Results 1 to 20 of 27
Thread: Socomec UPS 1000VA - Small Review
    Default Socomec UPS 1000VA - Small Review
    Today I bought a 1000VA Socomec NETYS PE UPS from Tech ValleyBD. I previously used a 1200VA (as written) OVO UPS and it restarted my PC when the power went out under high load.
    Tests:
    I tested this UPS by doing the following:
    1) Playing Metro 2033 @ 1600x900 @High DX 11 no tess and DOF (95% GPU usage; didn't see processor usage)
    2) OCCT PSU Test (I use a ThermalTake Toughpower 600W)
    On both of these occasions, the PC did not restart when I turned off the main power connection. That shows the reliability of the UPS
    The UPS has a USB connection as well and allows automatic shutdown when the battery is low. Haven't tested this though, just browsed through the software. It even lets you set specific times when the PC will turn on and off.
    Backup Times:
    On idle, the UPS started beeping rapidly after exactly 30 minutes. Out of the 3 bars in the battery indicator, it was down to the last one. I suppose it would've lasted at least another 5 minutes.
    On load, when playing Metro, I didn't have the full time to see it, but it didn't even start beeping frequently after 10.5 minutes and the battery indicator was showing 2 bars, I suppose near the end of the second bar.
    Other info:
    The thing that annoyed me the most is that, there are no traditional sockets on the UPS, they are all IEC 320 sockets, your PSU socket on both ends. This makes it difficult to connect other stuff. They included 2 cables, but my monitor does not use this socket. I took a multiplug of mine and they did the socket conversion for me, no additional charges but had to give them a cable which came with the UPS. They told me that this cable is readily available in case I need more. I personally don't as my full setup is now connected.
    On Sunday I will be taking a multi-plug to them and they'll do the socket conversion for me.
    Another thing is that when the UPS is working (power out) a fan in the UPS turns on, and that is quite loud, almost louder than my whole PC. But it doesn't bother me at all.
    Pricing:
    1000VA cost me Tk8200.
    600VA is avaible but no 800VA. 600VA was Tk4200/4500, can't remember exactly.
    Warranty:
    1 year battery warranty and 2 years service warranty
    Helpful links:
    http://www.socomec.com/presentation-...tys-pe_en.html
    http://www.findtheneedle.co.uk/produ...-phase-ups.asp
    Bought from:
    Tech Valley Solutions LTD.
    House-6, Road- 5, Dhanmondi 1205
    Tel: 8616771-2, 8621471-2
    Cell: 01730335895 (Md. Kamal Khan)
    • OoAIDoO's Gadgets
      • Gigabyte GA-Z68A-D3-B3
      • Kingston HyperX 2 x 2 GB 1600 MHz
      • Corsair F60 + Samsung 1TB + 1.5TB
      • Gigabyte HD 5670 GDDR5
      • Fujitsu 24 inch TFT LCD
      • Creative Sound Blaster X-Fi Titanium
      • Shure SRH440 Professional Studio Headphone
      • Logitech G110
      • A4 Tech X7 XL-747H
      • PS3 DS3 Controller :P
      • XFX Core Edition PRO550W
      • ASUS DVD-ROM
      • iPod Touch 4G + StoreJet 25D3 USB3 500GB
      • Micro 1000VA
      • IS Pros
      • 256 kbps or 32 KB
      • 256 kbps or 32 KB
    OoAIDoO's Avatar
    Azimpur Dhaka
    Default Re: Socomec UPS 1000VA - Small Review
    backup time ta dio parle.
    ami micro er 1000VA use kori, 20min backup pai always, with 24" monitor
    aroung 8k e porsilo, jotodur mone pore.
    ps3(22") + pc(24") aksathe chalayle 5 min thake.
    • wolf's Gadgets
      • Asus p5g41c-m lx
      • Core 2 Duo E7500 2.93GHz
      • 2x2GB DDR3 Twinmos
      • Samsung 500 GB
      • Gigabyte Radeon HD 6850 1GB GDDR5
      • Samsung SyncMaster 2033sw
      • Delta 500w
      • Transcend 500GB StoreJet 25M
      • Windows 7
    wolf's Avatar
    Was the monitor connected to the UPS as well when you tested it?
    Nah couldn't keep it connected, no socket
    I will update the review after Sunday with backup time as well.
    Ok so I did some tests with the monitor connected.
    • Uchiha Obito's Gadgets
      • ASUS P7H55M
      • A4Tech X7
      • 1 x Samsung DVD-RW
      • Transcend 16GB JetFlash 700
      • Windows 7 x64 + Linux x64
      • Didn't see till now.
      • RIG OK and Console Awesome.
      • BTCL ADSL 512kbps, 1mbps
      • 60KB/s and 120KB/s
      • Secret
    Uchiha Obito's Avatar
    Sep 2008
    Mymensingh, Bangladesh.
    Oh mY god.... 30mins.
    This is awesome. It is perfect competitor for RA in our country.
    Ya amio surprised chilam jokhon stopwatch ta dekhsi :S
    But akta shomossha dekhtesi, earthing ken jani thik kore hocche na, PC touch korle shock kore. Shudhu CPU jokhon lagano chilo tokhon problem hoito na, converted multiplug ta genjam kortese kono.
    • Rakin's Gadgets
      • Gigabyte GA-X58-USB3
      • Intel Core i7 920 Cooled by TT Frio (dual fan)
      • Transcend 2 GB + Silicon Power 2GB DDR3 1333Mhz
      • 1 TB Hitachi @ 7200 RPM 32MB Buffer
      • XFX AMD Radeon 5850 Black Edition
      • ASUS MS228H 21.5 Full HD 1080p
      • 10-channel (7.1) Dolby Home Theater Audio subsystem using the Realtek ALC892 audio codec
      • Creative Inspire M4500 4:1 , A4 Tech Headphone
      • A4 tech KBS - 8
      • A4 tech 2X office 7K
      • Xbox 360 Controller for Windows
      • ASUS 650 Watts
      • BenQ 24X
      • Transcend StoreJet 320 GB , Transcend 4 GB Pendrive
      • Powerpac 1200 VA
      • Windows 7 x64
      • 1000/1000
      • The Killer Machine
      • Qubee WiMAX @ 256 kbps
      • 32 KBps
      • 7-8 KBps
    will this ups be enough to power up my rig??my sucky 1200va gives 1 sec backup during load even....
    Probably, it should work fine with PCs requiring 600Ws of power. If you want you can contact them for even higher capacity UPS'.
      • ASUS P7H55M
      • A4Tech X7
      • Secret
    Sep 2008
    Quote Originally Posted by Rakin View Post
    As it power Aayman's PC it surely will yours.
    I am thinking of buying a 600VA to power up ADSL modem and some other parts.
    • W1C|<3D's Gadgets
      • Intel DG41RQ
      • Intel Core 2 Duo
      • 3GB
      • Samsung
      • Gigabyte 9500 1 GB[factory overclocked]
      • HP 1859m
      • A4TECH GK-85
      • Logitech MX 518
      • 500 watt
      • ASUS Sata DVD RW
      • Windows Se7en Ultimate X64
      • RAM 5.5,HDD 5.8,Processor 6.4,Gaming Graphics 6.2
      • Meh....
      • BTCL ADSL
      • 64+
      • 30+
    W1C|<3D's Avatar
    Narnia :O
    Quote Originally Posted by Joker View Post
    What about your IPS??:S
    I use my IPS to power up my whole PC. My PC is not power hungry though
    No 7. No discussion, sharing or referencing game hacks.
    BG Rule Book
      • ASUS P7H55M
      • SAMSUNG SA300B 21.5&quot; 1080p Monitor For PC and LG 2043T 20&quot; for PlayStaion 3
      • A4Tech X7
      • Secret
    Sep 2008
    Your PC is a normal one.
    My pc shuts off even with a 800VA UPS......so no luck here.
    and the 600VA i wanna buy is the socomec/RahimAfrooz.
    • W1C|&lt;3D's Gadgets
      • Intel DG41RQ
      • Intel Core 2 Duo
      • 3GB
      • Samsung
      • HP 1859m
      • A4TECH GK-85
      • Logitech MX 518
      • 500 watt
      • ASUS Sata DVD RW
      • Meh....
      • BTCL ADSL
      • 64+
      • 30+
    W1C|<3D's Avatar
    Narnia :O
    Buy this one
    BG Rule Book
    Well be careful Sumon cause this doesn't use normal power connectors. Make sure you have them convert 1 multiplug at least. I love this UPS but this shock thingy is annoying me, anything I can do about it other than the traditional ways?
      • ASUS P7H55M
      • A4Tech X7
      • Secret
    Sep 2008
    no normal power connectors? gimme a pic of the backside of the UPS. :S
      • ASUS P7H55M
      • A4Tech X7
      • Secret
    Sep 2008
    হায় হায় where is 3 point Plug?
    • error's Gadgets
      • None ; 18x DL SuperDrive
      • Mac Pro love.
      • 1 mbps
      • 1 mbps
    error's Avatar
    Boo.
    IEC 320 socket converters are also available.. You can use them instead of tampering with a multiplug..Then you won't even have the earthing problem...I'm using an IdeAL 1000VA ups and gives me about 30-40mins normally..On load, i roughly get about 20-25mins :S.. I too dont have the 3-pin plug point and use those converters to power up my internet modem
    This is the type of converter i meant
      • Samsung KS8000 55&quot;
    rahma Afrooza 1000VA UPS (2 x 9 amp 12 V battery ) costs 6700 taka. Bought 1 today for my office. 1 year batt + 2 year unit warranty.
    • @bhi's Gadgets
      • Gigabyte Z87X-UD3H
      • Samsung 30nm 2x4GB
      • Gigabyte HD7950 3GB WF3
      • Samsung 20&quot; LED BX-2035
      • Creative SoundBlaster Z
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Seasonic X-650 km3 80+ Gold
      • Luminous Solo 1200 VA
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    Quote Originally Posted by error View Post
    @error
    where can i get those converters?? available in BCS??? and price??
  1. 500w Delta PSU on a 1000VA Rahimafroz UPS
    Last Post: February 4th, 2011, 08:25
  2. A very small BG Get together
    By anik_lc in forum Member Central
    Last Post: September 26th, 2010, 19:10
  3. A small contest.
    By xK::CREATOR in forum Trash
    Last Post: October 31st, 2008, 21:24
  4. A small yet fine ANTIVIRUS for all
    By Tian in forum Software
    Last Post: August 30th, 2008, 09:07
  5. A small announcement
    By SinEater in forum DotA Talk
    Last Post: May 8th, 2008, 09:43
Page generated in 0.32031 seconds with 14 queries.
