Thread: cpu temperature problem
    Default cpu temperature problem
    plz help my cpu normal temp 25-26 degree celcius but when i play games it reaches 44 degree c.im using tharmaltake spin Q cpu cooller and core i3.is it normal?
    • abir's Gadgets
      • Realtek Builtin Audio
      • Creative Inspire 2.1
      • A4tech 7K Office (USB)| HP
      • Deluxe DLP 388A 450W
      • 4GB Apacer Pendrive
      • OVO 650VA
      • Smile Internet (Bronze)
    abir's Avatar
    Azimpur
    Default Re: cpu temperature problem
    @Swapan Roy
    Its absolutely normal, don't worry
    I bleed red, Man Utd 4ever..
    plz can u tell me, maximum temp of core i3 2.93ghz
    • sumonpathak's Gadgets
      • GA-Z68X-UD4-B3/GA-G31M-ES2L / Asus M4A785T-M
      • Core [email protected]/Core 2 Duo E7500 @ 3.46Ghz /AMD Phenom II X4 965BE @ 4.1GHZ[benched]
      • Corsair gaming memory 800mhz @ 5-5-5-18 / Corsair Value select 1333 mhz running @ 1800mhz 7-9-97-20
      • 500 gb +500gb+160 gb+160gb+160gb
      • HD6870
      • AOC 22" inch/ samsung 933 18.5' / lg 15' CRT
      • TX 650 v2/FSP Saga II 400w / Cooler master 460w
      • Windows seven ultimate 32bit
    sumonpathak's Avatar
    Jan 2011
    i guess you already have core-temp to monitor the temp......anything near the 90c is alarming.....ur temp is absolutely normal.......
    yes i have and it shows tj maximum temp 105 degree c
      • HD6870
    Jan 2011
    then you are all set....dont worry bro,,,the temps are normal
    • Rakin the Devil's Gadgets
      • Gigabyte X58-USB3
      • Hitachi 1TB 7200 Rpm
      • A4tech Gaming Keyboard
      • A4tech X7 747H Gaming Mouse
      • BenQ 24x DVD-RW
      • Powerpac 1200VA x2
      • Windows 7 SP1 x64
      • Check Links in Sig..
      • 140+
      • 50+
    Jan 2011
    its really very normal....
    • eXsTatik's Gadgets
      • Msi 990FXA GD80
      • Phenom x6 1090T @ 4ghz 24/7
      • 8gb drr3 1600mhz
      • 500GB x2 raid 0 + 1TB caviar black + 500GB wd passport.
      • GTX 580
      • Syncmaster 2243
      • X-fi titanium
      • 2x microlab solo 7c front and back, 2 x microlab FC subs + pro 1 as center
      • Razer blackwidow
      • Razer imperator/deathadder/a4tech x7/razer boomslang 2007CE/ Razer Abyssus
      • xbox 360
      • 850 Toughpower Thermaltake
      • Glasses.
      • Generator that runs on oil downstairs with 24/7 backup
      • Windows7 64 I still dont really care.
      • Yes if you are wondering I am AMD fanboyish :/. LOL
      • link 3
      • 142
    eXsTatik's Avatar
    Beyond reality
    Maximum temps 105 ? wth, download HW monitor, somtimes bugs in the bios may cause irrational readings ? 44degrees is a fine temp, but 105 ? whats that about ? did you apply the thermal compound properly ?
    FTW!!!!!!!!!!
    • Speed's Gadgets
      • Creative ZxR| Built In
      • ASUS DVD +/-RW
      • USPOWER 2000va Online UPS
      • Windows 10 Pro 64 bit
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    Quote Originally Posted by THE_ZULK View Post
    that's tj max.the maximum burning temp for cpu. it's calculated by identifying each cpu code on real temp. however some people reports that it's not accurate at all
  1. CPU Temperature Measurement
    By gamefreak in forum Technical Support
    Last Post: January 27th, 2011, 01:06
  2. CPU Over temperature!
    By Dee in forum CPU
    Last Post: October 22nd, 2010, 00:06
  3. Replies: 15
    Last Post: June 14th, 2010, 07:42
  4. CPU problem
    By Codename-Scorpion in forum Technical Support
    Last Post: November 26th, 2009, 00:34
  5. E5200 temperature problem
    By shahriar in forum CPU
    Last Post: June 8th, 2009, 12:00
Page generated in 0.20802 seconds with 14 queries.
