Results 1 to 2 of 2
Thread: PS4 facing the evil power cuts... risky for use in BD?
    Default PS4 facing the evil power cuts... risky for use in BD?
    As we all know BD suffers from power cuts, so whenever I play my PS3 and then the power randomly cuts off when I turn it on again I get a message "The file system will be checked to see if it's corrupted" or something like that. (Thankfully power never went out during a system update ever since 3.60 to 4.75)
    Now, on the PS3 you could skip that. However on the PS4, if power is interrupted in any way, it goes to Safe Mode and does a system storage check. And you can't skip that.
    So what happens if the storage check screws up??? Or what happens if the PS4 stops working and then you'll have to reinstall the entire OS again? Due to the amount of power cuts (well not that much now) it could put these latest gen consoles like PS4 and Xbox One to risk where they are designed to be always on (I know you can fully shut them off)
    Is there any advice on using a PS4 safely in BD? I don't have one yet but I hope to get the latest model CUH-1200 whenever it's available and get it from the UK soon so would like some advice.
    Thanks.
    • Trave160's Gadgets
      • MSI B350M Mortar AM4
      • AMD Ryzen 5 1600
      • 16GB DDR4 3000Mhz
      • 3TB Western Digital red
      • ASUS Strix GTX 960 4G
      • Dell S2216H 22 Inch monitor
      • Logitech Speaker
      • TtEsports Knucker
      • PS4 Dualshock 4 controller
      • Pendrive 4GB
      • NunuCom Ltd, Penus group
      • Super San 200kbps
      • 105*2
    Trave160's Avatar
    A Secure Area
    Get a 700VA or 650VA UPS and use it , with the amount of power backup you'll be able to turn off your console safely
    Will cost you almost 3k to buy one
  1. Power Supply Surges Detected during the previous power on
    By Saiful418 in forum Technical Support
    Last Post: April 28th, 2015, 04:52
  2. Sale (Used) Tansnet Casing with 430watt Thermaltek Lite power Power Supply
  3. The Risky business behind taking care of your PC.
    By Trave160 in forum Technical Support
    Last Post: August 1st, 2011, 20:27
  4. Replies: 2
    Last Post: December 1st, 2010, 01:32
Page generated in 0.17060 seconds with 14 queries.
