibul's Gadgets
      • GIGABYTE GA-X79-UD5 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 Extended ATX Intel Motherboard
      • Intel celeron 1.8 GHZ :) :)
      • OCZ DDR3 PC3-12800 / 1600 MHz /Gold Edition / Triple Channel Kits 12gb
      • Crucial M4 CT256M4SSD2 2.5" 256GB SATA III and hitachi 2TB sataII
      • 2x ATI Radeon HD 5970 2GB DDR5
      • HYUNDAI 22" LED
      • Microlab 7.1
      • CORSAIR CH9000003UK Vengeance K90 Mechanical Gaming Keyboard
      • RAZER Ouroboros Elite Wireless Gaming Mouse - Black
      • Thermaltake Toughpower W0133RU 1200W ..
      • ASUS+SAMSUNG DVD Writer
      • 32 gb transcend pendrive 19mb write and 35 mb read speed. Usb HDD 2TB Transcend USB3
      • Windows 7 Ultimate X64 and win xp service pack2 dual boot( for SL3 Hash calculation)
      • not scored
      • Justify yourself
      • Banglalion 2 MBPS
      • 280 Kilobyte
      • 150 KB
    Oct 2011
    Khulna
    I think so, its the fault of shopkeeper, when he opened the processor then problem created.
  1. [HELP] Which Motherboard should I use ?
    By Gaara™ in forum Help - PC Buying
    Last Post: April 28th, 2011, 02:09
  2. motherboard help
    By sakinsarwar in forum Motherboard
    Last Post: October 22nd, 2010, 23:04
  3. Want to Buy MotherBoard
    By abir in forum Shop - Gadgets
    Last Post: September 4th, 2010, 23:54
  4. Closed Motherboard
    By AmareX in forum Shop - Gadgets
    Last Post: July 16th, 2010, 02:39
  5. Which motherboard will be the best?????
    By Cracked in forum Motherboard
    Last Post: April 17th, 2010, 11:05
Page generated in 0.31182 seconds with 14 queries.
