Thread: Connection problem
    Unhappy Connection problem
    Hi .. I am using BTCL ADSL for the last 8 months. From the last couple of weeks i have been having serious connection problems. The ADSL LED starts blinking every few minutes and the connection doesnt stay stable. Sometimes even after a stablr ADSL LED , i cant connect to the internet properly. It only works fine for 1 or 2 hours in a day but most of the time the problem persists. I have complained to the company but no avail. I am under the Chawkbazar circle. Is anyone else having this problem or am I the only one ??
    Noblesse Oblige
    • CvP's Gadgets
      • ASUS P8Z77 V Delux
      • Intel Core i7 3770K @3.9GHz
      • EVGA 980Ti 6GB
      • Samsung 17"+22"+22"
      • Realtek HD Audio <internal>
      • Creative Inspire 5:1
      • Razer BlackWidow Ultimate
      • G7
      • Seasonic X 850W 80Plus Gold
      • External DVD-RW
      • Link3/Amber IT
      • 10000
      • 10000
    CvP's Avatar
    Default Re: Connection problem
    hey Ahad.
    did you check your phone line noise? SNR? Attenuation?
    Well ... my phone line is perfect as i changed the wires a month back .. there is no noise whatsoever. However i have no idea about snr or anything...
    Product Name SmartAX MT882a Physical Address 00:24:d2:a2:78:00 Software Release V100R001B021 Firmware Release 3.11.2.142 Batch Number RTCAP0.021.3112142 Release Date 2009/02/13 ADSL Description ADSL State Show Time Data Path Interleaved Operation Mode G.lite Max. Bandwidth Down/Up(kbps) 3840 / 704 Bandwidth Down/Up(kbps) 3776 / 544 SNR Margin Down/Up(dB) 8.5 / 9.0 Attenuation Down/Up(dB) 41.0 / 24.5 Power Down/Up(dBm) 15.5 / 12.5 CRC Down/Up 58/ 4 FEC Down/Up 22899/ 1 HEC Down/Up 258/ 1 System Up Time 0:43:30 DSL Up Time 0:08:33 PVC Select
    PPP Up Time 0:00:00
    i logged in and got this.. i was advised to change adsl mode... can you plz interpret the numbers for me ..
    • shuvonabil's Gadgets
      • Gigabyte GA-Z170X Gaming 7
      • Intel Core i7 6700k 4.0GHz
      • 8GB DDR 4
      • Trascend 512GB SSD+Western Digital 4TB SATA
      • Samsung 32" 3D TV
      • Built in 24-bit/192KHz and 5.1
      • Logitech Z906
      • LEXMALK4800 USB GAMING
      • LEXMA M231 USB
      • none yet
      • THERMALTAKE 675W TPX-675MPCEU
      • SAMSUNG DVD RW
      • Digital X 1200VA
      • Windows 10 pro
      • Antaranga.com 10mbps
      • 1.2MB/s
    shuvonabil's Avatar
    Dec 2009
    Shegunbagicha
    Check your splitter, mine was broken and I was facing similar problems
    once my friend even faced similar kind of problem for 3 months, eh then changed his adsl modem tarpor it was working fine !!!! so its better tumi tmr onno frnd ba neighbor er modem nia try koro ekbar
    ya modem or spitter ei probs!
    • shakhawat's Gadgets
      • Gigabyte
      • AMD FX 6100 Bulldozer
      • DDR3 8 GB
      • 500 GB SATA
      • Geforce 550Ti Overclocked
      • 18.5 Inch LED
      • A4 Tech
      • A4 Tech
      • Apollo
      • Windows 7 SP1
      • Great Deal
      • BTCL ADSL
    shakhawat's Avatar
    May 2011
    Azimpur, Dhaka
    Change your ADSL Operation Mode from G.lite to G.dmt
    **Login to modem configuration http://192.168.1.1 may be
    This might help you, Not 100% sure
  1. BTCL ADSL Connection Problem
    By austin in forum BTCL
    Last Post: March 23rd, 2012, 13:08
  2. FIFA 11 Connection timed out problem solved :D
    By nino90 in forum FIFA 11
    Last Post: August 3rd, 2011, 05:06
  3. BTCL ADSL connection PROBLEM !!
    By Saadmanheavy in forum BTCL
    Last Post: June 7th, 2011, 00:27
  4. Tracker connection problem
    By avas911 in forum File Sharing and Torrents
    Last Post: February 26th, 2011, 00:50
  5. PS3 Internet Connection Problem
    By shon_91 in forum PlayStation
    Last Post: September 20th, 2010, 14:02
Page generated in 0.19123 seconds with 14 queries.
