Thread: My Monitor not working ... HELP
    • ABDmaster's Gadgets
      • Intel Media Series DP35DP
      • Core2Extreme 3.0 GHz QX6850
      • Transcend 2 GB DDR2 800MHz
      • Samsung 1TB F1 + Western Digital 320GB Blue
      • ATi Sapphire HD4670 512MB
      • Asus 19" VW192T
      • Built-in 7:1
      • Logitech Rumblepad2
      • ThermalTake 500W TR2
      • Apollo 1000VA
      • Windows Vista SP2 32-bit
      • Spark
      • 20 to 30
    Uttara, Dhaka
    Default [FIXED] My Monitor not working ... HELP
    My monitor ASUS 19" VW192T suddenly stopped working today at 11am. The power button is not turning the monitor on. Tried changing power cable, still not working. It like it just simply died after a long service (3 Years, 4 months).
    When Electricity went out for 15 mins, I just had to shut down the PC. When Electricity came, I turned on my UPS, but no power light came to my monitor.
    My PC is fine.
    Now is there any way to fix the Monitor, maybe repair shop or do I have to buy new one? If I have to buy new one, suggest me a good 21".
    • Speed's Gadgets
      • Creative ZxR| Built In
      • ASUS DVD +/-RW
      • USPOWER 2000va Online UPS
      • Windows 10 Pro 64 bit
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    Default Re: My Monitor not working ... HELP
    Quote Originally Posted by ABDmaster View Post
    My PC is fine.
    i think ur monitor just died.
    in case of 21.5". go for asus ms228 21.5" full hd 1080p led @ 15,500 available @ ryanscomputer & global technology
    • Rakin the Devil's Gadgets
      • Gigabyte X58-USB3
      • Hitachi 1TB 7200 Rpm
      • A4tech Gaming Keyboard
      • A4tech X7 747H Gaming Mouse
      • BenQ 24x DVD-RW
      • Powerpac 1200VA x2
      • Windows 7 SP1 x64
      • Check Links in Sig..
      • 140+
      • 50+
    Jan 2011
    Quote Originally Posted by ЯV●Speed View Post
    +1 support...ASUS MS228H is the best at this price......
      • Asus 19" VW192T
      • Built-in 7:1
      • Apollo 1000VA
      • Spark
      • 20 to 30
    Uttara, Dhaka
    Thanks towsif.... monitor ta dekhei lobh hoitese... dekhi siggir kenar chestaa korbo.
    • acE.Shanny's Gadgets
      • Intel Core 2 Q8400 2.66GHz
      • 2*2GB 800bus DDR2 TRANSEND
      • 1TB+1TB+80GB
      • 17" LCD
      • Realtek built-in
      • Logitech G19
      • SteelSeries Sensei
      • 500W TT TR2
      • 800VA Rahmia Afroz
      • 10/10
      • 64kBps/128kBps
      • Half of Download Speed
    acE.Shanny's Avatar
    Dhaka, Bangladesh,
    Rest In Peace ASUS 19" VW192T 19/3/2011
    • EyE SpeeD | A.B.'s Gadgets
      • Gigabyte X58A-UD7
      • Core i7 930/ OC at 4.2 ghz
      • 3x2 GB Twinmos 1333
      • 500GB+1000GB Samsung
      • Gigabyte Radeon 5970 2GB GDDR5/ASUS GTX 570
      • 21.5 ASUS MS228 LED Monitor
      • Builtin 7:1
      • Thermaltake TP 850 Watt
      • ASUS 16x DVD ROM,LITE-ON 24x DVD Writer
      • 1200 VA Power pac
      • mazeda BD(Aftab IT)
      • Around 30
    EyE SpeeD | A.B.'s Avatar
    Dhaka, Bangladesh, Bangladesh
    My PC is fine.
    Maybe any LED monitor could be a better solution in these days like asus or samsung. but just dont focus only in higher contrast ratio in asus ms228 u will get abt 10000000:1 and other vendor maybe pretty similar but u will loss pixel pitch which is a very imp part of a LCD or a LED monitor. and also take the full hd 1080p... in 20000 u will get better LCD monitor than LED monitor.so make ur decision wisely.
      • Asus 19" VW192T
      • Built-in 7:1
      • Apollo 1000VA
      • Spark
      • 20 to 30
    Uttara, Dhaka
    Talk about revival. Its back... from the DEAD... .. My ASUS 19" VW192T has been revived from the grave .
    Gave the monitor to an electronics repair shop, basically saw they fixes some computer monitor & gave it a try. And they fixed it today. At home, its working fine. They just changed some broken Capacitors & a Drive and Tada its working. Took about 2K for the fix.
    Akta small Dukho jodio, ASUS er oi LED monitor kinaa hoitese na jehutu eita thik hoye gese. But anyway, I got my monitor back. I'm very happy.
    Well they did told me that in the future, don't keep it connected with any power source when not using it. Remove the power plug of monitor when not using. Because I sometimes kept the monitor turned on for long hours, like over 12 hours, thats why it happened. I'll be careful now.
  1. Want to Buy any working HDD / any working PSU
    By OoAIDoO in forum Shop - Gadgets
    Last Post: January 30th, 2011, 18:47
  2. some keyboard buttons not working
    By @bhi in forum Technical Support
    Last Post: November 20th, 2010, 00:28
  3. Just Cause 2 stopped working error??
    By shohag2018 in forum Action-Adventure
    Last Post: April 20th, 2010, 23:29
  4. about full working Bengali........
    By Uchiha Obito in forum Feedback
    Last Post: January 19th, 2010, 23:07
  5. full working on pc without crash
    By s.a_rocky in forum Older NFS Games
    Last Post: August 10th, 2009, 21:53
Page generated in 0.19401 seconds with 14 queries.
