Results 1 to 6 of 6
Thread: Help me ! I wanna overclock my CPU
    Default Help me ! I wanna overclock my CPU
    hi brothers . I wanna over clock my cpu. Because i cant play cod black ops and bbc2 thats da main reason :o while i playing my pc got hangd everytime :s this 2 game minimum requirement core 2 due cpu..hahaha..watever.. If i overclock my cpu may b i can play those games.. I google about this on web.. Some ppl said they can play without any prob.. But my rig got hang everytime..i dont know why. My pc spech:- intel pentium duel core 2.6 ghz e5300. Mobo:- gigabyte ga-g31m-es2c. Ram:- 2gb ddr2. Gpu:- gigabyte hd5450 1gb ddr3 Normal pSu with casing-400watt. Cpu temp:- load 70-75 idle 42. i m noob in overclocking. I hope you guys will help me thanks
    • W1C|<3D's Gadgets
      • Intel DG41RQ
      • Intel Core 2 Duo
      • 3GB
      • Samsung
      • Gigabyte 9500 1 GB[factory overclocked]
      • HP 1859m
      • A4TECH GK-85
      • Logitech MX 518
      • 500 watt
      • ASUS Sata DVD RW
      • Windows Se7en Ultimate X64
      • RAM 5.5,HDD 5.8,Processor 6.4,Gaming Graphics 6.2
      • Meh....
      • BTCL ADSL
      • 64+
      • 30+
    W1C|<3D's Avatar
    Narnia :O
    Default Re: Help me ! I wanna overclock my CPU
    I dont think by OC you can play those games nicely. As games see a little improvement from CPU OC. You should install the latest COD:BO patch. Hopefully after that you can play nicely
    No 7. No discussion, sharing or referencing game hacks.
    BG Rule Book
      • GIGABYTE B75M-D3H rev1.1
      • AOC e2043Fsk 20&quot; LED(1600 X 900) DCR 50,000,000:1
      • A4Tech KRS-86
      • Thermaltake azureus
      • Antec VP450P
      • Samsung DVD RW+Asus CD RW
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    you have to try lower setting/res in order to get playble fps on those game as your gfx card meets minimum req of those games.cpu oc may not bring any result...
    • Rakin the Devil's Gadgets
      • Gigabyte X58-USB3
      • Hitachi 1TB 7200 Rpm
      • A4tech Gaming Keyboard
      • A4tech X7 747H Gaming Mouse
      • TT Toughpower XT 775W &amp; TT V6
      • BenQ 24x DVD-RW
      • Powerpac 1200VA x2
      • Windows 7 SP1 x64
      • Check Links in Sig..
      • This Monster will Kill any game thrown at it with stunning visuals &amp; Frame Rates!!
      • 140+
      • 50+
    Jan 2011
    OC in wont help....u better play @ lower settings.......
    ---------- Post added at 14:31 ---------- Previous post was at 14:30 ----------
    still if u wanna do it then use the MIT in the Bios to OC.....nd get the lowest volts possibly stable in your desired clocks....
    i also tried lower setting. 800x600.. Same thing happens. what should i do now to play bad company 2 and COD black ops.. I cant play those games.. Black ops er 1st mission ta e over korte partasina..mission sesh houar aktu agei freeze.. Same problem bad company 2 te o.. ctl+alt+del press kore end task k0re..ber howa lage..
    • proton_chain's Gadgets
      • Gigabyte GA-P55-UD3
      • 4x4GB DDR3-1600MHz
      • 6.5TB (3TB+2TB+1TB+.5TB)
      • Nvidia Geforce GTX 760 4GB
      • Samsung Syncmaster 22 inch
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
      • Sony Optiarc DVD burner
      • Blue Yeti USB Microphone
    proton_chain's Avatar
    In your case, overclocking will NOT solve the problem. It is not due to slow performance. Even if your PC runs a game slowly, it will run slowly to the end without crashing. Your problem may be software related. Install the patches (refer to the COD Black Ops thread in this forum) and see if it helps. Overclocking will only make the situation worse. CPU OC only pays off in multi GPU setups, and in benchmarks (as it gives slightly higher framerate to boast of).
    If you STILL want to OC, thats your call, and we can tell you how to. But your CPU temps are too high in this winter (75 C load?). Either way, it is not recommended even though you are free to decide your path.
  1. How to overclock p4 2.26?
    By Dee in forum CPU
    Last Post: September 6th, 2010, 22:31
  2. How can i Overclock ma GPU?
    By Véиòmøûs Vàmþý in forum GPU
    Last Post: May 29th, 2010, 23:40
  3. Replies: 18
    Last Post: March 22nd, 2010, 17:41
  4. My first ever Overclock
    By ScS :: XTR in forum CPU
    Last Post: November 30th, 2009, 11:00
  5. Replies: 1
    Last Post: November 4th, 2008, 10:55
Page generated in 0.18417 seconds with 14 queries.
