Thread: Assassins creed installation problem
    Default Assassins creed installation problem
    I seem to have a lot of problems in installing this game because whenever I start the installation it says "do you want to uninstall assassins creed 2 from your computer?" but I don't even have it installed yet, this happened because I deleted the Assassins creed folder instead of uninstalling it and now I am trying to reinstall it but I cant because of the problem! help somebody please!
    I already tried Revo but it didn't fix the problem. I need help fast please!
    Jan 2011
    Chittagong
    Default Re: Assassins creed installation problem
    if u didnt intall anything important recently i suggest a system restore. restore to just the time before u deleted it. hope it helps
    cant do that because if I do Im gonna have to delete important files and some of them are confidential and its a lot of them I wont be able to remember if there is a solution to the installation problem please I need it to be efficient since I have gone a lot of useless solutions if you think you cant help you're wrong can you find an expert for this? that way you can help
    • proton_chain's Gadgets
      • Gigabyte GA-P55-UD3
      • 4x4GB DDR3-1600MHz
      • 6.5TB (3TB+2TB+1TB+.5TB)
      • Nvidia Geforce GTX 760 4GB
      • Samsung Syncmaster 22 inch
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
      • Sony Optiarc DVD burner
      • Blue Yeti USB Microphone
    proton_chain's Avatar
    Quote Originally Posted by josh4rocks View Post
    System restore does not touch your personal files. It just restores a shadow copy of your registry and some important system files. But if you are still confused, back up important files before proceeding. This process is also reversible.
    Never do such a thing again. You may want to get the game directory form a friend and place it where it is supposed to be. Then you just uninstall it and reinstall it.
    You may also delete the registry values to trick your OS into believing that Assassin's Creed never existed in your system. To do that, open registry editor, select "Computer" and do a search for "Assassin". Then find and delete all the strings having an "Assassin" in it. It requires advanced knowledge about the registry interface though.
    • codename5302's Gadgets
      • Gigabyte X99-UD5 Wifi
      • Zotac 980Ti Amp Extreme
      • Fiio Andes E07K
      • Corsair RM850
      • 2 * Prollink 1200VA
      • Windows 7 64Bit
      • It works!!
      • 154
    codename5302's Avatar
    dont need to do system restore. type regedit in cmd prompt. search for assassin's creed/ ubisoft registry in your pc. delete one by one (careful about other games). restart. otherwise download registry mechanic. and clean your registry.i hope in this way you can install AC again.
    • Rakin the Devil's Gadgets
      • Gigabyte X58-USB3
      • Hitachi 1TB 7200 Rpm
      • A4tech Gaming Keyboard
      • A4tech X7 747H Gaming Mouse
      • BenQ 24x DVD-RW
      • Powerpac 1200VA x2
      • Windows 7 SP1 x64
      • Check Links in Sig..
      • 140+
      • 50+
    Jan 2011
    Reinstall windows thats what i do every 30 days.....btw follow proton_chains method it should work.....
    • Overlord's Gadgets
      • Asrock Z370 Pro4
      • Geil 8GB DDR4 2400
      • MSI GTX 970 OC Gaming 4G
      • ASUS VX229H IPS 21.5 LED
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Samsung 22X DVD RW
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    I need help.....Its kinda crash related.....I have direct play folder of Assassin's creed 1 game.....dont have any dvd....ekhn 2nd mission e aisha latest memory loading e Retrieving information e game crash kore....xp te crash ar win 7 e freeze hoia jay.....patch download korlam...but windows registry r jonno install hoitese na.....urgent help needed....plz keu game ta registry path ta dile upokar hoy.....already HKEY_LOCAL_MACHINE\SOFTWARE\Ubisoft\Assassin's Creed boshaisi....vitore InstallDir and language o deya ase.......tarporeo hoitese na
  1. Assassins creed: Brotherhood
    By muscle in forum XBOX
    Last Post: January 7th, 2011, 20:26
  2. Assassins creed 2 pc leaked
    By Exiled_SouL in forum Action-Adventure
    Last Post: March 5th, 2010, 15:26
  3. Assassins Creed 2
    By anik_lc in forum Trash
    Last Post: June 2nd, 2009, 00:53
Page generated in 0.18924 seconds with 14 queries.
