Thread: CPU temperature problem again :(
    Default CPU temperature problem again :(
    Hello bros, at last I've got that thermal paste which took 100 tk. Still the problem is not 100% solved. cpu temp ekhon 0-5% load e 55 thaktese. 90-100% load e 10 min pore 70 ar 15 min pore 75 cross kortese. Now is that normal? I don't think so. What do I do now. Please help guys.
    Thanks in Advance...
    • [email protected]'s Gadgets
      • Gigabyte Z97x-UD3H-BK
      • G Skill 16 GB DDR3 2200MHz
      • Asus Geforce 970 4GB
      • Asus 21.5 inch IPS monitor
      • Logitech G500s
      • EVGA G2 750W 80 plus Gold
    Tom@L's Avatar
    San Francisco, USA
    Default Re: CPU temperature problem again :(
    did u apply the thermal paste properly ???
    Also check whether ur cpu fan is clean (free of dust).
    Possibly ur casing is small (not enough air circulation) or it is located in a congested area.
    I applied the paste properly. Casing is not small but medium sized. and It has 3 60mm fans running. I talked to the sales center they asked me to take it to them. Now I have no other option other than meet them.
    Thanks anyway.
    • cyanid3's Gadgets
      • msi 760Gm p33
      • Amd Athlon x4-640
      • 4GB siliconpower DDR3
      • 540GB
      • SAPPHIRE HD 6770 1GB GDDR5
      • Philips 192EL2SB 18.5"
      • Microlab 2.1
      • LOGIC waterproof + dustproof
      • A4tecH 2x
      • VINYSON
      • TT 500W
      • Liteon 24x Label Tag DVDRW
      • WIN 7 x86
      • goriber pc
      • LINK3
    cyanid3's Avatar
    Dec 2009
    West Panthapath.
    @[email protected] bro thermal paste er price kemon & kothae pabo? i live in kalabagan.
    • proton_chain's Gadgets
      • Gigabyte GA-P55-UD3
      • 4x4GB DDR3-1600MHz
      • 6.5TB (3TB+2TB+1TB+.5TB)
      • Nvidia Geforce GTX 760 4GB
      • Samsung Syncmaster 22 inch
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
      • Sony Optiarc DVD burner
      • Blue Yeti USB Microphone
    proton_chain's Avatar
    An idle temperature of 55°C on a E7200 (stock) is absolutely not normal, even considering that it is mid April. But 100% CPU load hitting only 75°C is abnormal as well which is only 20°C more than the idle temperature! If you are 100% sure that both are correct, then it is your testing method that is inappropirate. Use Intel Burn Test to measure the load temperature. Run it on both threads for 5-6 minutes and you should reach the maximum temperature. Then post it here, we need appropriate results before coming to a conclusion. But it is almost certain that the TIM was not applied properly from the unusually high idle temperatures. Rapid and significant rise in IBT load temperatures will only valdate this assumption.
      • Logitech G500s
    Tom@L's Avatar
    San Francisco, USA
    Quote Originally Posted by cyanid3 View Post
    akdom sosta gula 100 takai pawa jai. Amio use kortesi. U can get them in Rishit in IDB. Elephant road eo pawa jabe i guess.
    I used RealTemp and CoreTemp to measure temp. both had same result. But BIOS e hardware monitor e temp 42-46 er beshi show kortese na. Oikhane to ar 100% load theoar system nai.
    Porshu Rajshahi jabo. service center e jaoa chara r upay nai.
    Anyway thanks..
  1. CPU temperature problem
    By Badhon_raj in forum Technical Support
    Last Post: April 29th, 2011, 15:00
  2. cpu temperature problem
    By Swapan Roy in forum CPU
    Last Post: March 5th, 2011, 17:45
  3. CPU Temperature Measurement
    By gamefreak in forum Technical Support
    Last Post: January 27th, 2011, 01:06
  4. CPU Over temperature!
    By Dee in forum CPU
    Last Post: October 22nd, 2010, 00:06
  5. Replies: 15
    Last Post: June 14th, 2010, 07:42
Page generated in 0.19779 seconds with 15 queries.
