Results 1 to 17 of 17
Thread: UPS not saving power, turning off abruptly
    • Trave160's Gadgets
      • MSI B350M Mortar AM4
      • AMD Ryzen 5 1600
      • 16GB DDR4 3000Mhz
      • 3TB Western Digital red
      • ASUS Strix GTX 960 4G
      • Dell S2216H 22 Inch monitor
      • Logitech Speaker
      • TtEsports Knucker
      • PS4 Dualshock 4 controller
      • Pendrive 4GB
      • NunuCom Ltd, Penus group
      • Super San 200kbps
      • 105*2
    Trave160's Avatar
    A Secure Area
    Default UPS not saving power, turning off abruptly
    Am using a Prolink 700VA UPS, Just bought this brand new from a friend a few months ago. But the issue now is whenever electricity goes my PC turns off suddenly and am getting this continuous beep with red light. Either it's not powering up properly from the Socket or matter of fact battery is dead.
    Am using a 15A 220V Multiplug Three-pins on a 10A Socket adapter Two-pins. Was working fine till now :/
    Update: Plugged it off to see it work in Desktop, still has charge but when I game it somehow doesn't
    • Sybaris Caesar's Gadgets
      • Intel DH61WW B3 Rev.
      • Intel Core i5 2400 3.10 Ghz
      • Thermaltake Commander
      • Logitech G402
      • Original Xbox 360 Wireless
      • Cooler Master G550M
    Sybaris Caesar's Avatar
    Nowy Warsaw
    R.I.P the battery. Amartao erokom. MS Word ba idle thakar time e current gele backup dey but game khelar time e gele shesh.
      • AMD Ryzen 5 1600
      • 16GB DDR4 3000Mhz
      • Logitech Speaker
      • TtEsports Knucker
      • Pendrive 4GB
      • Super San 200kbps
      • 105*2
    Trave160's Avatar
    A Secure Area
    Quote Originally Posted by Sybaris Caesar View Post
    It's probably has something to do with the GPU. I heard at Peak consumes shittons of power
      • Logitech G402
    Nowy Warsaw
    Quote Originally Posted by Trave160 View Post
    Stupid GPU!
    either the battery is dead or as u have said its only a 700VA ups so i'm guessing its about 420W(!), and if ur system consumes more than that during gaming ur ups wont give any backup.
    do some normal testing like keep the pc on, just normal desktop environment, unplug the AC main line and see if it can keep the pc turned on.
      • AMD Ryzen 5 1600
      • 16GB DDR4 3000Mhz
      • Logitech Speaker
      • TtEsports Knucker
      • Pendrive 4GB
      • Super San 200kbps
      • 105*2
    Trave160's Avatar
    A Secure Area
    Already did that, check OP
    Try to list down & sum up the total peak power draw by adding the TDP of all components that are powered by ups ( including ur monitor or other gadgets, equipment) then post those figure here.
    sorry i couldn't make head or tail of this line "Update: Plugged it off to see it work in Desktop, still has charge but when I game it somehow doesn't"
    mane hoilo destop a thakle ups power dite pare but gaming er shomoi UPS power dite pare na. :/
      • AMD Ryzen 5 1600
      • 16GB DDR4 3000Mhz
      • Logitech Speaker
      • TtEsports Knucker
      • Pendrive 4GB
      • Super San 200kbps
      • 105*2
    Trave160's Avatar
    A Secure Area
    Yeah, this UPS's power factor is 0.7 which makes it upto 490W.
    GPU: 200W Concurrent
    CPU: 160W Concurrent
    Other Peripherals on Motherboard: 60-70W including DVD-Drive, SSD, HDD, RAM, Stock CPU Cooler and Back Panel Fan
    Monitor: 40W Max
    I don't know how much power does keyboards and mouses take. I only have the Monitor and PC connected
    Monitor: 40W Max
    450w x 20% (your psu is 80Plus bronze) = 540w.
    Monitor: 40W Max
    mobo VRM and GPU VRM might draw a bit more thn 70W.
    and u forgot about the efficiency of the PSU. its upto 87% and usually stays at like 82% so u have to factor in atleast 18% more power.
    @Trave160 pretty much all offline ups even well known brands like APC has their offline UPS rated at .6 power factor
    so its quite safe to assume ur UPS also comes with a .6 PF despite whats been written on its spec.
    .7 and above PF is mostly available in Online UPS.
    so at .6 ur UPS can provide max 420watt. A bit less in real life.
    ur PSU is around 80+ eff. which means the PSU can draw as much as 562 watt(80% effi) to 529 watt (85% effi) from the UPS
    but as U can see ur UPS can only support max 420watt or even less.
    So even if your PC consume a bit less lets say around 350 watt with 82% effi it will try to draw 426 watt from the UPS. n thats when the restart occurs.
      • AMD Ryzen 5 1600
      • 16GB DDR4 3000Mhz
      • Logitech Speaker
      • TtEsports Knucker
      • Pendrive 4GB
      • Super San 200kbps
      • 105*2
    Trave160's Avatar
    A Secure Area
    @VANGUARD Bhai, do you still have that UPS you're selling
    I just realized there was no point buying this then
    Yes. But don't try to negotiate.
      • AMD Ryzen 5 1600
      • 16GB DDR4 3000Mhz
      • Logitech Speaker
      • TtEsports Knucker
      • Pendrive 4GB
      • Super San 200kbps
      • 105*2
    Trave160's Avatar
    A Secure Area
    Depends, what's the price?
    http://banglagamer.com/showthread.ph...ree-1250VA-UPS
  1. Replies: 32
    Last Post: January 18th, 2013, 00:04
  2. Farcry 3 is not saving
    By shafi in forum Gaming Topics
    Last Post: December 18th, 2012, 05:48
  3. Replies: 13
    Last Post: October 31st, 2011, 19:57
  4. GTA 4 saving problems
    By MasterOfDeath in forum Action-Adventure
    Last Post: May 2nd, 2011, 20:36
  5. CoD 4 In game Video demo saving!!!!
    By furiousTaher in forum Call of Duty
    Last Post: February 20th, 2011, 09:17
Page generated in 0.28441 seconds with 14 queries.
