Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 53
Thread: Need help regarding RAMs.
    • shohag2018's Gadgets
      • Gigabyte H55M-USB3
      • Intel Core i7 860 OC'[email protected] 3.5ghz (TT Frio OCK).
      • a-DATA 8GB 1333MHz
      • Samsung evo 250gb SSD+1 TB 7200rpm
      • Zotac GTX 970 OC
      • Sony Bravia 26inch
      • Creative 5.1 ll Nokia BT stereo 503 ll Nokia BT Stereo 505
      • A4tech bloody b314
      • A4tech bloody v3m
      • Xbox 360 wired original
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Windows 10 pro x64
      • Cinebench r15- 600, Unigine valley- 54fps
      • Going under renovation, Next is CPU-mobo!
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    Default Need help regarding RAMs.
    I have 2x2GBs,(on slot1 and slot 3) of 1333mhz rams on my H55 Mobo. Now i have a few questions.
    1. I use windows 7x64 OS...and even @idle desktop my pc uses up 1.37 GB minimum. is that normal, or too much?
    2. Since the DDR3 rams are cheap ryt now ( im not sure how long the price will stay like this), i was thinking of Buying 2GBs extra, but is it really needed?
    3.if i get 2 GBs more, will i be able to use it on triple channel ?and if it does then how much of an advantage is it?
    • RonzDrive's Gadgets
      • ECS H61H2-M2 B3 Stepping
      • Intel Core i3 2100 SB
      • Transcend 2x2 GB DDR3
      • Hitachi 500 GB SATA 2
      • ECS GTX 550 Ti 1 GB DDR5
      • Acer 18.5'' LED
      • Creative Inspire 2500 2.1
      • PS2
      • PS2
      • Tt TR2 RX 450W (Modular)
      • External
      • Windows 7 Ultimate (64-bit)
      • 3DMark 11 Score P2740
      • Happy with it
    RonzDrive's Avatar
    Default Re: Need help regarding RAMs.
    1. The usage seems a bit on the higher side, is there other background program running? it can determine by Task Manager. Also CPU and memory usage varies upon antivirus program, as some needs more resource than others. For example i previously used AVAST 5 that seems needed less resource than NIS 2010 that i m using now. Still the usage barely cross 800 mega in idle for me(win 7 x86 version). If possible run a full system scan with latest antivirus definition.
    2. 4 GB is already good, adding 2 GB more will only be benefited for heavy gaming and multitasking.
    3. Triple channel setup for memory will definitely speed things up(but again mostly for heavy level gaming). But it may also depends on the mobo.
    • error's Gadgets
      • None ; 18x DL SuperDrive
      • Mac Pro love.
      • 1 mbps
      • 1 mbps
    error's Avatar
    Boo.
    Yes, as your using Win 7, 1.37GB is sorta normal :/ if you want, you can buy another 2gb's. but would be better if you can buy a 4gb stick for noticeable performance increases
    • abir's Gadgets
      • Realtek Builtin Audio
      • Creative Inspire 2.1
      • A4tech 7K Office (USB)| HP
      • Deluxe DLP 388A 450W
      • 4GB Apacer Pendrive
      • OVO 650VA
      • Smile Internet (Bronze)
    abir's Avatar
    Azimpur
    Quote Originally Posted by shohag2018 View Post
    tagging AmareX Muradd9 proton_chain for help.
    add 2 GB RAM then u will get double bandwidth for ram
    and for win7 600-800MB is normal..
    I bleed red, Man Utd 4ever..
      • Zotac GTX 970 OC
      • A4tech bloody v3m
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    Quote Originally Posted by abir View Post
    so i should get 2x2GB more and run quad channel?
    and disable extra services from msconfig for rams?
    • Rakin the Devil's Gadgets
      • Gigabyte X58-USB3
      • Hitachi 1TB 7200 Rpm
      • A4tech Gaming Keyboard
      • A4tech X7 747H Gaming Mouse
      • BenQ 24x DVD-RW
      • Powerpac 1200VA x2
      • Windows 7 SP1 x64
      • Check Links in Sig..
      • 140+
      • 50+
    Jan 2011
    1 stick - Singe Channel
    2 sticks - Dual Channel
    3 sticks - Triple Channel
    4 stick - Dual Channel
    5 sticks - Single Channel
    6 sticks - Triple Channel
    Its like this...& yes Heavy Multitasking & Heavy Gaming will be benefited as it will get more bandwidth but i dont really thik its nessecary & yes 1.37 GB is ok mine uses 1.8GB @ idle also..
    ---------- Post added at 23:41 ---------- Previous post was at 23:41 ----------
    its recommended to use a even config...like 2,4,6,8..
      • Zotac GTX 970 OC
      • A4tech bloody v3m
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    Quote Originally Posted by RonxGamer View Post
    i am running AVG professional.. i unchecked unnecessary services and selected selective start-up from msconfig.. wasnt much of a help...still over 1 GB...i guess thats normal for 64 bit..
    is 4GB enuf for crsysis 2? my promary concern is to play that game properly..i think my motherboard can handle 8 GBs of ram.
    ---------- Post added at 23:43 ---------- Previous post was at 23:42 ----------
    Quote Originally Posted by Rakin the Devil View Post
    thanks.. exactly what i needed to know.
      • Gigabyte X58-USB3
      • BenQ 24x DVD-RW
      • Windows 7 SP1 x64
      • 140+
      • 50+
    Jan 2011
    is 4GB enuf for crsysis 2? my promary concern is to play that game properly..i think my motherboard can handle 8 GBs of ram..
    Its normal 32-bit os uses less rams & 64-bit uses more RAM for program compatabitliy i guess.....nd crysis 2 er bapar ta to bola jacche na until it releases ajaira hope diye to aar lavv nai.....yes if it have 4 slots then 16GB handle kortey parbe ATM...in future we can expect bigger Memory in 1 stick....dun worry wid 4GB Ram u can Run any Game till date & still hav memory to spare...in game approx my 3GB gets used...But I myself will be getting 1 stick more not for crysis 2 but for the benifits of triple channel & he truth is u cant multitask bcoz of slow Hard Drives....SSDs are gr8 multitaskers bcoz i have a gr8 processor but i cant still multitask bcoz of my HDD....Only games can take advantage of the extra RAM as multitasking is BS on HDDs....
    • Mazhar's Gadgets
      • ASUS B250 Strix
      • AMD Ryzen 1700X
      • G.Skill 2x8GB DDR4 3200
      • Samsung 850 Pro 1TB
      • Gigabyte 1070Ti
      • Dell U2711
      • ASUS Essence STX II
      • Beyerdynamic Tesla T1
      • G910
      • G502
      • Xbox One Controller
      • Windows 10 Home
      • Aamra
    Mazhar's Avatar
    You cant use triple channel. LGA 1366 is triple channel, LGA1156 is limited to dual channel. Id say 4GB is enough, and 1.37GB is a bit on the high side unless you have many startup applications running.
    • proton_chain's Gadgets
      • Gigabyte GA-P55-UD3
      • 4x4GB DDR3-1600MHz
      • 6.5TB (3TB+2TB+1TB+.5TB)
      • Nvidia Geforce GTX 760 4GB
      • Samsung Syncmaster 22 inch
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
      • Sony Optiarc DVD burner
      • Blue Yeti USB Microphone
    proton_chain's Avatar
    That's completely normal, nothing to worry about. If you disable pagefile (NOT recommended with only 4 GB RAM), you will see much higher usage. And it is 64-bit OS so it, itself eats more memory than 32-bit OS does. It will simply keep more programs in your RAM so that you do not have to wait for it to be fetched from the disk provided that you have enough free memory. If you run a demanding app, the OS will automatically swap less important programs to the pagefile. For example, my RAM usage is 2.12 GB right now (I don't use pagefile, that's why).
    No, its not really needed at all, especially not for games as of now. Like I said, its only going to give you the freedom of disabling pagefile offering you a much faster experience (because of virtually no disk usage unless you run a program). More RAM equals more headroom for multitasking, insanely high resolution photo editing, video editing and rendering. Other than that, its useless. You have to choose which way to go.
    H55 chipset has dual channel memory controller. You cannot run triple channel. Only dual channel.
    You tagged me in the wrong way, that's why I did not notice earlier. You have to use the following code:
    Code:
      @member_id
    • Mazhar's Gadgets
      • ASUS B250 Strix
      • AMD Ryzen 1700X
      • Gigabyte 1070Ti
      • Dell U2711
      • G910
      • G502
      • Windows 10 Home
      • Aamra
    Mazhar's Avatar
    Quote Originally Posted by proton_chain View Post
    H55 chipset has dual channel memory controller. You cannot run triple channel. Only dual or quad channel.
    Theres no quad channel memory in LGA1156. Unless you mean simply populating 4 channels. Technically, that would still be dual channel bandwidth
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
    Quote Originally Posted by Mazhar View Post
    Sorry, I meant quad stick dual channel (instead of dual stick dual channel), my bad.
    And there is also no "quad channel" memory controller in any desktop system AFAIK.
      • Gigabyte X58-USB3
      • BenQ 24x DVD-RW
      • Windows 7 SP1 x64
      • 140+
      • 50+
    Jan 2011
    oops my mistake H55 & P55 also maybe doesnt have triple channel...btw @proton_chain how much ram do u have??
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
    Not "maybe", they do NOT have triple channel. But beware, next gen is coming with quad channel memory (Bulldozer chips are rumored to have support for quad channel, but I did not further investigate).
    btw how much ram do u have??
    8 GB (4 sticks of 2 GB RAM), you could've checked my gadgets and got the answer instantly instead of asking.
    • error's Gadgets
      • Mac Pro love.
      • 1 mbps
      • 1 mbps
    error's Avatar
    Boo.
    Checking the gadgets won't increase post counts you know xD
      • Gigabyte X58-USB3
      • BenQ 24x DVD-RW
      • Windows 7 SP1 x64
      • 140+
      • 50+
    Jan 2011
    hey alot of ppl dont update thir gadget list so i asked...
      • Zotac GTX 970 OC
      • A4tech bloody v3m
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    Code:
      @member_id
    Thanks. so my only option is to buy two more sticks and run the dual channel, or just stay as it is now. am i correct?
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
    Yes. I also explained the "few" advantages of more RAM. There is no need for more RAM unless you know what it does. The sectors I have mentioned get massive boost in performance from more RAM but if are not interested in these sectors, then investing in more RAM will be a complete waste of money.
    • abir's Gadgets
      • OVO 650VA
    abir's Avatar
    Azimpur
    @shohag2018
    You should get atleast 4GB ram for win7x64bit for gaming.
    for single channel the ram bus width is 64bit.
    for dual channel the ram bus width becomes 128bit, so u will get double bandwidth
    But if your CPU is bandwidth is less than the bandwidth of your single channel u wont get any advantage regarding speed.
    But as you have good cpu i hope dual channel will give you lot better performance
    I don't think your motherboard support quad channel ram
    And no need to disable service from msconfig if you have 4GB ram.
    Instead you can turn off some applications start up with windows.
    Such as my windows only starts ATi catalyst with startup.
    I start the other softwares when i need them.
    So, don't disable service, but u may turn off start up applications.
    ---------- Post added at 18:45 ---------- Previous post was at 18:40 ----------
    See the difference in Single Channel & Dual Channel RAM for my CPU.
    As my CPU bandwidth is less than dual channel bandwidth so I didn't get much improvemnt
    Though its better than single channel for me atleast
    My RAM windows rating is now 6.6 which was 5.5 when single channel.
    Single:
    Dual:
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
    His memory modules are actually running in dual channel mode right now (he asked if he should ADD another 4 GB over the currently existing 4 GB).
  1. 800 mhz rams 6-6-6-18 timing too bad??
    By shohag2018 in forum Others PC Hardware
    Last Post: January 31st, 2010, 19:53
  2. Closed 256MB x 2 DDR1 RAMS
    By SP|WeRewOLF in forum Shop - Gadgets
    Last Post: December 1st, 2009, 02:00
  3. Mushkin RAMs & PSUs Coming to BD?
    By LORÐ in forum Others PC Hardware
    Last Post: November 23rd, 2009, 19:51
  4. Closed 2 HDDs and 3 RAMs.
    By Uchiha Obito in forum Shop - Gadgets
    Last Post: November 9th, 2009, 23:02
  5. Sale (Used) Harddisks & Rams
    By saadbillah in forum Shop - Gadgets
    Last Post: October 8th, 2009, 22:05
Page generated in 0.33472 seconds with 14 queries.
