Results 1 to 14 of 14
Thread: pls help :PC SLOW down problem
    • kazi_taufique's Gadgets
      • Gigabyte:94gcm-S2C
      • Intel core2duo [email protected]
      • 2 GB
      • 320GB SATA
      • NVEDIA GT220
      • samsung Syncmaster 733nw
      • built-in
      • HEADPHONE:C0SONIC,SPEAKER : NANSIN s-630s
      • A4TECH
      • A4TECH
      • 400W
      • samsung trudirect DVD writer
      • apollo
      • windows xp sp3
      • 25-30 kb
    kazi_taufique's Avatar
    Default pls help :PC SLOW down problem
    amar pc r configuration: processor : intel core 2 duo 2.4 gz, ram 2 gb, hard disk 320 gb, graphics card : Nvidia GT 220, mother board gigabyte GA 945GCM S2C.
    amar problem hocche amar pc full format dea r por o 2-3 din er moddhei pc slow hoye jacche r assassins creed brotherhood khelte parchi na, atke jacche. pc full format dea r por 1-2 din game khela jay. erpor hotath e game atke jay erpor pc restart dea r por thekei pc slow hoye thake. abar format dea na porjonto kichu tei kichu hoy na. ei ta j virus er jonno hocche na sheta motamoti confirm korte parchi..ei dhoroner problem er karon ki hoye pare? solve e ba korbo kivabe?
    Default Re: pls help :PC SLOW down problem
    How can you confirm that virus is not doing this. Do you use any antivirus?
    Dhore nilam virus eta korse na. Tahole amar suggestion holo, format your c drive, install windows once again. And this time DO NOT INSTALL ANY OTHER APPS. Only install the game and use your pc for 2 or 3 days and see if your pc slows down again or not.
    Member rummoi's Avatar
    Nov 2009
    Shahjahanpur
    net e onek pc optimizer type software ase , ogula try kore dekhte paren. ar game khelar somoi antivirus off kore dekhte paren
      • 2 GB
      • 320GB SATA
      • NVEDIA GT220
      • built-in
      • A4TECH
      • A4TECH
      • 400W
      • apollo
      • windows xp sp3
      • 25-30 kb
    virus nei ei ta bollam karon j ami full pc format dea r por prothom ei Norton antivirus original copy install korsi, erpor driver install kore game install korechi r kono software e install kori nai..erpor o pc 2/3 er moddhei slow hoye jacche.
    • samiulislam16's Gadgets
      • Core i7 860 2.93ghz
      • Sapphire HD7870 ghz dualX
      • Asus 22 inch LED MS228H
      • Realtech Hd 8 channel Audio
      • Creative 2.1
      • Newmen M560
      • Dilong usb controller
      • Samsung DVD writer
      • Sigma 640va
      • Good enough
      • Smile/BDcom
      • 150
      • 200
    samiulislam16's Avatar
    Install windows again and if that doesnt do it u must have virus in ur other drives
    use an antivirus eg. avast
    Guess what??? scan it??:
    Good enough GAMING RIG
    HApPy GAMing
    • master_tanjid's Gadgets
      • HP-Intel HM65
      • Intel Core i5 - 2410m @ 2.30GHz
      • 4.00 GB Single-Channel DDR3
      • 640GB Western Digital WDC
      • AMD Radeon HD 6750m 1gb ddr5
      • Generic PnP Monitor ([email protected])
      • Altec Lansing
      • HP dvd rom
      • windows 7 premium 64bit
      • Maxis Broadband
      • 500
      • 200
    Sep 2008
    Jalan Gombak, Kuala Lumpur, Malaysia
    Quote Originally Posted by kazi_taufique View Post
    open task manager and check which app is using most of the cpu and memory
    • [email protected]'s Gadgets
      • Gigabyte Z97x-UD3H-BK
      • G Skill 16 GB DDR3 2200MHz
      • Asus Geforce 970 4GB
      • Asus 21.5 inch IPS monitor
      • Logitech G500s
      • EVGA G2 750W 80 plus Gold
    Tom@L's Avatar
    San Francisco, USA
    Quote Originally Posted by master_tanjid View Post
    yeah do this while playing the game and also when the pc is idle. Then See the culprit.
    I heard that norton slows down pc a lot. Though I never tried it. It will be better if you can disable the antivirus before playing game. Also scan your entire hard disk for viruses.
      • Logitech G500s
    Tom@L's Avatar
    San Francisco, USA
    norton ato slow kore na akhon. Oi ager version gula slow korto. Modern Norton antivirus is very gud.
    But yes, he can try uninstalling Norton and check the speed after uninstallation.
    • emroz_2272's Gadgets
      • Xonar STX
      • Microsoft Sidewinder X4
      • Samsung 24x DVD-RW
      • Acme 1000VA
      • Windows 10 Professional x64
      • Not into benchmarking!
      • Makes me delirious! :) :p
      • Agni Online 3/6 Mbps
    emroz_2272's Avatar
    Gulshan, Dhaka
    it sounds very much like a virus infestation but you seem to be confident that it's not. But do check using another antivirus like avast 6 or avira or avg. also there are many good anti-malware like malwarebytes anti-malware etc... which might just help.
    install them and check your pc along with monitoring your system resources as others have already stated. If you go to filehippo.com you'll find a large collection of free & legal security software! Hope this helps!
    • SadmanBD's Gadgets
      • Asus VX229H 21.5" LED IPS
      • Newmen E370
      • A4Tech D-70FX
      • Genius F-1000
      • XFX 850W Core Edition
      • Luminous Solo 1000VA
      • Windows 8.1 Pro WMC
      • Primary Rig ;)
      • ReignICT
      • 416 kB/s
      • 416 kB/s
    SadmanBD's Avatar
    Jan 2011
    I also had the same problem. After every 2, 3 days I had to format my hdd for playing games. It was caused by a virus called Idonno (New Folder.exe). At last Avast saved me
    ---------- Post added at 22:33 ---------- Previous post was at 22:26 ----------
    If your system is affected by Idonno virus then msconfig, registry editor, gpedit, cmd and task manager will not open. And svchosl.exe will eat up to 50% of your cpu.
      • 2 GB
      • 320GB SATA
      • NVEDIA GT220
      • built-in
      • A4TECH
      • A4TECH
      • 400W
      • apollo
      • windows xp sp3
      • 25-30 kb
    ami age avast 6 e use korsi.. and avast use koreo amar same problem face korte hoise, norton disable kore game on koreo kono luv hoy na. norton die full scan e virus pai nai.. pawar kothao na karon matro koydin agei ami pc ful format korechi.kintu er age ak ta kotha bolte vule gesi, pc format dea r shomoy r game er majheo ami ak ta problem face korsi , pura screen hotath blue hoye gie "windows has been closed to save your system from potential damage" ei jatio error eshe pc off hoye jay. amr ki hardware e kono mismatch hocche? amar 2gb RAM Apogee r , beshi din hoynai kinchi... Assassins creed 2 khelchi tokhon kono problem hoy nai..but brotherhood khelte gie problem face korchi.
    ---------- Post added at 13:45 ---------- Previous post was at 12:58 ----------
    svchost.exe using most of the memory (24112 k) but cpu usage is very low only 1%-2%
    • knroeoueqisk's Gadgets
      • Intel Core i5 750
      • Cosonic head phone
      • Perfect keyboard
      • Delux optical mouse
      • Normal Non brand gamepad
      • Thermalake TR2 500 watt
      • Samsung 22X Dvd Writer
      • i am happy with it.
      • 15 Kilobytes - 64 Kilobytes
      • 5-15 kilobytes
    Dec 2009
    blue screen of death.mone hoitase ram er problem.
    ram er stick koeta ta 1 na 2 ta?2 ta holle ekta khule onnota die pc chaliey dekho pc slow oy kina.jodi slow na hoy taile oi stick khule onno stick ta install kore pc chalaya dekho pc slow hoy kina jodi slow hoy ba blue screen of death paw taile mone hoy oi ram tar sommosa ase.(try this if you know about ram install procedure if not then don't try it or try at your own risk.)
    • cyanid3's Gadgets
      • msi 760Gm p33
      • Amd Athlon x4-640
      • 4GB siliconpower DDR3
      • 540GB
      • SAPPHIRE HD 6770 1GB GDDR5
      • Philips 192EL2SB 18.5"
      • Microlab 2.1
      • LOGIC waterproof + dustproof
      • A4tecH 2x
      • VINYSON
      • TT 500W
      • Liteon 24x Label Tag DVDRW
      • WIN 7 x86
      • goriber pc
      • LINK3
    cyanid3's Avatar
    Dec 2009
    West Panthapath.
    check ur processor temperatures too. summer time e over-heating issues onek common hoy.. i was facing the same probs of slow'd pc today..my processor's temp went sky high to 73-74*C
    now im cleaning my rig and will be off to buy some thermal paste.
  1. Forum: Slow browsing
    By LynAs in forum Feedback
    Last Post: January 24th, 2011, 06:06
  2. Slow Browsing but fast downloads
    By gamer_101 in forum Internet
    Last Post: January 29th, 2010, 21:17
  3. uber slow file copy over network on win7
    By CvP in forum Technical Support
    Last Post: January 3rd, 2010, 02:08
  4. Forum Slow, isn't it?
    By Hamilton in forum Feedback
    Last Post: November 25th, 2009, 10:54
  5. Redesigned PlayStation Store looks new, runs slow
    By CHR.Overload in forum PlayStation
    Last Post: April 20th, 2008, 20:18
Page generated in 0.26490 seconds with 14 queries.
