Results 1 to 8 of 8
Thread: Problem with CPU core temp.
    • salmanshah's Gadgets
      • MSI Z97 Gaming 5
      • i7-4790K - Cooled by Corsair V8 GTS
      • G.SKILL Trident X Series 2400MHz 32GB (4 x 8GB)
      • Samsung 850 EVO 250GB SSD (2TB + 3TB HDD)
      • MSI GTX 970 GAMING 4G
      • Sony KDL-32W654
      • Sound Blaster Z PCIe Gaming Sound Card
      • Sennheiser HD555
      • Thermaltake MEKA G-Unit
      • Steelseries Sensei
      • Microsoft Xbox 360 Wired Controller
      • Corsair TX650w V2
      • Power Saver 1200va
      • Windows 10 PRO Retail key
      • Winrar bench - 11085 KB/s @ OC CPU
      • Casing: NZXT Phantom 001W
      • Radiant Telecommunications
      • 6 - 24 Mbps
      • 6 - 24 Mbps
    salmanshah's Avatar
    Lalbagh
    Default Problem with CPU core temp.
    I am having some problem with the cpu core temp of my core 2 duo e7500. It is OCed to 3.667 MHz, with 1.31v from bios. I do video encoding X264/AVC which uses all cores to get higher FPs.
    The problem is my usual full load temp was max 72C but after I installed AIDA64 EXTREME and start using my cpu at full load it shows 64C highest, whats the problem, would anyone tell me?
    Before:
    After:
    Btw I had my Rig switched off for about 6 hours before I installed AIDA64. After that I got my lowest temp 27!
    Is it because of this winter season? the weather temp? If this is so, Then I think I can OC it more
    • proton_chain's Gadgets
      • Gigabyte GA-P55-UD3
      • 4x4GB DDR3-1600MHz
      • 6.5TB (3TB+2TB+1TB+.5TB)
      • Nvidia Geforce GTX 760 4GB
      • Samsung Syncmaster 22 inch
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
      • Sony Optiarc DVD burner
      • Blue Yeti USB Microphone
    proton_chain's Avatar
    Default Re: Problem with CPU core temp.
    It is probably because of the cold weather. Even yesterday my CPU was 3 degrees higher, now it is idling at 19 C and full IBT load at 50 C. But check BIOS readings to eradicate any software side conflict.
    • Dee's Gadgets
      • Asus Maximus VIII Ranger
      • Intel Core i5 6600k
      • Dell S2216H
      • Cooler Master V650 Gold
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    @salmanshah , what Thermal Paste do you use? And do you use any after-market cooler? Your temperatures are quite impressive if on a stock cooler. On my E7300, temperature hits 72C with stock speed even in this cold weather , though I'm using the TIM from a Tt Frio.
      • MSI Z97 Gaming 5
      • Sony KDL-32W654
      • Sennheiser HD555
      • Corsair TX650w V2
      • 6 - 24 Mbps
      • 6 - 24 Mbps
    salmanshah's Avatar
    Lalbagh
    I am using a normal air cooler and i don't know which thermal paste the shopkeeper used. Do you think I should again paste some grease on the cpu to get more decrease in temp? Its been more than 1 year I've bought my cpu.
    • Mahfuz's Gadgets
      • Asus 9600GT 512MB
      • Asus ML239H 23'' IPS Panel
      • Never Interested :-/
      • Asus 18X DVD RW
      • RahimAfrooz 1000VA
      • Not half-bad.
      • 30KBps
      • 7KBps
    Mahfuz's Avatar
    May 2010
    মনে নাই
    for stock cooler and TIM , temps are seem fine ... but make sure bios reading is same as real temp .... and if u've not any decent brand TIM then i'd say, don't open up the heatsink for nothing since TIM those are available in market are worst than manufacturer TIM and never could lower the temp than this ...
    Quote Originally Posted by proton_chain View Post
    19C tao abar i7 860 a !!!
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
    Yes. Look here.
    It was shot at noon, but temps were even lower when I posted first post (at morning). IBT loads at 49/50, rendering at 45/46, encoding video 39/40. This is why I love winter! My PC is in my room which is not so cold. If I took it outside, CPU temp would probably had dropped down to 15-16 degrees celcius (or even lower).
      • MSI Z97 Gaming 5
      • Sony KDL-32W654
      • Sennheiser HD555
      • Corsair TX650w V2
      • 6 - 24 Mbps
      • 6 - 24 Mbps
    salmanshah's Avatar
    Lalbagh
    why did u take screenshot with your utorrent maximized? lol
  1. core i5 high temp problem
    Last Post: January 12th, 2011, 04:34
  2. Replies: 42
    Last Post: February 21st, 2010, 15:51
  3. Best CPU Temp. Checker Software
    By Extreme Noob in forum Software
    Last Post: November 19th, 2009, 23:20
  4. Confused about cpu temp!
    By shahriar in forum CPU
    Last Post: March 7th, 2009, 22:49
  5. cpu temp too high
    Last Post: February 22nd, 2009, 02:23
Page generated in 0.21153 seconds with 15 queries.
