Results 1 to 18 of 18
Thread: Help in home networking!!!!
    • fahimspider's Gadgets
      • MSI P67A GD65(B3)
      • TWINMOS 8 GB 1600 BUS
      • Saphire ATI HD 7950 Dual-X
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt E-sports Knucker
      • Tt Theron mouse
      • Razer Nostromo
      • Asus DVD RW. HP DVD ROM
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    fahimspider's Avatar
    Default Help in home networking!!!!
    First of all I have to admit I have very little knowledge (noob) about networking. Pls Help.
    Isp: Smilebd (PPPoE connection through dialup)
    Wifi: Don't wana make a wifi network.
    Now I need a network between 3-4 PC with internet. Pls help me out.
    Currently I am using smilebd in my desktop. last night I tried it with my laptop by making a dialup. It failed. Any idea why?
    Noblesse Oblige
    • CvP's Gadgets
      • ASUS P8Z77 V Delux
      • Intel Core i7 3770K @3.9GHz
      • EVGA 980Ti 6GB
      • Samsung 17"+22"+22"
      • Realtek HD Audio <internal>
      • Creative Inspire 5:1
      • Razer BlackWidow Ultimate
      • G7
      • Seasonic X 850W 80Plus Gold
      • External DVD-RW
      • Link3/Amber IT
      • 10000
      • 10000
    CvP's Avatar
    buy a 1800 taka router and some cables.
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    I understand this part. But do I have to call the line man to setup the router? My laptop is not connecting to broadband, though i made up the dialup. Is it becuz change of pc?
    can u also suggest a router for PPPoE connection?
    Quote Originally Posted by fahimspider View Post
    Almost every router supports PPPoE, unless it's a very shitty/old one. Buy a router, plug your LAN cable(the cable which you connect to your ethernet provided by SmileBD) and buy 3-4 point to point LAN cables for your other PCs. Connect those cables to your router's (LAN1-LAN2-LAN3-LAN4) and your PCs. Once you configure the router to have internet access using PPPoE setup, all the connected PCs should have internet access.
    If you don't know how to setup PPPoE on your router, look into the manual after buying the router. There should be detailed steps on how to do it.
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    @dipanzan @CvP Thanks.
    but can u explain why my laptop not connecting? Pluged in the cable, setup the dial up with user id and pass, but still no internet.
    because, u need to configure your laptops network settings exact same as ur desktop. start creating a new net connection> copy paste net settings> check if dial up properties has any numbers in it, if so> copy paste.
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    Quote Originally Posted by dk3 View Post
    i followed all these steps:
    http://www.tp-link.us/article/?faqid=339
    that is only the idea of the process. your net wont work without the net addresses. u have to configure net properties. if u really cant then u can always call the operators
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    @dk3 where to look for net address or network properties?
    ok, got the properties
    from tray bar right click network> click "open network & sharing"> at the top left click change "adapter settings"> then u'll find 2 or more connection 1 for dial up & 1 for net connection. your username & pass will be in the dialup one & your net settings would be in the other 1(right click> properties> internet protocol version 4 OR 6) that is the important 1. ............ & poke around the settings, dont change any settings just take note of the numbers. copy paste
    Sorry didn't read all the comments, you might have already got the answer but still writing.
    first buy a good router according to your budget, tp-link or SMC will work just fine, i have used and still using both of them. I don't know why you don't want wifi but i can tell you it will come handy to have the feature so buy a wifi one and turn off the wifi for now.
    get some CAT6 cable with adequate length and RJ45 male port connected to them, remember if you need to transfer large files over the network a normal 100Mbps network won't be perfect, it will be ok for playback but not for copying, if that is in your mind, but gigabit routers cost significantly more so think about that too.
    router setup is very easy, i guess you have the answer already but if you can't connect with the internet via router but you pc is connecting properly then you might have to clone the mac address. To clone it, just go to the router page go to network and go to mac clone.
    clone it and it should work just fine.
    Smile runs a mac filter, that's most probably why your laptop can't connect directly via PPOE.
    You'll have to buy a router, and then either a. have your MAC cloned, or b. contact them to update the mac address to that of your new router.
    Good luck.
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    Thank you all. ya, i contacted them. Its the MAC address, that's why my laptop not connecting.
    @Codex @redwan hasan pls advice me a good router.
    1. this one at around 2k
    http://www.tp-link.com/lk/products/d...odel=TL-WR841N
    2. this one at around 10k
    http://www.tp-link.com/lk/products/d...odel=Archer+C7
    What package do u have?
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    Gold. if u have other good isp available, then ignore smilebd. Its not stable.
    I have a smile connection in Bashundhara. Its great and I get almost twice the speed I pay for :/
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    Quote Originally Posted by fahim1rocks View Post
    ya I know, same here. Problem is - its not stable.
  1. Bangladeshi social networking website
    By outragedhuman in forum Miscellaneous Topics
    Last Post: January 22nd, 2017, 14:09
  2. Want to Buy Want to Buy few networking Products
    By GLaDOS in forum Shop - Gadgets
    Last Post: April 26th, 2014, 14:05
  3. Replies: 10
    Last Post: June 1st, 2011, 23:15
  4. Playfire - social networking for gamers.
    By cRush in forum Gaming Topics
    Last Post: November 6th, 2009, 12:00
  5. Is there a Networking Wiz on this site?
    By aayman in forum Others PC Hardware
    Last Post: August 7th, 2008, 12:09
Page generated in 0.27802 seconds with 15 queries.
