Results 1 to 13 of 13
Thread: Need suggestion for cpu cooler
    • TaherTheRetard's Gadgets
      • CONSOLE MASTER RACE
      • 136
    Khilgaon
    Default Need suggestion for cpu cooler
    So while playing GTA V my i5 3550 reaches 90 degrees (at stock clocks ) . My room temp is pretty high and there is only one fan in the case (front bottom intake ) . So getting a tt versa h35 case + a cpu cooler. Is there any better cpu cooler cheaper than hyper 212x ?
    Quote Originally Posted by Gentleman View Post
    no matter what cooler you buy, your temp will always be high as there is no exhaust fan.
      • 136
    Khilgaon
    I will be getting a new case and it will have exhaust fans hopefully.
    get a 212X then, it will lower the temp by atleast 20 degree C.
    dunno the price of T3 but it should be cheaper than 212X
    • Sybaris Caesar's Gadgets
      • Intel DH61WW B3 Rev.
      • Intel Core i5 2400 3.10 Ghz
      • Thermaltake Commander
      • Logitech G402
      • Original Xbox 360 Wireless
      • Cooler Master G550M
    Sybaris Caesar's Avatar
    Nowy Warsaw
    And fans can't be installed in your current one?
    Install some exhaust fans, 90C is definitely not okay for a 3rd gen i5.
      • 136
    Khilgaon
    Quote Originally Posted by Sybaris Caesar View Post
    Yes currently have one 80mm fan there but it doesnt help much so I don't use it. I have to keep my side panel open otherwise idle temps get really high.
    Will be getting the 212x + fans + case.
    you can buy a table fan too!
      • 136
    Khilgaon
    hahahahah true but there is no room left on the table for it
      • Logitech G402
    Nowy Warsaw
    Open secret is the best and cheapest way.
    table fan doesn't necessarily need to sit on a table :3
      • 136
    Khilgaon
    So bought the Cooler master 690 III case + 3x sickleflow x fans + Hyper 212x . Idle temp decreased by 10 degrees/
    CPU temp didn't cross 60 degrees while running GTA V for 1 hour.
    congratulations!
  1. CPU Cooler Suggestion
    By sammi in forum Help - PC Buying
    Last Post: February 7th, 2015, 14:42
  2. CPU Cooler Suggestion ??
    By seal in forum Others PC Hardware
    Last Post: November 10th, 2013, 04:41
  3. Need Suggestion for Cooler
    By LuSTRiDE in forum Help - PC Buying
    Last Post: May 11th, 2013, 14:16
  4. Suggestion for a CPU cooler
    By vergil007 in forum Help - PC Buying
    Last Post: November 20th, 2011, 23:54
  5. Need suggestion about cpu cooler
    By shahriar in forum Others PC Hardware
    Last Post: October 25th, 2009, 00:40
Page generated in 0.23506 seconds with 14 queries.
