Thread: How is this Cooling solution for my GPUs?
    • Rakin the Devil's Gadgets
      • Gigabyte X58-USB3
      • Hitachi 1TB 7200 Rpm
      • A4tech Gaming Keyboard
      • A4tech X7 747H Gaming Mouse
      • BenQ 24x DVD-RW
      • Powerpac 1200VA x2
      • Windows 7 SP1 x64
      • Check Links in Sig..
      • 140+
      • 50+
    Jan 2011
    Default How is this Cooling solution for my GPUs?
    Here i made a rough diagram of a better cooling system for my GPU. I made the HDD Cage a Duct for the GPUs.If u guys have something better in mind then please post as i need all the help i can get to cool these beasts. Also Suggest whether i should go for full blue led fans or should get some red fans & some blue. I want the Best Cooling possible regardless of noise. By the way my ASUS GTX 460s use DirectCu Cooler which uses a downforce fan not a blower design.
    Correction : The Side panel has a 120mm 2000 RPM TT Thunderblade fan.
    Default Re: How is this Cooling solution for my GPUs?
    Top Intake ta dawa ta bhul na? Cause Top exhaust er hot air tai kintu abar bhitore jacche.
    Ar side panel fans work best as intake, but onek dust dhuke bhitore.
    • Mazhar's Gadgets
      • ASUS B250 Strix
      • AMD Ryzen 1700X
      • G.Skill 2x8GB DDR4 3200
      • Samsung 850 Pro 1TB
      • Gigabyte 1070Ti
      • Dell U2711
      • ASUS Essence STX II
      • Beyerdynamic Tesla T1
      • G910
      • G502
      • Xbox One Controller
      • Windows 10 Home
      • Aamra
    Mazhar's Avatar
    Comments from a quick glance: reverse the fans in the HDD cage, the one blowing in air from the outside should be the lower rpm one.
    Top should only be exhaust, as aayman said. 3x 120mm exhaust vs two 120mm intake will create a negative pressure, but thats not a problem.
    • Mahfuz's Gadgets
      • Asus 9600GT 512MB
      • Asus ML239H 23'' IPS Panel
      • Never Interested :-/
      • Asus 18X DVD RW
      • RahimAfrooz 1000VA
      • Not half-bad.
      • 30KBps
      • 7KBps
    Mahfuz's Avatar
    May 2010
    মনে নাই
    follow both of the aayman and mazhar vai's suggestion ...
    in my opinion, instead of the top intake or side intake try to mount a 12cm fan in top of u're modded hdd cage as intake ... it'll serve enough air for cpu cooler and since V6 has dust filter on front panel, there will happen to be much more less dust then side intake ...
      • Gigabyte X58-USB3
      • BenQ 24x DVD-RW
      • Windows 7 SP1 x64
      • 140+
      • 50+
    Jan 2011
    Dust er kono chinta nai.But jototuk observe korlam top 120mm ta diye hot air bair hoy na rather 200mm ta diye onek hot air bair hoy so 120mm ta khub effective na as per my observation.Moreover amar GPU guli hot air chare in within the case...
    Quote Originally Posted by Mazhar View Post
    Well tokhon LED fan ta thakbe na so dekhte valo lagbe na khub. To jei config e disi oita tey ki khub airflow effect hobe??Judi beshi effect hoy tahole 1300rpm ta front e diye dibo but beshi effect na hoile dibo na.
    Quote Originally Posted by amateur_geek View Post
    Front 120mm fan jeikhane ase oikhaner dust filter guli remove kore disi....
  1. availability of cpu cooling fan in bd
    By pallab7 in forum Others PC Hardware
    Last Post: March 17th, 2011, 02:41
  2. Best cooling solution provider (cpu )
    By EBL.Mantis in forum Others PC Hardware
    Last Post: January 9th, 2011, 01:24
  3. Replies: 6
    Last Post: June 1st, 2010, 11:02
  4. Want to Buy Thunderblade Cooling Fan
    By Extreme Noob in forum Shop - Gadgets
    Last Post: January 1st, 2010, 13:04
  5. Case Airflow/Cooling
    By ScS :: XTR in forum Others PC Hardware
    Last Post: December 15th, 2009, 22:04
Page generated in 0.18470 seconds with 15 queries.
