Results 1 to 14 of 14
Thread: sapphire hd 5770 problems.. need help !!!!
    • MasterOfDeath's Gadgets
      • Intel DG41RQ
      • Intel core 2 Duo E7500 2.93Ghz
      • Team 2 GB x 2 DDR2
      • Samsung 320GB
      • Sapphire Ati Radeon HD 5770 1GB GDDR5
      • Samsung SyncMaster 933 18.5'' LCD
      • Realtake Built In
      • Creative Inspire T3130
      • Value-TOP
      • Suntech
      • Gigabyte Superb 550 watt
      • Asus
      • Windows 7 64bit
      • 25KBps
      • 10KBps
    Mirpur
    Angry sapphire hd 5770 problems.. need help !!!!
    matro gotokal gpu ta lagalam.... but 1 diney eto problem ditese... ...1st of all. battlefield bad company 2 chole na.. game start er somoy monitor a black ekta scene ashe then automatic game off hoye jaitese.... abar desktop er icon gular o problem hoy jemon icon gular niche deep ekta shadow pore... nd lekha gula clear dekha jay na... mone hosse ekta lekhar upor arekta lekha.... overwriting er moto..... nfs shift choltese...but choto ekta screen a... maximize hoy na....... ki korbo kisui bujhtesi na... catalyist reinstall disi kaj hoy nai... ..abar onno game thiki choltese... mafia 2 choltase..smoothly 60 fps a....... amar tar cataylist version 10.9... win xp sp3 ,550 watt gigabyte psu , 2 gb ddr2 ram nd core2duo 2.93 processor amar..... PLEASEEEEEEEEEEEEEEEEE HELPPPPPPPPPPPPPPPPP GUYYYYYYYYYYYYYYYYYYYYSSSSSSSSSSSSSSSSSSSS........
    • Mohiuddin's Gadgets
      • Xeon X5650
      • 8gb gskill ripjaw
      • Western Digital 1TB blue
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Gigabyte 1200w OdinPro
      • Apatoto nai
      • Netvision
      • Janina, 3Mbps may be
      • Don't upload...
    Uttara,dhaka
    Default Re: sapphire hd 5770 problems.. need help !!!!
    Give a clean win7 32bit install. Then install 10.10ehotfix or 11.1a hotfix...
    here 11.1ahotfix dl from guru3d
    11.4 whql driver is out/will be out soon today/tommorrow in amd site...it is also stable i think.
      • Intel DG41RQ
      • Samsung 320GB
      • Realtake Built In
      • Value-TOP
      • Suntech
      • Asus
      • Windows 7 64bit
      • 25KBps
      • 10KBps
    Mirpur
    not win 7.... ei problem er solve ki xp tey hobe na????????? new driver install korle performance barbe?????
    ---------- Post added at 10:52 ---------- Previous post was at 10:51 ----------
    please help or i will suicide
    • Reventon's Gadgets
      • Gigabyte H67MA-D2H
      • Intel Core i5 2400 3.1 ghz.
      • 4 GB DDR3 1600 BUS CL7 OCZ FATALITY EDITION
      • WD CAVIER BLACK 1 TB
      • Sapphire AMD 7870 GHZ edition
      • PHILIPS 224EL LED 1080p HDMI+DVI
      • ON BOARD
      • 4:1 creative inspire
      • a4 tech
      • a4 tech
      • COOLER MASTER SILENT PRO 600W
      • Samsung.
      • should be better
    Reventon's Avatar
    Sep 2009
    Moghbazar
    seems anouther **** ucc strike... try to upgrade driver though...
    • knroeoueqisk's Gadgets
      • Intel Core i5 750
      • Cosonic head phone
      • Perfect keyboard
      • Delux optical mouse
      • Normal Non brand gamepad
      • Thermalake TR2 500 watt
      • Samsung 22X Dvd Writer
      • i am happy with it.
      • 15 Kilobytes - 64 Kilobytes
      • 5-15 kilobytes
    Dec 2009
    btw guys he couldn't find integrated graphics option in mobo bios.so he couldn't disable integrated graphics.maybe that is causing the problem and the external pci card is not active due to that reason.
    ---------- Post added at 11:10 ---------- Previous post was at 11:03 ----------
    any way to disable integrated graphics from windows xp without using the bios?
      • Intel DG41RQ
      • Samsung 320GB
      • Realtake Built In
      • Value-TOP
      • Suntech
      • Asus
      • Windows 7 64bit
      • 25KBps
      • 10KBps
    Mirpur
    mohiuddin vai bolse... dg41 mobo te disable kora laage na..... tobou ami dusable korsi devics manegar theke.. nd pci kaj korste.. cz aage je game gula hoto na ogula choltese
      • Xeon X5650
      • 8gb gskill ripjaw
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Apatoto nai
      • Netvision
      • Don't upload...
    Uttara,dhaka
    ok, then give a clean install of whatever window u want...
    It is highly recommended when u switch to a new gfxcard.patience...
      • Intel DG41RQ
      • Samsung 320GB
      • Realtake Built In
      • Value-TOP
      • Suntech
      • Asus
      • Windows 7 64bit
      • 25KBps
      • 10KBps
    Mirpur
    any way to disable integrated graphics from windows xp without using the bios? ..............................
    yes ami eta device manegar thekey disable korsi... bios charay
    ---------- Post added at 11:14 ---------- Previous post was at 11:13 ----------
    nfs shift er screen boro hoy na kan??? kalke raate khellam boro screen a... bt aj screen choto.... huh
    ---------- Post added at 11:15 ---------- Previous post was at 11:14 ----------
    xp notun kore setup dibo????
    ---------- Post added at 11:25 ---------- Previous post was at 11:15 ----------
    oi oi shift er problem thik hoise... my documents a nfs shift folder a ekta xml file silo.. ota delete korsi...
    • emroz_2272's Gadgets
      • Xonar STX
      • Microsoft Sidewinder X4
      • Samsung 24x DVD-RW
      • Acme 1000VA
      • Windows 10 Professional x64
      • Not into benchmarking!
      • Makes me delirious! :) :p
      • Agni Online 3/6 Mbps
    emroz_2272's Avatar
    Gulshan, Dhaka
    after installing a dedicated gpu, the IGP is automatically disabled or overridden. sometimes what happens is that the igp still shares ram from the main ram. rather than disabling it from device manager, go to bios and disable it from there.
    Also, a fresh install of windows and the latest graphics drivers should alleviate your problems......hopefully.......
    • Red Devil's Gadgets
      • Gigabyte Z68X-UD5-B3
      • Intel Core i5-2500K Sandy Bridge @4.00 GHz with Corsair H75 LC
      • AVEXIR - Core Series 8GB(4GBX2) 1600MHz @9-9-9-24
      • Samsung 850 Evo 250GB SSD + Seagate Barracuda (4TB+3TB) HDD
      • MSI GTX 960 2GB
      • ASUS VX229H IPS Panel Monitor
      • Creative Sound Blaster X-FI Titanium
      • Altec Lansing expressionist ultra MX6021
      • Corsair Vengeance K70 Mechanical Keyboard
      • A4tech Bloody V9C/Razer Goliathus Fragged Control Edition
      • XBOX One Wireless Controller
      • Thermaltake Smart SE 630M || Cooler Master HAF 912 Advance Mid Tower Case
      • Pioneer DVD RW
      • Transcend V60 8GB, Apacer 2GB pen drive
      • RahimAfroz 800VA
      • Windows 10™ Pro 64 Bit
      • My PC is my life......
      • ICC
      • 8mbps
    Red Devil's Avatar
    Quote Originally Posted by MasterOfDeath View Post
    Just install OS & latest driver. It will solve your problem! & abt shift, pressing ALT+ENT will do the job.
    • error's Gadgets
      • None ; 18x DL SuperDrive
      • Mac Pro love.
      • 1 mbps
      • 1 mbps
    error's Avatar
    Boo.
    EPIC XD!
    And Win XP SP3? Is it the one that's made by ITNext which has a BMW theme and wallpaper when you first installed it? If yes, either get a clean copy of Win XP SP"3" from some other shop, or downgrade to SP2. That so called SP3 is bull¤¤¤¤!
      • Intel DG41RQ
      • Samsung 320GB
      • Realtake Built In
      • Value-TOP
      • Suntech
      • Asus
      • Windows 7 64bit
      • 25KBps
      • 10KBps
    Mirpur
    na...eta itnext theke kini nai
    ---------- Post added at 14:26 ---------- Previous post was at 14:26 ----------
    r etate itnext er logo o nai
    ---------- Post added at 16:44 ---------- Previous post was at 14:26 ----------
    hey........ arekta problem ..eta gpu problem na obosso.... nfs shift 2 unleshed intall er jonne 2 ta disk theke file gula eki folder a copy korte hoy...... 1st disk ta copy hoise thik moto... bt 2nd disk ta copy korar somoy sesh dike ar copy hoy na....Lekha ashe ::: Cannot copy group 6 :data error (cyclic redundancy check)......... eita abar ki???????????? pls reply
    • samiulislam16's Gadgets
      • Core i7 860 2.93ghz
      • Sapphire HD7870 ghz dualX
      • Asus 22 inch LED MS228H
      • Realtech Hd 8 channel Audio
      • Creative 2.1
      • Newmen M560
      • Dilong usb controller
      • Samsung DVD writer
      • Sigma 640va
      • Good enough
      • Smile/BDcom
      • 150
      • 200
    samiulislam16's Avatar
    ekhon arki CD paltaite hobe
    ar nahole onno arek pc theke copy korte hobe
    Guess what??? scan it??:
    Good enough GAMING RIG
    HApPy GAMing
      • Intel DG41RQ
      • Samsung 320GB
      • Realtake Built In
      • Value-TOP
      • Suntech
      • Asus
      • Windows 7 64bit
      • 25KBps
      • 10KBps
    Mirpur
    Hmmm eta cd tey problem......... onno pc teo same obosta
  1. SAPPHIRE 5770 vs GIGABYTE 5770-- Which is better?
    By VANGUARD in forum Help - PC Buying
    Last Post: April 25th, 2011, 23:10
  2. Want to Buy Want to buy Sapphire 4870 toxic 1gb or sapphire 5770 1gb
    By Camouflage in forum Shop - Gadgets
    Last Post: October 6th, 2010, 11:06
  3. Replies: 8
    Last Post: September 26th, 2010, 14:13
  4. Sapphire 5770 Graphics issue
    By Nafis Iqbal in forum Technical Support
    Last Post: September 13th, 2010, 14:05
  5. Replies: 105
    Last Post: January 3rd, 2010, 21:35
Page generated in 0.27486 seconds with 14 queries.
