Thread: Need Help Buying A Samsung LED 3D TV from Abroad
    • Raihan081's Gadgets
      • Asus Maximus VI Hero
      • Intel Core i7 4770k
      • Corsair Dominator Platinum 4x4GB DDR3-1866
      • WD 3TB Red, 256GB Samsung 840 Pro Series
      • EVGA GTX 780 Ti SC Dual Classified ACX in SLI
      • Samsung UD590 UHD
      • Turtle Beach - Call of Duty Spectre
      • Razer Deathstalker Ultimate
      • SS Kana Ltd Ed. Dota 2
      • Corsair AX1200i
      • Windows 8 64 bit
      • Tellus
      • 6656
      • 1536
    Raihan081's Avatar
    Default Need Help Buying A Samsung LED 3D TV from Abroad
    Hi, I have a Samsung LED TV UN40C6900 which is not 3D. But now I am looking for Samsung 3D TV. And my budget is around 200000tk.
    http://www.amazon.com/Samsung-UN46C8000-Resolution-Technology-HyperReal/dp/B003XKRIZ4/ref=sr_1_5?s=electronics&ie=UTF8&qid=1296317451&sr=1-5
    Bundle @ $ 1997
    Ok my other options. I will opt for this two -
    Samsung UN40C7000 LED 3D TV -
    http://www.amazon.com/Samsung-UN40C7...6316995&sr=1-4
    Bundle @ $ 1397.
    http://www.amazon.com/Samsung-UN46C7...317914&sr=1-10
    Bundle @ $ 1697
    So any of the above products will be fine for me. Ami nijei antam but jake diye anabo shei akhon Bangladesh e. And he wont be going abroad for sometime.........
    My budget is $ 2570 - $ 2857.
    So any of the above products will be available i think including shipping.
    And oh ha obviously je help korbe i will provide him his charge for helping......... $ 200 - 300. I promise.
    Thanks in advance mates.
    ---------- Post added January 30th, 2011 at 01:30 ---------- Previous post was January 29th, 2011 at 22:23 ----------
    no reply?
    • Mohiuddin's Gadgets
      • Xeon X5650
      • 8gb gskill ripjaw
      • Western Digital 1TB blue
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Gigabyte 1200w OdinPro
      • Apatoto nai
      • Netvision
      • Janina, 3Mbps may be
      • Don't upload...
    Uttara,dhaka
    Default Re: Need Help Buying A Samsung LED 3D TV from Abroad
    Are vhai, money keno?all of us r here to help each other as friends.it is kind of odd looking.
    amar oto idea nai.but,i saw some samsung 3d tv in uttara all r >3lac.and prefer sony over samsung.
    and if u want, i can talk to a dealer(only Sony) i know.and can cut a lot price.but, i m not so sure , does they import 3dtv or not.
      • Samsung UD590 UHD
      • Corsair AX1200i
      • Windows 8 64 bit
      • Tellus
      • 6656
      • 1536
    Raihan081's Avatar
    well mohiuddin vai money ta ami khushi hoyei dite chaisi.n vai jai bolen na keno nothing can beat samsung 9000 series 3d tv. N samsung prefer kori vai coz 2d ke 3d te convert korte pare samsung. Tai.n sony monolothic sara 3d nai maybe. Thakleo slim na. Lcd. Bt ami led prefer kortesi. Present jeta ase otao kharap na bt 3d gaming is all i need mohiuddin vai. N vai abroad theke anle anek kom porbe.bd te anek cost ai tv gular.
    • fishd990's Gadgets
      • Intel DH55HC
      • 2 GB DDR3
      • Samsung HD322HJ (320 GB) & Transcend Storejet (TM)25 Mobile (160 GB External)
      • Sapphire HD 5770 1 GB DDR 5
      • Samsung Syncmaster 2243BWX (22")
      • ATI High Defination Audio Bus
      • Microlab 2:1
      • Logitech K400
      • Logitech K400
      • XBox 360 Controller for PC (Chinese)
      • Thermaltake TR2- 500 W
      • Bluetooth, Printer (HP Laserjet 1010), Scanner (HP Scanjet 4370)
      • 800 VA (Gives upto 15 Min to my PC)
      • Windows 7 Ultimate
      • BTCL Broadband 256 Kbps
      • 60 (Avarage)
      • 30 (Avarage)
    fishd990's Avatar
    I don't know much about 3D TVs but this much i can say that, look for a TV with active shutter glasses, It way better than Polarized glasses. Though each pair of glasses can cost 150$
    • Dee's Gadgets
      • Asus Maximus VIII Ranger
      • Intel Core i5 6600k
      • Dell S2216H
      • Cooler Master V650 Gold
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    Well you can get the Samsung UN46C7000 LED 3D TV. The C6900 is 46" too, so as you are not buying that because it is not 3D, I would suggest you to buy the UN46C7000, you'll get both 3D + 46". I guess you would definitely want a 46" screen, right? If yes, you can consider buying the one I suggested.
  1. Samsung SyncMaster BX2250 21.5" LED monitor....is it available in BD ???
    By Codename-Scorpion in forum Help - General Shopping
    Last Post: January 4th, 2011, 22:13
  2. Suggestion on buying 18.5 LED LCD
    By Diego Maradona in forum Help - General Shopping
    Last Post: January 3rd, 2011, 01:19
  3. Suggestion for Buying LCD/LED Monitor
    By SadIkMahdI in forum Others PC Hardware
    Last Post: December 9th, 2010, 02:09
  4. Help me buying a good LCD/LED monitor(budget 18k)
    By showdown_king in forum Others PC Hardware
    Last Post: June 12th, 2010, 17:10
Page generated in 0.17808 seconds with 14 queries.
