Thread: Suggestions For Buying A LED Monitor For PC + PS3 and Xbox 360...................
    • SinisterFahim's Gadgets
      • Gigabyte GA-945GCMX-S2
      • Core 2 Duo E4500
      • Twinmos 1GB + 2GB = 3GB DDR2 (800 Mhz)
      • Hitachi 1TB
      • ATi Radeon X1050
      • Asus MS228H
      • On-Board......
      • Creative Inspire M4500. (Going To Get A Microlab SOLO 7C ASAP)
      • A4 Tech Basic Keyboard
      • Genius 120 NetScroll
      • Don't Have One For PC Gaming..........
      • Generic 440W.....
      • Lite-On 16X Combo & ASUS 24X Dual Layer DVD-RW
      • Transcend 25M2 500GB External HardDrive ll Apacer 8GB AH324 ll Apacer 8GB AH332 ll Transcend V30 8GB
      • Mercury 1200VA
      • Windows 7 (62-Bit)
      • Sucks, I Know........!!!!
      • Banglalion WiMax
      • 512kbps OR 64KB/s
      • 128kbps Or 16KB/s
    SinisterFahim's Avatar
    Home........
    Default Suggestions For Buying A LED Monitor For PC + PS3 and Xbox 360...................
    Hey guys,
    My present monitor which is a LCD Samsung 21.5 is having problems so i have decided to buy a new monitor because it was given to me by my uncle when he went to Italy and I dont have the receit to claim the warranty. So I need help choosing the right LED monitor for me.
    I need some help deciding about which LED monitor to buy. The monitor must have HDMi and Speakers. All brand will do, but Benq is prefarable. I don't get time thesedays so can't go to the market and inquire about it, and this time im counting on you guys to suggest.
    And as im a bit out of cash , I can't slip nothing more than 21-22Gs for now, so make your suggestions within this range please.
    AND THANKS IN ADVANCE.
    ---------- Post added April 21st, 2011 at 16:47 ---------- Previous post was April 20th, 2011 at 22:44 ----------
    @aayman_farzand
    bro i opened the thread in the wrong section....can u move the thread to ''GENERAL SHOPPING HELP'' section plz......
    Default Re: Suggestions For Buying A LED Monitor For PC + PS3 and Xbox 360...................
    You want built in speakers? They are horrible, just get a cheap 2.0 stereo setup instead and connect it to the monitor, much much better.
    I believe the ASUS MS22H is the best one available in BD right now, it has 1 HDMI port, 1 VGA port, and of course the Audio jack.
    ---------- Post added at 16:52 ---------- Previous post was at 16:51 ----------
    Btw, you have a big budget for a monitor, you must NOT get one with built in speakers!
      • Core 2 Duo E4500
      • Hitachi 1TB
      • ATi Radeon X1050
      • Asus MS228H
      • On-Board......
      • Generic 440W.....
      • Mercury 1200VA
      • Banglalion WiMax
      • 512kbps OR 64KB/s
      • 128kbps Or 16KB/s
    Home........
    aayman bro thnx for the suggestions.......and im thinking about the asus monitor u mentioned...i have good speakers i.e. creative 4.1.....but dnt have remote for controlling the soind......is there any speaker from creative or altec lansing with remote sound control.........
    ---------- Post added at 17:16 ---------- Previous post was at 17:14 ----------
    and bro as my budget is good enuff..........wat the best LED with HDMI you recommend..............and can u shed some light on the speakers thing........
    Monitor:
    1. Asus MS228 21.5 Inch LED (15.2k)
    2. Asus ML238H 23 Inch LED (22.4k)
      • Core 2 Duo E4500
      • Hitachi 1TB
      • ATi Radeon X1050
      • Asus MS228H
      • On-Board......
      • Generic 440W.....
      • Mercury 1200VA
      • Banglalion WiMax
      • 512kbps OR 64KB/s
      • 128kbps Or 16KB/s
    Home........
    Well I have settled down with this............
    I am getting :
    Monitor : Asus MS228H
    Speaker : Microlab SOLO 7C
    Quote Originally Posted by aerofighter View Post
    Monitor:
    Thanks 4 that info.
    ML248H ashshcey? I am interested in 24''.
    Ashley daam o omon gola kaata hobey.
    • asif105878's Gadgets
      • Intel X45
      • Intel Core i5-450M Processor 2.40GHz with Turbo Boost Technology up to 2.66 GHz
      • 4GB DDR3 800MHz
      • 500GB 7200rpm, 1+1.5+2 TB external
      • Intel GMA HD
      • ASUS VH238H, 14.0” diagonal High-Definition HP BrightView LED Display (1366 x 768)
      • Altec Lancing, A4Tech Hs-30
      • CM Storm Trigger, Logitech, 101-key compatible with island-style full-size keyboard
      • Logitech M125
      • DualShock 3, XBOX controller, Wii Remote and Nunchuck, Mad Catz X360 CoDBO PrecisionAIM Controller
      • 65W
      • Sony Walkman, Portable HDD, USB flash drive
      • N/A
      • Win7 Home Premium x64
      • 4.5
      • stuck with it atm :(
      • Comocast
      • 3125
      • 1500
      • 50
    asif105878's Avatar
    May 2010
    Somewhere in Michigan
    My friend is using this monitor for his pc, he is planning to buy an Xbox360
    Model: SyncMaster 2243NWX
    Specifications:
    http://www.samsung.com/uk/support/de...dl_name=2243NW
    Max resolution:1680 x 1050
    Video Signal: Analog RGB
    Sync. Signal: Separate H/V, Composite, SOG
    Connector: 15pin D-SUB
    Now my questions are:
    1.Will he be able to use this monitor with his Xbox360?
    2.What sort of converters will he need? How much will they cost in BD? How will be the image quality?
    3.Will he be able to play games in HD (720p)?
    Anime-Planet.com - anime | manga | reviews
  1. suggestions on buying a 360
    By Drake Fenix in forum XBOX
    Last Post: June 20th, 2011, 10:49
  2. Help Buying a Xbox 360 or PS3
    By Mouse in forum XBOX
    Last Post: March 2nd, 2011, 19:11
  3. Suggestion for Buying LCD/LED Monitor
    By SadIkMahdI in forum Others PC Hardware
    Last Post: December 9th, 2010, 02:09
  4. Replies: 3
    Last Post: October 14th, 2010, 23:25
  5. Help me buying a good LCD/LED monitor(budget 18k)
    By showdown_king in forum Others PC Hardware
    Last Post: June 12th, 2010, 17:10
Page generated in 0.20015 seconds with 14 queries.
