Results 1 to 2 of 2
Thread: Strange problem!!!!!
    • shaikh_imtiaj's Gadgets
      • Asus P6X58D-E| Gigabyte G31-ES2C
      • Core i7 930 @ 3.88GHZ cooled by True Spirit| E5200 @ 3.15Ghz
      • Patriot 6GB DDR3 1600| Transcend 3GB DDR2
      • Samsung F3 500GB|Samsung 160GB +Samsung 1TB F1
      • Gigabyte GTX660 OC| Intel GMA3000
      • Asus MS228H LED
      • Creative x-fi Titanium | intregreted realtek x-fi modded
      • Creative GigaworksT20 +Inspire2.1|A4tech HS-800 Gaming Headphone
      • Newmen Backlit Gaming KB E370Logitech NewTouch 100
      • A4tech X7 747H | Logitech M90| A4tech x7
      • XFX Dual analog | Xbox360 wired Controller
      • XFX 650W Core edition|Thermaltake Litepower 400W
      • Benq DVD/RW, Benq DVD rom
      • Canon Lide25| WD 500GB USB3| 16GB+8GB Transcend | 2GB PNY
      • Rahim Afrooz 600va
      • Windows 7 x64|Windows xp sp2+Windows 7 build7600
      • A killer PC...Grrrrrr
      • Link3 | Banglalion
      • 60-70 | 100
      • 60-70 | 8
    shaikh_imtiaj's Avatar
    Jan 2009
    Greenroad,Dhaka
    Default Strange problem!!!!!
    Guyz I am having strange problem! Today I uninstalled kaspersky from the computer and installed ESET nod32. After that I reboot my computer. Then at the log in screen I found that my mouse cursor isnt moving! Than I logged in by keyboard. Now I found that my keyboard isnt working in the desktop! But I can browse my computer as well as other folder through start menu. I cant figure out whats the problem is. I used tune up utilities 2011 to solve all registry prob but after that no problem is solved!
    Now I am using win7 as I use dual boot. All is ok there. But I need xp badly. Can anyone help me in this problem?
    BTW I removed the ESET also but nothing happened
    For secondary use: E2160 OC @2.2Ghz| Gigabyte 945GCMX| 1.5GB DDR2| Thermaltake 400w| Intel GMA 950
    • NIMBUS_TeK's Gadgets
      • Dell Vostro 1015
      • Core 2 Duo 2.2 GHz T 6670 Mobile
      • 4 GB - 800 BUS
      • 320 GB Internal, 750GB External
      • 15.6" LED
      • Genuine Windows 7 Ultimate
      • Zoom Ultra
      • 20
      • 20
    Dhanmondi
    Default Re: Strange problem!!!!!
    Safe mode diya try koran. Amar mone hoi apnar anti virus uninstall kora ta hoi nai. Apni kespersky ar original set up file a click korla bolbe je remove korben naki repair korben, Oita diya try kora dakte paran. amar mone hoi kaj korbe.
  1. Strange problem in win 7
    By Speed in forum Technical Support
    Last Post: December 8th, 2014, 01:39
  2. Strange Pc Problem
    By D3FC0N in forum Technical Support
    Last Post: October 11th, 2010, 18:12
  3. Too Strange! Need help with my exe files :(
    By TE.Ruff in forum Technical Support
    Last Post: September 13th, 2009, 05:18
  4. Strange Occurances is Bdgaming server :/
    By LynAs in forum CS: Source
    Last Post: December 13th, 2008, 23:38
  5. strange problem....any solution?
    By saadbillah in forum Older NFS Games
    Last Post: November 16th, 2008, 22:38
Page generated in 0.15230 seconds with 14 queries.
