Thread: Some quaries about power supply.
    • Banglavai's Gadgets
      • Asus Maximus VI Hero
      • Core i5 4670k
      • G-Skill Ripjaws X 2X 8GB 1600
      • 2X Samsung EVO 840 240GB
      • Gigabyte GTX 770 Windforce OC
      • Asus MX279H 27 inch
      • ROG SupremeFX 8-Channel High Definition Audio
      • Bose 301 Direct / Sennheiser Momentum 2.0
      • Logitech G105
      • Logitech G5
      • Xbox 360(usb wired)
      • Fractral Design 650 watt 80 plus gold
      • No need at all
      • Windows 8.1 64bit Professional
      • 100 Mbps
      • 30 Mbps
      • 146
    Banglavai's Avatar
    Oct 2009
    Helsinki, Finland
    Smile Some quaries about power supply.
    Extreme power supply calculator diye amar pc er jonno recommended psu dekhai 284watt er(with my 9600gt).eta ki sotti??
    r amar grafix card change kore jodi 5850 kore deya hoy tahole recommended kore 333watt r gtx 460 er jonno 348watt.
    jodi etai hoy taile ami tt lightpower 400 ba 430 diyei eisob card chalate parbo??
    please anyone help me to find the problem.
    • Mohiuddin's Gadgets
      • Xeon X5650
      • 8gb gskill ripjaw
      • Western Digital 1TB blue
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Gigabyte 1200w OdinPro
      • Apatoto nai
      • Netvision
      • Janina, 3Mbps may be
      • Don't upload...
    Uttara,dhaka
    Default Re: Some quaries about power supply.
    450w will serve ur config. with a 5850/460gtx...but to cross the safety margin 500 will be best...btw, look 4 max amp. rating in d psu +12v rails.
    • Ratul107's Gadgets
      • gigabyte h61M s2p
      • core i5 2400 3.1 ghz
      • 2x2gb ddr3 1333mhz
      • 1TB + 1TB ext
      • Sapphire R9 280X
      • samsung SA300 20" 1600X900
      • generic
      • generic
      • generic
      • thermaltake smart power 550w
      • 1000va
      • win 7 64 bit ultimate edition
      • Cpu 7.4 gpu 7.8 ram 7.6 hdd 5.9
      • it's a mixed bag ... but gaming performance is satisfactory
      • smilebd
      • ~240kB/s
    Ratul107's Avatar
    A 400watt psu doest give exact 400w. See the wattage it can deliver in real time. A 80+ rated 450w should b fine for u.
      • Core i5 4670k
      • Logitech G105
      • Logitech G5
      • No need at all
      • 100 Mbps
      • 30 Mbps
      • 146
    Banglavai's Avatar
    Oct 2009
    Helsinki, Finland
    So the moral is a 450 watt delta psu(which is considered a good psu ) can safely handle my rig with a 5850 or gtx460??
      • Xeon X5650
      • 8gb gskill ripjaw
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Apatoto nai
      • Netvision
      • Don't upload...
    Uttara,dhaka
    ^^nd with 400w~ while running heavy 3d applications pc will extract d full juice out of psu(100%load)...keeping psu within 70~80% is a wise decision as most branded psus work most efficiently within this range.(a few can be efficient in 100%load)...in this consideration if ur pc need 400w, getting a psu above 450w will be best.
  1. Replies: 21
  2. Power supply
    By sameev29 in forum Others PC Hardware
    Last Post: May 28th, 2010, 00:23
  3. Any good power power supply available???
  4. PC Power Supply Discussion
    By Albert SX65 in forum Technical Support
    Last Post: October 14th, 2009, 22:39
  5. Need advice about a new power supply.
    By Xero Fatal1ty in forum Others PC Hardware
    Last Post: July 20th, 2009, 17:05
Page generated in 0.17562 seconds with 14 queries.
