Results 1 to 13 of 13
Thread: TP-Link TL841N WiFi Speed Problem
    Default TP-Link TL841N WiFi Speed Problem
    nothing!
    which device are we talking about here? i mean the wifi device that you are trying to use... a tablet or a phone? if so its pretty normal.
    there are other things like distance and number of wifi devices connected which can affect the wifi bandwidth.
    Wi-Fi never gives the full link speed in actual data transfer. There are a lot of other factors affecting the speed. The highest I've ever got with a Nexus tablet was 30 Mbps on a 802.11n 65Mbps link. And even the link speed drops if there are too many devices around or the router is far away from the device.
    If the wifi device is phone/tablet, then it is normal I think. Don't know the exact reason. The mobile also supports n band. So technically it should achieve higher speed.
    Here is a file transfer from pc to pc:
    wifi adapter: tplink 725N
    The speed is not stable. But it reaches near 100mbps.
    Here is a file transfer to an Xperia P via FTP:
    The router in use is TP-link 740N
    i got about 32Mbps on a nexus 7 2013, 2.4GHz 65Mbps link.
    but on a laptop with a mediatek 150Mbps wifi i could actually get about 100Mbps(limited via the LAN ports)
    Sorry for that, forgot to mention, the device is a laptop, and the laptop is 12cm away from the router. no other device is using the net.
    And the built in wifi receiver link speed is 150mbps, it was working fine with wr720n.
    can u check the speed of file copying or its the speed of file copying?
    will test mine and report back.
    mine working nicely, over an 150Mbps connection getting about 10MBps, which is actually limited via the 100Mbps wired connection.
    im utilizing 26% of 100mbps connection which means 26mbps or 3.250MBytes/sec
    u r getting 82mbps pretty close to 100mbps limit.
    But how come im getting so low numbers? testing on my iphone 4S. is it the device?
    yes it is the device. phones/tabs usually dont get that much speed.
    I usually get around 2.5-4MBps on my nexus 7 2013, although now getting this.
    and this is my routers settings. default actually.
    is your wireless advanced setting's value same as mine?
    not more than 30Mbps? u said laptop right?
    can you copy file the other way around and see what happens?
    btw something weird happened too, when i first bought this tab i got around 1MBps max and all on a sudden i started getting 3 or 4MBps, no update no nothing :S
    Im using a SMC router but tplink has the same interface, i use TPlink router at my home.
    • @bhi's Gadgets
      • Gigabyte Z87X-UD3H
      • Samsung 30nm 2x4GB
      • Gigabyte HD7950 3GB WF3
      • Samsung 20" LED BX-2035
      • Creative SoundBlaster Z
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Seasonic X-650 km3 80+ Gold
      • Luminous Solo 1200 VA
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    the problem is with 841n and 841nd model, I have seen users having this problem on this specific router.
    not entirely true. 841n version 8 using for 3 years and getting same result as redwan i.e 9-10.5MBps from pc to laptop via wifi(laptops card is a 150mbps one).
    ashe pashe microwave oven chole na to?
    jodio sarakhon oven chalabei ba ke!
    maximum transmit rate thik ache to?
    • @bhi's Gadgets
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    nop
    nop
    hmm amio deksi, shobar hoi nai, but recently ei router take nieyi same report ashtese, ar taw jara notun kinse sudhu tader e ei prob hoise.
    version 9 emnei faltu, problem howar kotha chipset change korse.
  1. Sale (Used) TP Link TD-W8950ND ADSL Wifi router
    By Xel-Naga in forum Shop - General
    Last Post: December 23rd, 2014, 00:35
  2. Sale (Used) Samsung Galaxy Note I || TP-LINK TL-W727N Wifi Receiver
    By PrK in forum Shop - Gadgets
    Last Post: January 15th, 2014, 05:40
  3. Sale (Used) TP-LINK TL-W727N Wifi Receiver + 150Mbps Wifi B/G/N router
    Last Post: December 11th, 2013, 10:20
  4. Sale (Used) Tp-link pci wifi card
    By dying4004 in forum Shop - Gadgets
    Last Post: August 9th, 2010, 11:33
Page generated in 0.24973 seconds with 15 queries.
