Results 1 to 17 of 17
Thread: Need help for choosing the BEST bang for buck
    • toukir95's Gadgets
      • MSI 880 GM-E41
      • AMD Phenom II X2 560 unlocked to X4 B60 @ 3.30 GHZ
      • 4 GB DDR3 1333 MHZ
      • Samsung 500 GB
      • Gigabyte AMD 6850 1 GB GDDR5 @ stock clock
      • Samsung BX2231 21.5 inch full HD LED
      • SONY Home Theater System
      • A4 Tech
      • A4TECH
      • TT ToughPower 550W
      • ASUS DVD-RW
      • None atm. Gotta buy 1 :)
      • Windows 7 Ultimate 64 bit
      • Crysis 2 on Advanced @ 50-60 fps
      • AMD FTW!!!
      • Smile
      • 15-20
      • 15
    toukir95's Avatar
    Jan 2009
    Dhaka Cantonment
    Default Need help for choosing the BEST bang for buck
    My SSC is over so this is the perfect time for building my dream gamin' PC. My budget is 55k excluding PSU. Heres what I've decided to get so far :-
    Processor: AMD Athlon II X4 64O or Phenom II X4 955 BE (*If I buy the 6850 or GTX 460 GFX Card)
    Motherboard: MSI 760 GM P33 (Is this mobo a gofod overclocker?)
    RAM: 2X2 GB DDR3
    HDD:500 GB
    CASING: Any good looking casing within 2k
    GFX CARD: AMD 6850 or GTX 460 or AMD 6870 (*if I buy the Athlon processor)
    Monitor: I'm having hard time choosing between 1600X900 & 1920X1080 resolution. Will the 6850 or 460 be Nuff to play most games @ 1080p for next 2-3 years?
    PSU: TT ToughPower 550W (Already bought 1.5 months ago getting dust on my drawer )
    UPS: Any cheapo ups within 1-1.5 k will do.
    N.B 1- Will the marginal performance increase of Phenom II over Athlon II really worth the extra 5k?
    N.B 2- Ryans e phone korsilam. Ora bollo oder kase r matro 1ta 6850 ase r sob GTX 460 & 6870 shesh. So ekhon jodi Ryans e na pai taile r kon dokane pawa jabe except UCC?
    • Dee's Gadgets
      • Asus Maximus VIII Ranger
      • Intel Core i5 6600k
      • Dell S2216H
      • Cooler Master V650 Gold
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    Default Re: Need help for choosing the BEST bang for buck
    1. I would suggest the Phenom II X4 955 BE.
    2. Try to go for 880... chipset board.
    3. RAM is alright.
    4. HDD is alright.
    5. Good luck.
    6. Go for the Asus GTX460.
    7. Not sure.
    8. Enough for GTX460.
    9. I don't think a cheap one will do. I'm not an expert on UPS, but I guess you'll need at least 800VA for your rig.
    NB 1: The extra L3 cache and the unlocked multiplier of course make some difference.
    NB 2: If you are not AMD fanboy, you can get the GTX460. I would tell you not to go for AMD cards unless you can find Gigabyte or Asus. You know why.
    • Darkthrone's Gadgets
      • MSI-760GM-P33
      • AMD AthlonIIX4 640 Processor 3.0Ghz
      • 4GB DDR3
      • 1TB
      • Gigabyte ATI RadeonHD5670 GDDR5
      • Asus 21.5inch 1080P MS226H
      • Creative SB X-Fi Go! Pro
      • Razer Charcharias/ Sony PIIQ HP
      • Cyber Snipa warboard
      • A4techX7/ SS XAI
      • Xbox 360 wireless controller,Guitar hero les paul controller
      • Gigabyte 460watt
      • Ipod touch 8gb,team 4 gb,transcend 4gb.
      • Current jay na
      • Not happy with gfx card, will buy gtx560/570 soon
      • 50/100 kbps
      • same as dl
      • 10
    Darkthrone's Avatar
    Простор
    For next 2-3 years u cannot play with 460 or 6850 at 1080p resolution, akhon e to mone hoy Shogun a 1080p te khela jabe na with those gfx cards.
      • MSI 880 GM-E41
      • Samsung 500 GB
      • A4 Tech
      • A4TECH
      • ASUS DVD-RW
      • AMD FTW!!!
      • Smile
      • 15-20
      • 15
    toukir95's Avatar
    Jan 2009
    Dhaka Cantonment
    Quote Originally Posted by Dee View Post
    3. RAM is alright.
    4. HDD is alright.
    5. Good luck.
    7. Not sure.
    But going for the 880 chipset will cross my budget...otherwise I would go for it. But 760 GM P33 is a quite good mobo right? Yeah but there is only +- 10 fps diff. between Phenom II & Athlon AFAIK thats why I'm nitpicking. About GFX Card I was leaning more towards Sapphire 6850 but Physx...oh yeah
    • sadi_warhead's Gadgets
      • MSI G41
      • Intel(R) Core(TM)2 Quad CPU Q8400 @ 2.66GHz (4 CPUs)
      • ADATA 4096MB RAM DDR3
      • 1 TB Samsung H3
      • Gigabyte GTX 560OC-1GI 1 GB
      • 22" samsung 2233sw
      • Realtek HD Audio output input
      • Creative 2.1/A4tech headphones
      • BenQ mulitmedia
      • A4 teCH
      • Sony controller
      • Fortex 600w
      • Windows 7 Ultimate 64-bit (6.1, Build 7600)
      • Motamuti-:| :)
      • Ispros
    sadi_warhead's Avatar
    MIRPUR
    offtopic : assa hd 6870 er price koto? market e?
    Fly High, Do or Die, Dare to Dream, Cheer Extreme!
      • MSI 880 GM-E41
      • Samsung 500 GB
      • A4 Tech
      • A4TECH
      • ASUS DVD-RW
      • AMD FTW!!!
      • Smile
      • 15-20
      • 15
    toukir95's Avatar
    Jan 2009
    Dhaka Cantonment
    Quote Originally Posted by Darkthrone View Post
    So you think going with 900p monitor will be better?
    ---------- Post added at 22:48 ---------- Previous post was at 22:45 ----------
    Quote Originally Posted by sadi_warhead View Post
    21.5 k shunsilam but kon dokane pawa jabe? Any !dea? Ryans e to nai
      • MSI-760GM-P33
      • 4GB DDR3
      • 1TB
      • A4techX7/ SS XAI
      • Gigabyte 460watt
      • Current jay na
      • 50/100 kbps
      • same as dl
      • 10
    Darkthrone's Avatar
    Простор
    Quote Originally Posted by toukir95 View Post
    Chaile 1080p monitor kinte paro, resolution komay khelte paro, i also have a 1080p monitor, kintu ami shob game to ar 1920x1080 resolution a khelte pari na.
      • MSI 880 GM-E41
      • Samsung 500 GB
      • A4 Tech
      • A4TECH
      • ASUS DVD-RW
      • AMD FTW!!!
      • Smile
      • 15-20
      • 15
    toukir95's Avatar
    Jan 2009
    Dhaka Cantonment
    But ami jotdur jani LCD/LED monitor e native resolution er niche dile GFX khubi blurry & washed out ashe? :\
      • MSI-760GM-P33
      • 4GB DDR3
      • 1TB
      • A4techX7/ SS XAI
      • Gigabyte 460watt
      • Current jay na
      • 50/100 kbps
      • same as dl
      • 10
    Darkthrone's Avatar
    Простор
    I've also heard that, but ami to kheli lower resolution a tamon kharap to ashe na.
    Resolution komai khelte asholei game ta weird ashe. 1080p monitor e 1600x900 jodi tao, onek khani blurred out hoi as the full image is stretched to fill the screen. Difference is quite noticeable. With that said, I'd still recommend a 1080P LED monitor, because for everything else its awesome
    None of those cards will let you game at full res now, let alone 1080P. So you just downgrade image quality settings if you don't want to lower the res. Your choice, the 460 is not a beast, but its a very good budget card
    ---------- Post added at 23:34 ---------- Previous post was at 23:33 ----------
    Actually so far all the games I've played, I played at full res and at max settings but no AA, but I'm sure I can't keep this up for long. Only the top performers can play any game at full res for the next 2 years.
    • Rakin the Devil's Gadgets
      • Gigabyte X58-USB3
      • Hitachi 1TB 7200 Rpm
      • A4tech Gaming Keyboard
      • A4tech X7 747H Gaming Mouse
      • BenQ 24x DVD-RW
      • Powerpac 1200VA x2
      • Windows 7 SP1 x64
      • Check Links in Sig..
      • 140+
      • 50+
    Jan 2011
    I suggest go for a GTX 460 (Gigabyte or ASUS or XFX whichever u can find) btw asus er GTX 460 Shesh so gigabyte ba xfx paite paro.....aar no there is no "future-proof" word in the world of computers..So get a GTX 460 n be happy wid it until u can...
    • error's Gadgets
      • None ; 18x DL SuperDrive
      • Mac Pro love.
      • 1 mbps
      • 1 mbps
    error's Avatar
    Boo.
    Whatever you do, PLEASE DO NOT BUY AN XFX GTX 460! Go for a Gigabyte or Asus one instead.
      • Gigabyte X58-USB3
      • BenQ 24x DVD-RW
      • Windows 7 SP1 x64
      • 140+
      • 50+
    Jan 2011
    Quote Originally Posted by error View Post
    I wouldn't actually mind getting it if i cant find ASUS......
      • MSI 880 GM-E41
      • Samsung 500 GB
      • A4 Tech
      • A4TECH
      • ASUS DVD-RW
      • AMD FTW!!!
      • Smile
      • 15-20
      • 15
    toukir95's Avatar
    Jan 2009
    Dhaka Cantonment
    Ya res komay khelar proshnoi ase na. So I have 2 options. 1 that u said lowering the gfx settings if needed rather than resu or 2 buying the 1600X900 resud monitor & be happy.
    ---------- Post added at 03:08 ---------- Previous post was at 02:59 ----------
    @Rakin the Devil I know right but I wont upgrade my PC again until the X720 or PS4 arrive.
    @error +100000 No way in the hell I will buy a XFX Card ever again. Dorkar hoile gfx card kinbo na tao xfx kintesina. 1bar XFX 8500 GT kina jothesto shikkha hoise >:O
    na na 1600x900 monitor kino na, get the 460 and lower the settings instead. You will LOVE the movies/shows on that monitor, ar pore kono console o kinle monitor e lagai full advantage paite parba.
      • MSI 880 GM-E41
      • Samsung 500 GB
      • A4 Tech
      • A4TECH
      • ASUS DVD-RW
      • AMD FTW!!!
      • Smile
      • 15-20
      • 15
    toukir95's Avatar
    Jan 2009
    Dhaka Cantonment
    Ta thik bolsen. Blu-ray Movies/HD TV Series Maximum Awesomeness e dekhar jonno 1080p monitor er bikolpo nai OHkay I'm buying the Samsung B2230 then. GFX card Asus or Gigabyte er ta paile 460 e nibo otherwise Ryans theke Sapphire 6850 nite hobe.
    ---------- Post added at 15:42 ---------- Previous post was at 11:00 ----------
    DAMN Jhamelay pore gelam...Ryans e matro 1ta 6850 ase...kalk porjonto thakbe kina k jane. Techview, Techno edge e 6850 or 460 konotai nai. PC Aid e 1ta 6870 ase but I dont wanna go to ECS. Ekhon BCS e r kon dokane 6850 or 460 pawa jabe? Any !dea would be very helpful.
    • samiulislam16's Gadgets
      • Core i7 860 2.93ghz
      • Sapphire HD7870 ghz dualX
      • Asus 22 inch LED MS228H
      • Realtech Hd 8 channel Audio
      • Creative 2.1
      • Newmen M560
      • Dilong usb controller
      • Samsung DVD writer
      • Sigma 640va
      • Good enough
      • Smile/BDcom
      • 150
      • 200
    samiulislam16's Avatar
    Go for trans 4GB RAM single one and 1TB HDD samsung
    Guess what??? scan it??:
    Good enough GAMING RIG
    HApPy GAMing
  1. Replies: 12
    Last Post: January 14th, 2011, 20:06
  2. Monk Continues to Bang UD ¤¤¤ !
    By Mad Monk in forum Warcraft III Replay Central
    Last Post: March 12th, 2010, 16:18
  3. Replies: 0
    Last Post: October 23rd, 2008, 02:49
Page generated in 0.30491 seconds with 14 queries.
