Thread: Pentium 4 problem
    • Diego Maradona's Gadgets
      • AMD ASUS A40/A50 Series FCH
      • AMD E2-1800 APU Dual core 1.8 Ghz
      • 4 GB DDR3 1333 Mhz
      • Seagate 500GB
      • AMD Radeon HD 7340 512MB DDR3
      • 15.6'' backlit LED
      • Built-in HD audio
      • Logiteh 2:1
      • generic
      • A4 tech
      • My 2 Hand
      • nill
      • TSSTcorp CDDVDW
      • 4GB transcend V60 , 32GB transcend V90
      • nill
      • Windows 7 RTM 64-bit
      • 2^p-1
      • M.I.A
      • Smile 256
      • 20-25
      • 10-15
    Diego Maradona's Avatar
    MirPur 10
    Exclamation Pentium 4 problem
    Got an old p4 setup running for 10 years . intel p4 1.6ghz,intel D845WN,384MB SD RAM.3 days ago , its responding to ON command but monitor screen shows nothing . no p4 logo , no BIOS initialization . checked the HDD, SD ram , processor fan ,BIOS battery . all of them working fine . but nothing on the monitor . is it BIOS problem or prob with mobo ? can BIOS be flashed manually ? from where ? ECS or IDB? help me out
    Default Re: Pentium 4 problem
    Full specs of the pc, please? Did you check the power supply? Sounds like your motherboard or psu could be the culprit, and I've a question, how did you check the ram and the processor? SDRAM and motherboard's capable of booting to 423 socket 1.6 gigahertz pentium 4 processor are hard to find indeed! And you haven't mentioned whether you've integrated graphics solution or an external graphics card, I don't remember 845WN having an integrated graphics card, in case you've an external graphics card (Agp) and it's faulty, it could also be the cause of a system failure. Check your motherboard and the power supply, and the graphics card, assuming you've one.
      • Seagate 500GB
      • Built-in HD audio
      • Logiteh 2:1
      • generic
      • A4 tech
      • My 2 Hand
      • nill
      • TSSTcorp CDDVDW
      • nill
      • 2^p-1
      • M.I.A
      • Smile 256
      • 20-25
      • 10-15
    MirPur 10
    thnx for your reply . SDRAM & processor was checked on another old P4 pc . they are OK .also AGP which is RIVA TNT 32 is also OK. PSU i didnt checked yet . i have a sound card , a LAN card and a modem installed in the PCI slot of the mobo . they are all checked and working 100% . so my idea is that my MOBO got busted somehow. will go to IDB next day for a full P4 checkup . & most annoying thing is the P4 just died in front of a buyer who was going to buy the P4 from my house on that day. damn bad luck for me .
    • NIMBUS_TeK's Gadgets
      • Dell Vostro 1015
      • Core 2 Duo 2.2 GHz T 6670 Mobile
      • 4 GB - 800 BUS
      • 320 GB Internal, 750GB External
      • 15.6" LED
      • Genuine Windows 7 Ultimate
      • Zoom Ultra
      • 20
      • 20
    Dhanmondi
    intel D845WN Mainboard ar mone hoi Ram Slot a problem hoisa. Dakte paran. Aita nai mainboard ar khub common problem/ ar apni 2 ta ram mone hoi use koran, so je kono 1ta ram lagaiya dakte paran/
  1. Sale (Used) Pentium D Full PC
    By Dee in forum Shop - Gadgets
    Last Post: November 9th, 2010, 17:09
  2. Closed Pentium 4 FULL PC
    Last Post: September 14th, 2010, 00:27
  3. Replies: 18
    Last Post: March 22nd, 2010, 17:41
  4. Sale (Used) Want to buy Pentium D /Pentium Dual Core pro within 3000-3500/=
    Last Post: January 5th, 2010, 23:16
  5. Sale (Used) Intel Pentium 4 [email protected]
    By dipanzan in forum Shop - Gadgets
    Last Post: April 27th, 2009, 21:45
Page generated in 0.16826 seconds with 14 queries.
