Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 66
Thread: Need help buying a i7 series PC...
    • salmanshah's Gadgets
      • MSI Z97 Gaming 5
      • i7-4790K - Cooled by Corsair V8 GTS
      • G.SKILL Trident X Series 2400MHz 32GB (4 x 8GB)
      • Samsung 850 EVO 250GB SSD (2TB + 3TB HDD)
      • MSI GTX 970 GAMING 4G
      • Sony KDL-32W654
      • Sound Blaster Z PCIe Gaming Sound Card
      • Sennheiser HD555
      • Thermaltake MEKA G-Unit
      • Steelseries Sensei
      • Microsoft Xbox 360 Wired Controller
      • Corsair TX650w V2
      • Power Saver 1200va
      • Windows 10 PRO Retail key
      • Winrar bench - 11085 KB/s @ OC CPU
      • Casing: NZXT Phantom 001W
      • Radiant Telecommunications
      • 6 - 24 Mbps
      • 6 - 24 Mbps
    salmanshah's Avatar
    Lalbagh
    Default Need help buying a i7 series PC...
    Hello guys,
    I am going to buy a i7 series Desktop PC. So I need help choosing my rig from Tech Gurus.
    Before that I should tell you what my need is.
    #:Video Encoding
    #:Multi-tasking(open ~40 tabs+MS Office+Gaming and small application)
    Here's my configuration chosen by me. Please suggest me if anything better than this is available in BANGLADESH.
    #1: CPU: AMD Phenom II X6 / Core I7 870 (It is overclockable?)
    #2: Mobo: Gigabyte H55M-D2H / ASUS P7H55-M (Support for at least DDR3 2200+/1800 memory modules )
    #3: RAM: I will buy it later. Until then 'will use my existing RAM.
    #4: GPU: I want to buy 460 GTX (Is there anything better than that available in BD?) / Should I buy AMD 6xxx?(want to SLI/CFX)
    #5: SSD: 64GB / 128Gb (Windows+Gaming) [I already have 1 TB and 320GB HDD]
    #6: PSU: I don't know which one will be better or required for me.
    #7: Casing: I want a hunky punky Casing with lighting.
    So Gurus pls suggest me a more better configuration which are available iin BANGLADESH.
    I need it urgent with in a week. There is a chance that I will buy it tomorrow. Budget is not a factor(100k). I want spend anything for my CPU and mobo.
    Thanks in advanced.
    Updates:
    Here's the configuration I bought with the price:
    AMD Phenom II X6 1090T = 19800
    MSI 980GXM-G65 = 11000
    ADATA XPG 2GB DDR3 1666MHz = 3000
    GIGABYTE SUMO 5112 casing = 13500
    PSU Deluxe 450w = 1500
    Liteon DVDwr with labeltag = 1600
    Total = 50400
    Rest are existing one
    GA 890FX paini
    GPU, Cooler and PSU abroad thekay anar chinta bhabna korsi.
    and I dont need SLI now.
    Default Re: Need help buying a i7 series PC...
    Better if you post your budget first
    Cleveland, Ohio.
    I recommend this configuration for ur new rig.
    CPU: Obviously AMD Phenom II X6, bang for the buck
    Mobo: ur listed mobos doesn't support amd processor get this MSI 890GXM G65 mobo instead
    GPU: Get, GTX 465/Radeon 6870/Radeon 5870 (best choice)
    SSD: 128GB SSD but add up 1 terabyte 7200rpm hard drive with that for some redundancy
    PSU: Thermaltake 550 watt will be good enough for one graphics card may need 600watt depending on the gpu but if ur planning to use crossfire or sli get XFX 750 watt instead
    Casing: Get a gigabyte isolo or sumo casing for showing off the beast
      • MSI Z97 Gaming 5
      • Sony KDL-32W654
      • Sennheiser HD555
      • Corsair TX650w V2
      • 6 - 24 Mbps
      • 6 - 24 Mbps
    salmanshah's Avatar
    Lalbagh
    Only i7 870 is avalable in BD? nothing more than that?
    Thank you nhrabbi. I liked your configuration. Where can I get this rig? from which shop?
    • codename5302's Gadgets
      • Gigabyte X99-UD5 Wifi
      • Zotac 980Ti Amp Extreme
      • Fiio Andes E07K
      • Corsair RM850
      • 2 * Prollink 1200VA
      • Windows 7 64Bit
      • It works!!
      • 154
    codename5302's Avatar
    if you are after core i7 870 then there is no need for high speed rams. high speed ram doesnt have significant impact on newer core i7 processors. again think about ssds. they seem lucrative but as far as i know, the more you use the slower a ssd performs. initial speed is great but look at performance of dirty ssds (i mean heavily used). and look for newer controllers (sandforce 1200, marvell etc.) if you are buying ssd.
    Cleveland, Ohio.
    Quote Originally Posted by salmanshah View Post
    @salmanshah The configuration i mentioned above is based on the products available on BCS computer city. But if u want to buy all this stuff from all in one place i recommend you "Ryans Computer". And you can also find other core i7 models in bd not just 870.
    Anyway Glad to help!
      • MSI Z97 Gaming 5
      • Sony KDL-32W654
      • Sennheiser HD555
      • Corsair TX650w V2
      • 6 - 24 Mbps
      • 6 - 24 Mbps
    salmanshah's Avatar
    Lalbagh
    I want to buy a faster CPU available in BD. pls sm1 tell me which would be better.
    and which GPU should I buy? GTX 465/Radeon 6870/Radeon 587. Are they all perform same? is there anything better than these?
    which SSD would perform better? and whats the price.
    thanks for helping me out.
    I think you should get a better card, one more appropriate of your budget. If I were you I wouldn't go below a 6950/570.
    Cleveland, Ohio.
    Radeon 5870 is significantly faster GPU out of these 3. For details, check ur pm which i sent u.
      • MSI Z97 Gaming 5
      • Sony KDL-32W654
      • Sennheiser HD555
      • Corsair TX650w V2
      • 6 - 24 Mbps
      • 6 - 24 Mbps
    salmanshah's Avatar
    Lalbagh
    570GTX is available in BD? As far as I know that all the cards are not available in BD or else I would have got 580 GTX and i7 2600k.
    So you tell me what should I do.
    • error's Gadgets
      • None ; 18x DL SuperDrive
      • Mac Pro love.
      • 1 mbps
      • 1 mbps
    error's Avatar
    Boo.
    Gigabyte GTX 580 is available at Smart, and they are asking 40k for it. Sapphire HD 6970 is also available in UCC for around 33k.
    And in my opinion, as budget is not a huge factor, you should check out the market first. Coz amra suggestion dile oi product ta market e available na o thakte pare, or we might not know about the recent imports :/ You can get proper ideas about what you should get if you can check out the market a bit
    ---------- Post added at 16:00 ---------- Previous post was at 15:59 ----------
    And about Sandy Bridge processors, even if they are available, the motherboard issue will be a great pain in the arse :/
    • Frank3nst3in's Gadgets
      • MSI 760GM-P33
      • AMD Athlon II X4 640
      • Samsung 500GB F3, WD Blue 1TB, Seagate Barracuda 1TB, Hitachi 160GB
      • ECS EliteGroup GTX 550Ti
      • ASUS VX229H 21.5
      • Creative SB X-Fi Titanium
      • Panasonic HTF600, SoundMagic E10
      • CM Storm Devastator MS2K
      • CM Storm Devastator MB24
      • Windows 8.1
      • 64 KBps
    Frank3nst3in's Avatar
    Check some benchmark of Phenom II X6,if you think,it can perform then buy it.
    And get a good motherboard even it has to be pricey.And MSI 890GXM G65 doesn't support RAM more than 16GB and SLI isn't available in that mobo but CFX is.Besides all of these,it's not bad.For the whole spec Check this
    I don't think you'll get i7 2600k in BD in this week.And I wouldn't buy SB if I were you.
    If you want a REAL MONSTER and if you don't have any budget and other restrictions then I would suggest you to get a i7 EXTREME
    And please buy at least 650-750W PSU.
      • MSI Z97 Gaming 5
      • Sony KDL-32W654
      • Sennheiser HD555
      • Corsair TX650w V2
      • 6 - 24 Mbps
      • 6 - 24 Mbps
    salmanshah's Avatar
    Lalbagh
    i7 extreme is avalable in bd?
    Cleveland, Ohio.
    Yeah, but kinda rare. As, you said you dont have any budget restriction then why not go for the i7 extreme if not the phenom II X6 is the best bet cuz extremes cost a lot like the GTX 580 & Radeon 5970.
      • MSI Z97 Gaming 5
      • Sony KDL-32W654
      • Sennheiser HD555
      • Corsair TX650w V2
      • 6 - 24 Mbps
      • 6 - 24 Mbps
    salmanshah's Avatar
    Lalbagh
    Then what about this?
    AMD Phenom II X6 1090T/1100T(if available)
    Motherboard I don't know which would be good.
    GTX 580 (as fas as i know 5970 has some tesseleation problem, also gets hang while playing some games.)
    SSD- buy the one available in BD.
    PSU 750w (as everyone mentioned)
    GIGABYTE SOMO casing
    is it ok?
    Cleveland, Ohio.
    is it ok?
    Nice rig but the mobo i mentioned earlier is the best choice for the amd processor i.e MSI 890GXM G65. It should be around 11,000TK and it has crossfire support and all the other things u need. And dont worry about that amd processor they are vastly available at the moment and selling like hot cakes Go for it now i guess
    Edit- Its better to go for an Radeon graphics card on this rig rather than the nvidia one cuz no sli support on the motherboard and the whole amd architecture suits the radeon gpu. Get, Radeon 6970 instead of GTX 580 cuz it doesnt have tessellation issues.
      • MSI 760GM-P33
      • ASUS VX229H 21.5
      • Windows 8.1
      • 64 KBps
    Check the specs of the mobo before buying.
    And if you buy Phenom,it would be good for you to buy a Radeon card too.You can check the Vision Technology.
    And i7 EXTREME would be the best option.
    ---------- Post added at 20:11 ---------- Previous post was at 19:04 ----------
    And mind you,for cooling you would need an after market cooler if you wanna OC hard
      • MSI Z97 Gaming 5
      • Sony KDL-32W654
      • Sennheiser HD555
      • Corsair TX650w V2
      • 6 - 24 Mbps
      • 6 - 24 Mbps
    salmanshah's Avatar
    Lalbagh
    which cooler would be better? which 1 should I get? I don't have any idea on aftermarket cooler.
      • MSI 760GM-P33
      • ASUS VX229H 21.5
      • Windows 8.1
      • 64 KBps
    TT Frio is available.
    But if you can manage coolmaster or something that would be better I guess and I don't have much idea :/
    Mentioning @error and @Rakin the Devil for suggestion.
    • Rakin the Devil's Gadgets
      • Gigabyte X58-USB3
      • Hitachi 1TB 7200 Rpm
      • A4tech Gaming Keyboard
      • A4tech X7 747H Gaming Mouse
      • BenQ 24x DVD-RW
      • Powerpac 1200VA x2
      • Windows 7 SP1 x64
      • Check Links in Sig..
      • 140+
      • 50+
    Jan 2011
    TT Frio is all u can get frm here but if u wanna get it frm aboard get a Megahalems......
  1. help for buying GT series graphics card??
    By superhuman in forum GPU
    Last Post: January 17th, 2011, 14:58
  2. Want to Buy Core 2 Quad 8XXX series or Core 2 Quad 9XXX series processor
    By EBL.Mantis in forum Shop - Gadgets
    Last Post: December 2nd, 2010, 09:22
  3. Closed 21/22 inch LCD with hd4800 series/gtx 270 series up
    By warriorfist in forum Shop - Gadgets
    Last Post: October 4th, 2009, 01:31
  4. Asus Formula Series!!!
    By kabir_sharif2000 in forum GPU
    Last Post: June 23rd, 2009, 19:42
  5. Replies: 5
    Last Post: October 23rd, 2008, 02:11
Page generated in 0.31903 seconds with 14 queries.
