Results 1 to 17 of 17
Thread: Power Supply Surges Detected during the previous power on
    • Saiful418's Gadgets
      • ASUS Z97-K
      • i5 4570 @ 3.2 GHz
      • 8 GB RIPJAWS
      • 1TB WESTERN DIGITAL
      • Sapphire 7970 Vapor X 3 GB
      • Viewsonic VX 2270S
      • CREATIVE SOUND BLASTER 24 BIT 5:1
      • A4TECH BLOODY B110
      • A4TECH BLOODY V9 C
      • THERMALTECH LITEPOWER 700 WAT
      • SAMSUNG DVD WRITER 24X
      • RAHIM AFROZ
      • WINDOWS 8 64BIT (CRACK)
      • 5.9 (LOWEST)
      • HHEHEHE!!!! RIG UNDER COSTRUCTION
      • LINK 3
      • INTERNATIONAL 120KB/s (AVG) BDIX 350KB/s
      • 1126KB/S (BDIX)
    Saiful418's Avatar
    Mar 2015
    Default Power Supply Surges Detected during the previous power on
    I have got this error message 2nd time......... but dunno why
    Last night i checked My PC was on for 8 hours.... No overclock, No Voltage up down
    When i was Playing the Assassins creed Chronicle:China The monitor screen was flashing suddenly However after 5/6 mins the flashing stopped
    But After 3 hours of playing the PC totally shut down & auto restarted Then i get this message
    My question is why that happened?????? What's the solution????? Plzzzzzzzzzzzzzzz Help
    May i know who suggested you to buy litepower 700w???
    • Sybaris Caesar's Gadgets
      • Intel DH61WW B3 Rev.
      • Intel Core i5 2400 3.10 Ghz
      • Thermaltake Commander
      • Logitech G402
      • Original Xbox 360 Wireless
      • Cooler Master G550M
    Sybaris Caesar's Avatar
    Nowy Warsaw
    ^whatever the guy above asked. Tao abar bhumikompe ki na ki hele dule gese >_<
      • ASUS Z97-K
      • i5 4570 @ 3.2 GHz
      • 8 GB RIPJAWS
      • RAHIM AFROZ
      • 5.9 (LOWEST)
      • LINK 3
      • 1126KB/S (BDIX)
    Saiful418's Avatar
    Mar 2015
    No one suggested i bought it on 2012
    Quote Originally Posted by Saiful418 View Post
    Change that piece of s.hit as soon as possible.
      • Asus vx229h ||Samsung 21.5&quot; S22A300B
    he uses 7970 vapor x with lp
    rip
    Quote Originally Posted by furiousTaher View Post
    rip
    ৭০০ ওয়াট, বুঝলা, সাআআআতশ ওয়াট, অ্যাঁ
      • ASUS Z97-K
      • i5 4570 @ 3.2 GHz
      • 8 GB RIPJAWS
      • RAHIM AFROZ
      • 5.9 (LOWEST)
      • LINK 3
      • 1126KB/S (BDIX)
    Saiful418's Avatar
    Mar 2015
    Building my rig since 2012
    @ that time system was okay with i3 2nd gen & HD 7790 1gb Dual X
    in 2014-15 changed my mobo cpu gpu ram monitor etc... so now the sytem is unstable....
    I know this psu doesnt provide that much wattage however if u had the build like mine wouldnt u take it for 2K
    if it's must to change then i've shortlisted afew.....
    CM V550
    TT Smart 650w
    Corsair CX500
      • Logitech G402
      • &#8734;
    Nowy Warsaw
    Cm g650m
    CM V550
    TT Smart 650w
    Corsair CX500
    deduct tt smart series and Corsair cx series.
    Take either CM v series or Tt Toughpower. If budget short, take CM G series.
      • ASUS Z97-K
      • i5 4570 @ 3.2 GHz
      • 8 GB RIPJAWS
      • RAHIM AFROZ
      • 5.9 (LOWEST)
      • LINK 3
      • 1126KB/S (BDIX)
    Saiful418's Avatar
    Mar 2015
    okay... thnx
      • Samsung KS8000 55&quot;
    This is a common issue with Asus Motherboard. I dont think that its related to your PSU.
    just go into the bios and turn off surge protection.
    if u still face similar power loss issue then u can blame ur PSu
    Also update ur Bios
    I don't think it's a power supply issue too plus you have an UPS that should suppress most of the surge(if any occurs) but at the same time running a 7970 with a TT LP700 is just insane. See if you can change it.
    and whats up with the Z97K and H81Plus?
      • Philips 191EL 19&quot; LED @77 Hz
    I don't think his specs are up to date.
      • ASUS Z97-K
      • i5 4570 @ 3.2 GHz
      • 8 GB RIPJAWS
      • RAHIM AFROZ
      • 5.9 (LOWEST)
      • LINK 3
      • 1126KB/S (BDIX)
    Saiful418's Avatar
    Mar 2015
    My board is Z97 K The given pic is collected from Google
    :3
    • Trave160's Gadgets
      • MSI B350M Mortar AM4
      • AMD Ryzen 5 1600
      • 16GB DDR4 3000Mhz
      • 3TB Western Digital red
      • ASUS Strix GTX 960 4G
      • Dell S2216H 22 Inch monitor
      • Logitech Speaker
      • TtEsports Knucker
      • PS4 Dualshock 4 controller
      • Pendrive 4GB
      • NunuCom Ltd, Penus group
      • Super San 200kbps
      • 105*2
    Trave160's Avatar
    A Secure Area
    His mind is not upto date people
      • ASUS Z97-K
      • i5 4570 @ 3.2 GHz
      • 8 GB RIPJAWS
      • RAHIM AFROZ
      • 5.9 (LOWEST)
      • LINK 3
      • 1126KB/S (BDIX)
    Saiful418's Avatar
    Mar 2015
    Weird
    If it isnt a PSU issue then fine i will run the rig with care....... & also updated the Mobo bios & disabled anti surge
    In the mean time i will be saving money for CM V550
  1. Power supply
    By yahyasharif in forum Others PC Hardware
    Last Post: June 22nd, 2014, 16:50
  2. Sale (Used) Tansnet Casing with 430watt Thermaltek Lite power Power Supply
  3. power supply
    By Spider72man in forum Help - PC Buying
    Last Post: September 30th, 2011, 00:43
  4. Replies: 21
Page generated in 0.27139 seconds with 14 queries.
