Results 1 to 6 of 6
Thread: Help applying thermal paste
    • n33l's Gadgets
      • MSI Z97 Gaming 5
      • Intel Core i5-4590
      • Team Elite 8GB DDR3 1600Mhz
      • ADATA SX900 256GB SSD (master), WD 1TB (slave)
      • Gigabyte GTX 650Ti 2GB
      • Samsung SyncMaster SA300
      • Presonus HD7 Studio Headphones
      • MSI DS100 Gaming Mouse
      • Cooler Master V650S 80+ Gold
      • I just need a good GPU now! :'(
      • Bani Networks LTD
      • 256 (Internet)
      • 256 (Internet)
    n33l's Avatar
    Default Help applying thermal paste
    Just bought a new processor and need to apply thermal paste before installing it in my old mobo.
    Anyone knows about a nice tutorial in how to apply it?
    • Dee's Gadgets
      • Asus Maximus VIII Ranger
      • Intel Core i5 6600k
      • Dell S2216H
      • Cooler Master V650 Gold
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    Default Re: Help applying thermal paste
    Some people say to put a dot in the middle of the IHS and then press on it with the Heatsink, but it really didn't work for me. I used my fingers to spread it, and temperatures are quite normal.
    Here you go, a tutorial on youtube, click here.
    • proton_chain's Gadgets
      • Gigabyte GA-P55-UD3
      • 4x4GB DDR3-1600MHz
      • 6.5TB (3TB+2TB+1TB+.5TB)
      • Nvidia Geforce GTX 760 4GB
      • Samsung Syncmaster 22 inch
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
      • Sony Optiarc DVD burner
      • Blue Yeti USB Microphone
    proton_chain's Avatar
    Which CPU?
    There are different methods. You may check this out as a starter. Experiment with all possible methods and thickness to find out the best configuration for you. I personally found "one drop at the center" method to be the best method for my i7 860, others give higher temperatures. But it may be the worst case for you, just like it was for @abir ; vaia. After my method was a failure, he spread the paste himself before installing the cooler. But the same method gave me surprisingly high temperatures. So, do NOT rely on just one method, test out all of them at least once. You'll find the best configuration in this way.
    • n33l's Gadgets
      • MSI Z97 Gaming 5
      • Bani Networks LTD
      • 256 (Internet)
      • 256 (Internet)
    n33l's Avatar
    Well to tell you the truth it's a Dual-Core E5500, and the stock cooler has pre-applied thermal paste.
    So maybe I don't need to apply extra thermal paste, do I?
    BTW I checked on the Internet and as @Dee said, the best method would be to put a dot on the CPU and press on it with the heatsink.
    • Rakin's Gadgets
      • Gigabyte GA-X58-USB3
      • Intel Core i7 920 Cooled by TT Frio (dual fan)
      • Transcend 2 GB + Silicon Power 2GB DDR3 1333Mhz
      • 1 TB Hitachi @ 7200 RPM 32MB Buffer
      • XFX AMD Radeon 5850 Black Edition
      • ASUS MS228H 21.5 Full HD 1080p
      • 10-channel (7.1) Dolby Home Theater Audio subsystem using the Realtek ALC892 audio codec
      • Creative Inspire M4500 4:1 , A4 Tech Headphone
      • A4 tech KBS - 8
      • A4 tech 2X office 7K
      • Xbox 360 Controller for Windows
      • ASUS 650 Watts
      • BenQ 24X
      • Transcend StoreJet 320 GB , Transcend 4 GB Pendrive
      • Powerpac 1200 VA
      • Windows 7 x64
      • 1000/1000
      • The Killer Machine
      • Qubee WiMAX @ 256 kbps
      • 32 KBps
      • 7-8 KBps
    the dot 1 worked for me but spreading it works bttr.......nd u don need extra paste if stock cooler has it.....
    • n33l's Gadgets
      • MSI Z97 Gaming 5
      • Bani Networks LTD
      • 256 (Internet)
      • 256 (Internet)
    n33l's Avatar
    Oh okay.
    For now I'll use the stock speed. Thanks for help everyone!
  1. Sale (New) Thermal Paste and thermal paste cleaner
    By Mazhar in forum Shop - Gadgets
    Last Post: January 28th, 2011, 17:15
  2. Thermal Paste with Cleaner
    By Orn in forum Others PC Hardware
    Last Post: November 21st, 2010, 02:44
  3. Want to Buy Thermal Paste
    By jigsaw in forum Shop - Gadgets
    Last Post: April 7th, 2010, 19:14
  4. Replies: 20
    Last Post: March 13th, 2010, 22:37
  5. Want to Buy Thermal paste
    By awestruck in forum Shop - Gadgets
    Last Post: February 6th, 2009, 03:05
Page generated in 0.18320 seconds with 14 queries.
