Thread: Mobo problem.
    • Blurgon's Gadgets
      • Asus H97-PLUS
      • Intel Core i5 4590 3.30 GHz
      • 8 GB 1333MHz
      • 500 GB
      • ZOTAC 1050 Ti 4GB OC
      • Samsung 19.5"
      • Knucker - Tt eSPORTS
      • Bloody A91
      • Logitech F310
      • Thermaltake 350w
      • Power Guard 1200VA
      • Windows 10 PRO
      • DOT internet.
    Blurgon's Avatar
    Dec 2013
    Unhappy Mobo problem.
    Today I went to assemble my old casing components to my newly bought spec 03. After everything was bolted in, shob kichu chalu hoise but monitor e display ashe na. My config is, intel dh55hc mobo,i3 530, chieftec 450w psu, 2gb and 4gb 1333 ram and 500gb toshiba hdd. The UCC technician said my mobo had a short curcuit as for the past 5 years mobo khola hoy nai and due to heat, it expanded after it was opened from the old casing. Plz help. None of the components have any warranty left.
    As you just assembled, I'd suggest you to disassemble again and make a test bench assembly. That is, take e clean open table, put the mobo on a non conductive platform like a thick book or the motherboard's box, then assemble everything else around it, in the open, on top of that table. You don't have to connect any CD/DVD drive nor HDD. If the machine still doesn't boot, clear the CMOS with the jumper and try again. If the PC boots, very very carefully reassemble everything inside the case. This method helped me in the past, multiple times, for this similar problem.
    1. Reset BIOS through cmos jumper.
    2. Try a new CMOS battery.
    3. Try with another psu.
    4. Check to see if the technician used mounting screws or just maira dise.
    5. Check the processor, last time I heard a case about ucc long ago that a technician couldn't install a cpu properly, that can also cause black screen.
    • Blurgon's Gadgets
      • Asus H97-PLUS
      • 8 GB 1333MHz
      • 500 GB
      • Samsung 19.5"
      • Bloody A91
      • Logitech F310
      • Thermaltake 350w
      • Windows 10 PRO
      • DOT internet.
    Blurgon's Avatar
    Dec 2013
    Thanks a lot, both of you. Kalke will try to do all those been suggested. Dekhy ky hoy.
    • Trave160's Gadgets
      • MSI B350M Mortar AM4
      • AMD Ryzen 5 1600
      • 16GB DDR4 3000Mhz
      • 3TB Western Digital red
      • ASUS Strix GTX 960 4G
      • Dell S2216H 22 Inch monitor
      • Logitech Speaker
      • TtEsports Knucker
      • PS4 Dualshock 4 controller
      • Pendrive 4GB
      • NunuCom Ltd, Penus group
      • Super San 200kbps
      • 105*2
    Trave160's Avatar
    A Secure Area
    I think that's called bread boarding.
    • giant's Gadgets
      • MSI H77MA-G43
      • Intel Core i5 3470 @ 3.6ghz
      • Realtek ALC892
      • Delux K9020
      • Thermaltake SE 630W
      • Asus DRW-24B3ST (24x)
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    Corsair chassis, and UCC technician!!! what the phuska??
    • Blurgon's Gadgets
      • Asus H97-PLUS
      • 8 GB 1333MHz
      • 500 GB
      • Samsung 19.5"
      • Bloody A91
      • Logitech F310
      • Thermaltake 350w
      • Windows 10 PRO
      • DOT internet.
    Blurgon's Avatar
    Dec 2013
    Quote Originally Posted by giant View Post
    Got the chassis from PCGS and went to ucc uttara for assembly as I know the technician for a while.
  1. Replies: 19
    Last Post: November 4th, 2012, 21:51
  2. Nvidia Driver Problem or Graphics Card Problem ??
  3. Hdds keeps on dying one after another. Mobo problem?or PSU?
    By shohag2018 in forum Technical Support
    Last Post: October 28th, 2011, 20:08
  4. Best Mobo within 4.5k....
    By Saz1d in forum Technical Support
    Last Post: September 1st, 2010, 13:21
  5. Replies: 3
    Last Post: February 19th, 2009, 21:08
Page generated in 0.18988 seconds with 14 queries.
