Thread: 3d mark vantage problem
    • Banglavai's Gadgets
      • Asus Maximus VI Hero
      • Core i5 4670k
      • G-Skill Ripjaws X 2X 8GB 1600
      • 2X Samsung EVO 840 240GB
      • Gigabyte GTX 770 Windforce OC
      • Asus MX279H 27 inch
      • ROG SupremeFX 8-Channel High Definition Audio
      • Bose 301 Direct / Sennheiser Momentum 2.0
      • Logitech G105
      • Logitech G5
      • Xbox 360(usb wired)
      • Fractral Design 650 watt 80 plus gold
      • No need at all
      • Windows 8.1 64bit Professional
      • 100 Mbps
      • 30 Mbps
      • 146
    Banglavai's Avatar
    Oct 2009
    Helsinki, Finland
    Exclamation 3d mark vantage problem
    I can't run the 3d mark vantage software.whenever i press start then it shows that minimum resoulation is 1280*1024.kintu amar monitor eta support kore na.is there any other way to run it?
    Thanx.
    • HolySlayer's Gadgets
      • Asus B85 Pro Gamer
      • Intel i5 4570
      • 12GB DDR3
      • 320GB + 250GB SSD
      • NVIDIA GEFORCE 660Ti ASUS DirectCUII 2GB
      • Builtin High Definition Audio with SPDIF Output
      • Microlab 5.1
      • A4 Tech Bloody
      • Almost kono naam nai
      • Xbox360,CreativeCOBRA2
      • Thermaltake LightPower Key 3
      • ASUS 52x CD-ROM Drive (Baki shob noshto)
      • Apollo 800 VA
      • Windows Score 7.3
      • Its okay
      • 160
    HolySlayer's Avatar
    Dacca
    Default Re: 3d mark vantage problem
    nope... (not as far as i know)
    i had this problem with my previous monitor Samsung 943swx.. at that time i also had an LG 17 inch Crt... Vantage worked perfectly on that... never ran on the samsung...
    • Muradd9's Gadgets
      • Msi B75MA-P45
      • Core i5 3470
      • 8GB 1600MHz Twinmos Twister
      • WD 2TB + Toshiba 2TB +Samsung 1TB
      • Msi GTX660Ti Oc 2GB DDR5
      • Samsung P2250 21.5
      • Realtek
      • Creative I-Trigue L-3500 2.1
      • Logitech K375s
      • Logitech M235 Wireless
      • Gigabyte Superb 550P 450W
      • Asus DRW-24B3ST
      • Creative muvo TX
      • RA Luminous ion 1500va(1200W) sine-wave ips
      • Windows 10 pro
      • 9007B server case
    Muradd9's Avatar
    Bogura
    Quote Originally Posted by Jaber17 View Post
    Thanx.
    I think u r using Vantage advance/professional edition key.
    Manually disable all the feature test.
    Go : Options > Feature Tests > and uncheck all option.
    (Because feature tests requires specific 1280x1024 resolution ; i think)
    And now try again.
      • Core i5 4670k
      • Logitech G105
      • Logitech G5
      • No need at all
      • 100 Mbps
      • 30 Mbps
      • 146
    Banglavai's Avatar
    Oct 2009
    Helsinki, Finland
    murad vai thanks.feature test ta kon vantage e kora jabe??
  1. pc mark vantage key needed!
    By sayemcom in forum Software
    Last Post: July 19th, 2010, 14:35
  2. 3DMark Vantage v1.02.1901 Advanced Edition (2010)
    By showdown_king in forum Software
    Last Post: March 6th, 2010, 03:11
  3. Help[3DMark Vantage]
    By kabir_sharif2000 in forum Software
    Last Post: September 7th, 2009, 01:32
  4. Post Your 3D mark
    By Cyber_Shot in forum GPU
    Last Post: February 25th, 2009, 13:00
  5. GTA IV Surpasses $500M Mark During Its First Week!!
    By Deep -xCross- in forum Sand Box
    Last Post: May 9th, 2008, 11:31
Page generated in 0.16644 seconds with 14 queries.
